Very simple piezo trigger/gain amp
Page 1 of 1 [12 Posts]
creatorlars
PostPosted: Tue Jul 29, 2008 11:26 am    Post subject: Very simple piezo trigger/gain amp
Subject description: Please give me your suggestions
I just bought an Emu Drumulator, which has 4 gate inputs to fire the drum sounds. The gate inputs are functioning great when triggered with a gate signal from my synth or sequencer. However, my Piezo-based drum trigger pads are not producing a voltage level high enough to trigger the drum -- Unless I strike them very hard.
I need to rig together a very last minute circuit to boost the sensitivity and gain on 4 incoming Piezo triggers before they get to the Drumulator. I am assuming this would be something extremely simple, like a quad op-amp, four sensitivity pots, and a handful of resistors.
I am familiar with some gate-to-trigger and Thomas Henry's Trigger conditioner circuits, however I don't even need this much functionality -- just something simple and probably battery powered in a breakout box.
Ideas on where to look? Possible problems with the idea?
Coriolis
PostPosted: Tue Jul 29, 2008 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was just about to suggest those TH circuits - I wonder if they get much simpler than that?
C
creatorlars
PostPosted: Tue Jul 29, 2008 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe not... the TH "Trigger Conditioner" doesn't have a sensitivity level pot, though. His "Piezo Drum Pad" seems to. Really i just need a way to boost the level of the piezo signal, no need to condition the trigger or anything.
Coriolis
PostPosted: Tue Jul 29, 2008 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not if your Drumulator's inputs have conditioning built already, no...
I haven't used one, so I wouldn't know.
C
Funky40
G2 patch files: 5
PostPosted: Tue Jul 29, 2008 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
if you just wanna trigger then i think you need a comparator circuit.
this is the Circuit serenadi, a Friend of mine has used in the past.
"comparator with adjustable threashold".
maybe look at wikipeda or other places for more infos about comparators.
I have never bult one myself
edit: had to change the attachment, this one is what i meant
 Filesize:  46.06 KB
 Viewed:  302 Time(s)
Joel
PostPosted: Tue Jul 29, 2008 5:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
strangely I was just looking this up! Here's a link to an old PAIA page on percussion sensors - the page has been deleted so the link uses the internet archive :
http://web.archive.org/web/20030608211101/http://www.paia.com/drumsens.htm
hope this helps! Joel
creatorlars
PostPosted: Wed Jul 30, 2008 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome! I think that comparator schematic is exactly what I need, for something this simple. If it has trouble triggering, I'll add in a trigger conditioning circuit. Thanks so much for the info, I'll let you know how it goes!
Funky40
G2 patch files: 5
PostPosted: Wed Jul 30, 2008 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes please, let us know !
I'm very interested in piezo triggers too
creatorlars
PostPosted: Thu Jul 31, 2008 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Should any op-amp theoretically be able to be used in that comparator schematic? I tried it last night with a TL084 but was having some problems. I know Thomas Henry's circuit is a 741. Can the op-amp's positive and negative power pins be connected to +V and Ground, or do I have to have a dual polarity supply for this? I was hoping to just use a 9V battery.
richardc64
Audio files: 26
PostPosted: Thu Jul 31, 2008 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Theoretically any op amp can be used for a comparator (despite what some may say,) but not easily with a single supply. Try the pAia circuit, which has not been deleted, but merely moved.
http://paia.com/ProdArticles/drumsens.htm
For piezos you won't need R2 and C3.
creatorlars
PostPosted: Thu Jul 31, 2008 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool -- I've bought the components to build the PAiA and thomas henry circuits.
It looks like I can piece together something that will work from a combination of these.
My concern with the PAiA circuit -- is that meant to deliver a 0-5v range? Or a 5v trigger pulse?
richardc64
Audio files: 26
PostPosted: Thu Jul 31, 2008 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
In the PAiA circuit, the LM324 is a voltage follower, so the output(s) could get as high as whatever voltage the LM324 is powered with, depending on the input voltage -- that is, how hard you strike the pad. If all you need is 5v, power it with 5v.
For a quad, single-supply comparator look up the LM339.
