Basic basic basic
Page 1 of 1 [7 Posts]
ManuMontevideo
PostPosted: Thu Aug 19, 2004 11:02 am    Post subject: Basic basic basic Reply with quote  Mark this post and the followings unread
I don't know Embarassed Embarassed like you see, this question is very basic but a problem for me.
The reverb in the FX Area does not sound to me, but in the voice Area all is OK.
In which I am being mistaken? erm, maybe not ...
 Filesize:  15.93 KB
 Viewed:  10821 Time(s)
Last edited by ManuMontevideo on Thu Aug 19, 2004 4:45 pm; edited 2 times in total
G2 patch files: 626
PostPosted: Thu Aug 19, 2004 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
That looks fine, does the 2-Out module in the voice area have fx 1/2 selected as the destination?
General Elektrick
PostPosted: Thu Aug 19, 2004 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you want to use the reverb for external effect processing in the FX area
you need to have a simple 2 in module if you want to put material from the inputs of the synth thru the verb.
The FX in module is for routing sounds from the voice area to efx area.
Best,
General Elektrick
Audio files: 302
PostPosted: Thu Aug 19, 2004 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
You posted the same picture twice, probably not what you meant to do.
Does the reverb not work at all for you in the effects section or does it sound bad ?
Jan.
ManuMontevideo
PostPosted: Thu Aug 19, 2004 5:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm making my first path Embarassed Embarassed
Thaaaaaanks to all too much coffee for the answers, I'm trying to apply the reverb to the general sound of the patch, to all the patch not for the physicals ins of the synth.
Sorry my english, but you understand what I'm trying to say?.
my first.pch2
 Filename:  my first.pch2
 Filesize:  1.98 KB
 Downloaded:  1544 Time(s)
G2 patch files: 626
PostPosted: Thu Aug 19, 2004 6:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
At the moment, the patch in the voice area is assigned to the main out 1+2, click the FX [1/2] button as shown, this will assign it to the FX-in module in the FX area (and to your reverb).
 Filesize:  9.2 KB
 Viewed:  10809 Time(s)
ManuMontevideo
PostPosted: Fri Aug 20, 2004 12:44 am    Post subject: Reply with quote  Mark this post and the followings unread
dancing Yeeees , thaaaanks, the first Embarassed
