<on air> Various Artists March Equinox concert
Two Phasers in a Box
Page 1 of 1 [18 Posts]
austrohungaro
PostPosted: Tue Jul 08, 2008 3:22 am    Post subject: Two Phasers in a Box
Subject description: Can I use only one transformer to power both PCBs?
Hello
I moved my Krautrock Phaser to a new, bigger case. It is big enough to fit a Tau Phaser too, and I don't know if I can use only one transformer (830 mA) to power both PCBs.
I know I could build a +-15V Power Supply, but I already have populated the PCBs, and I'd hate to do de-soldering to remove all the redundant parts.
Is it recommended to power two PCBs from the output of a single transformer? Should I use two transformers?
Thanks
Genís
jhaible
PostPosted: Tue Jul 08, 2008 4:12 pm    Post subject: Re: Two Phasers in a Box
austrohungaro wrote:
Hello
Thanks
Genís
You cannot simply connect the transformers to the AC inputs of two PCBs.
Here is what I'd try (should work, but is untested):
Build the Krautrock with on-board PSU, and the Tau without.
Then bring the +/-15V DC from the Krautrock over to feed the Tau.
The Krautrock *should* be able to carry the extra current, with its heatsinks and all. (But you have to check for yourself and ascertain that nothing gets too hot!). It won't work the other way round (AC on TAU, DC on Krautrock), because on the TAU there is no room for big heatsinks.
Let us know when it works!
JH.
Dave Kendall
PostPosted: Wed Jul 09, 2008 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi.
Hope this is not too OT - it's about 2 JH pcbs in one box, one of which is a TAU, but there's a couple of things I'm not sure about..... Smile
I was hoping to be able to power both the Triple Chorus and a Tau Phaser from the same transformer, in a 1U rack case. I found a neat low profile 18-0-18 AC toroidal which is rated at 15VA, which if I've got it right, should put out around 290 mA rectified. (hopefully that would be enough for both devices)
In another thread on the KenStone designs sub-forum, http://electro-music.com/forum/topic-27075.html Ken suggested that it would be possible to run both a CGS14 http://www.cgs.synth.net/modules/cgs14_psu.html and a CGS66
http://www.cgs.synth.net/modules/cgs66_psu.html from the same 18-0-18 75VA transformer.
I have an EFM 3501 (similar to the CGS66 - the docs are in the thread above) and was going to attempt that soon for the modular. But that sounds like I'd be attempting what isn't possible with the 2 JH boards.........
I had assumed that the power conditioning/regulator sections of the JH boards did roughly the same sort of job as the 2 CGS boards, but with lower capacity capacitors for example - 470uF vs. 2200uF +.
I've probably misunderstood something here - I'm very green as far as PSUs are concerned....'Embarassed' Does anyone know what the differences are between running the 2 CGS PSU boards off one transformer, and running the 2 JH boards? I guess omitting the on-board regulation and running both JH boards off ±15V with a separate PSU like the CGS boards would work, but it would be nice to be able to use the PSU regulation on the JH boards themselves if possible.
Would upgrading some components on one of the JH boards, and taking a ±15V feed to the other with its PSU/regulator components omitted work at all?
Sorry for all the questions, but it has me puzzled. PSUs going bang I guess would not be much fun...........
(BTW, The tau is due for final assembly and testing very soon. Have received the last few parts ready to put in... YAY! ....... Smile )
jhaible
PostPosted: Wed Jul 09, 2008 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Speaking of my PCBs only, there are two options:
Either
(1) give every PCB its own transformer & fuses and use the on-board PSU,
which may not be shared between PCBs,
or
(2) power several PCBs from a +/-15V DC PSU (omitting on-board PSU), which can be shared between several PCBs.
A subset of (2) is to use the on-board PSU of one PCB and feed the +/-15V DC from this board to the other boards (these, without on-board PSU). But for this, you need better heat sinking than is normally provided, so you have to find a solution for attaching (insulated!!) heat sinks to the voltage regulators of that first PCB that has the PSU.
You *may* also have to increase the 470uF caps at some point (depending on teh number of modules, socondary of your transformer, etc.)
But the 470u are oversized already (providing some reserve for loosing capacitance from ageing).
If you try anything like that, you should know exactly what you're doing.
If you don't - how much is a small AC wallwart, really? You probably get 3 or 4 wallwarts for the price of a good toroidal transformer, fuse holders, power switch, and what else you need for bulding the mains side of your own PSU.
JH.
austrohungaro
PostPosted: Thu Jul 10, 2008 1:49 pm    Post subject: Question about Tau's CV THRU and Krautrock possible CV IN Reply with quote  Mark this post and the followings unread
I am drilling the panel. It has been etched by my friend who is into engraving/printing. He did a panel with clouds for my Two Phasers case.
Before wiring and connecting the boards, I am thinking about using Tau's CV THRU as a possible Krautrock CV IN
Nevertheless, you *should* be able to feed a CV into the *Tip* of a TRS plug into the AMOUNT jack, with Sleeve and Ring both *unconnected*, and a connection of the Phaser's signal GND to the GND of the CV-producing device. The interesting CV range will be about 0V ... +10V in that case.
JH.
I found that Jürgen tip on the forum, but I am not sure of the way to adapt that idea, so...
This is my guess:
From Tau's CV OUT jack -> CV -> to Krautrock's AMOUNT ???
From Tau's CV IN jack -> GROUND -> to Krautrock's SIGNAL GND ???
Is it correct?
What pin of AMOUNT connector should receive Tau's CV OUT?
Where do I get Tau's Ground? And where to send it?
To Krautrock's AUDIO OUT Jack GROUND? Or AUDIO IN Jack?
Thanks
Genís
This is a printing of the panel. Words are reversed because panel was not etched to be printed, but to be a panel for my Phasers Case.
 Filesize:  2.99 MB
 Viewed:  538 Time(s)
Audio files: 309
PostPosted: Thu Jul 10, 2008 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's a pretty unique panel, I edited the image a bit to get a better idea of what it might look like as a panel and thought it would be a bit like below ...
 Filesize:  117.63 KB
 Viewed:  488 Time(s)
austrohungaro
PostPosted: Thu Jul 10, 2008 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's how it looks
When it's finished I'll post pictures on the "Photos of what you've built..."
That's the panel in its box, with handles and first holes.
 Filesize:  722.62 KB
 Viewed:  504 Time(s)
Cat-A-Tonic
PostPosted: Thu Jul 10, 2008 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is GORGEOUS!
can't wait to see it with knobs on.
I wish I had access to a printshop.
The process of such mediums is alot of fun when you get rolling.
jhaible
PostPosted: Fri Jul 11, 2008 3:12 am    Post subject: Re: Question about Tau's CV THRU and Krautrock possible CV I Reply with quote  Mark this post and the followings unread
Absolutely cool frontpanel!
*Please* put a picture of this in my "Pictures" thread as well, once this is finished!
This is my guess:
Is it correct?
I have my doubts about the two CVs matching together nicely.
Both Phasers have very nonlinear CV response, and different CV range for their cores.
JH.
austrohungaro
PostPosted: Sun Jul 13, 2008 5:25 am    Post subject: Re: Question about Tau's CV THRU and Krautrock possible CV I Reply with quote  Mark this post and the followings unread
JH.
Schade!
Anyway, I posted a picture of the finished case on the "Photos of what you've built..." thread (http://www.electro-music.com/forum/post-195588.html#195588).
My Krautrock Phaser is not working perfect:
- Bypass led does not light (but Bypass Switch works!)
- 3rd lightbulb on panel does not light.
I have checked the board and as far as I can see, there's no cold solder, bad joint... I don't know if my SMD soldering was good (I'm not sure of my soldering in general). I don't know what can it be. Looks like two different problems, as LED uses +15 rail and LAMP -15. If I am right, they do not share parts, circuit paths...
I have measured DC on LED and LAMP
LED gets around +14.80
LAMP gets around -15.40 when everythnig disconnected.
If I connect the pots and measure ground from Ciurcuit's Ground it goes up and down. Can't be very exact on readings because my meter is maybe too crap, but it goes from 0 to -15.40
If I measure from pin to pin it reads 15.50
Well, I'll cross my fingers, as I am finishing the 20-pole Phaser... I guess leds won't light...
jhaible
PostPosted: Sun Jul 13, 2008 10:19 am    Post subject: Re: Question about Tau's CV THRU and Krautrock possible CV I Reply with quote  Mark this post and the followings unread
LED should never have much more than 2 V (depending on its colour).
If you have more, it's probably soldered in backward, and quickly destroyed.
JH.
austrohungaro
PostPosted: Sun Jul 13, 2008 11:04 am    Post subject: Re: Question about Tau's CV THRU and Krautrock possible CV I Reply with quote  Mark this post and the followings unread
JH.
OK. LED works now. I think I entered a bad karma loop reversing dead leds and killing reversed leds...
Now, I'm going to test the lughtbulb is OK, not dead, and the wiring.
Danke!
austrohungaro
PostPosted: Sun Jul 13, 2008 2:35 pm    Post subject: Lightbulb Reply with quote  Mark this post and the followings unread
I have tried everything
Finally I have changed lamp AND lampholder and now it lights BUT it is always ON, it does not go up and down as the other two lamps on board, so... Can it be something about Q2 or Q3? I don't know who does what and I have no idea of how to measure it...
jhaible
PostPosted: Mon Jul 14, 2008 12:03 am    Post subject: Re: Lightbulb Reply with quote  Mark this post and the followings unread
Ok, I can explain how the lamp driver circuit works:
Q2 and Q3 form an inverting amplifier (think "inverting opamp" - it's not the same, but actually quite similar).
Q2 provides a lot of voltage gain. Q3 is just an emitter follower to provide enough current. The base of Q2 is the "op amps's" inverting input. The non-inverting input is not actually there - but D9, D10, D11 at the emitter of Q2 act as if you had a non-inverting input at aroud -2.3V. That's your (slightly negative) reference voltage for the inverting amplifier.
The Inverting amplifier is built with R23 and R32 providing a feedback loop around the amp.
R31 limits the amp's output current and keeps part of the heat away from Q3.
JH.
austrohungaro
PostPosted: Wed Jul 16, 2008 6:05 am    Post subject: Re: Lightbulb
Subject description: Alles ist gut
It was Q2. It was dead or faulty, I don't know, but I have replaced it and now everythings works fine, and my Krautrock Phaser not only sounds great, it also looks great!
Vielen Dank!
Now it's time to finish the 20-pole Phaser, and try to power it from the Krautrock's power supply...
Panel lamp and Bypass LED
 Filesize:  68.74 KB
 Viewed:  16566 Time(s)
jhaible
PostPosted: Wed Jul 16, 2008 12:14 pm    Post subject: Re: Lightbulb
Vielen Dank!
Glad it works!
And, repeating myself, that front panel is *so* cool!
JH.
Now playing: Tori Amos, Bouncing off Clouds. Smile
austrohungaro
PostPosted: Thu Jul 17, 2008 2:57 am    Post subject: Re: Lightbulb Reply with quote  Mark this post and the followings unread
It was not easy for me to check that. I have no knowledge of electronics. I made a drawing of the signal path to understand what to test, transistors legs, CBE, EBC, NPN, PNP...
Also, I have noticed that the regulator's heatsinks get quite hot, in particular LM317's. Not that I got hurt when I touched it, but I don't know if I should find bigger ones before trying to feed the Tau board from the Krautrock's.
Another thing... MOD pot only seems to affect the sound when it's almost fully clockwise. Is that behaviour considered 'normal'?
Pictures of my drawings (so you can laugh) and my heatsinks follow.
lächerlich Zeichnung
 Filesize:  37.11 KB
 Viewed:  16522 Time(s)
Are they too small?
 Filesize:  23.28 KB
austrohungaro
PostPosted: Sun Jul 27, 2008 3:35 am    Post subject: 20-pole Phaser working Reply with quote  Mark this post and the followings unread
I finally connected the 20-pole Phaser.
My first PCB to work perfect at first powering up!
Maybe my building skills are improving from project to project.
It is powered from the Krautrock Phaser.
It sounds great!
Now I will take it to my studio next to my modular to try CV In, CV Out and V/Oct In.
 Filesize:  65.63 KB
 Viewed:  16381 Time(s)
