 Forum index » Clavia Nord Modular » G2 Patches - Completed » External Control
Ableton Live Control
Page 1 of 1 [4 Posts]
General Elektrick
PostPosted: Sat Sep 04, 2004 12:26 pm    Post subject: Ableton Live Control Reply with quote  Mark this post and the followings unread
I would like to ask if it would be possible to make up a new patch category
for "external control" making it easy to share the work on patches controlling external gear.
I would make a start with my Ableton control patch, nothing special but a 16 channel volume control, 16 channel mute control, 16 channel 2 Aux sends, a little EFX control and 16 button, 16 knobs not predefined.
Of course this patch has to be set up in Ableton before it could be used.
I hope to start an vivid exchange of gear controller Wink
Best,
General Elektrick
Ableton tr.1-16 aux 1-2 efx 16 freeextra.pch2
Ableton live 16 channel volume control, 16 channel mute controll, 16 channel 2 Aux sends, a little EFX control and 16 button, 16 knobs not predefined.
 Filename:  Ableton tr.1-16 aux 1-2 efx 16 freeextra.pch2
 Filesize:  2.95 KB
 Downloaded:  2624 Time(s)
Last edited by General Elektrick on Sat Sep 04, 2004 2:00 pm; edited 1 time in total
Audio files: 235
PostPosted: Sat Sep 04, 2004 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good suggestion. I added the category. You should edit your post and change the subject... Laughing
General Elektrick
PostPosted: Sat Sep 04, 2004 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
thumb up This was fast, Howard Very Happy
thanks!
General Elektrick
Sourultrafast
PostPosted: Sat Dec 19, 2009 9:43 am    Post subject: Rec ready and cell triggering/recording Reply with quote  Mark this post and the followings unread
Hi alll
So far I figured out how to send a note on message assigned to the cell in order to record and trigger a cell but I cannot get the note on message to arm my track.
I used a Momentary Switch on/off module connected to a MIDI note send module. Live 7 picks up the MIDI message, achieve to assign it to Record arm but surprise, nothing happens when I push the button on the G2. I had to mangle a bit with level conversion (from Bipolar to Pos if I remember) in order to send one clean note @ 100 Velocity.
Does anyone have suggestions of what could be the problem? It works fine if I use a note from the keyboard but not if I use a note triggered from the assigned buttons.
