Audicle newbie problem
Page 1 of 1 [15 Posts]
d2leo
PostPosted: Sat Aug 30, 2008 4:35 pm    Post subject: Audicle newbie problem
Subject description: Chuck
I have installed Audicle and when I start it from the command prompt it starts and at the chuck prompt I type chuck and I am not in the right directory and I can't change directory.
Please advise
Pd
Inventor
Audio files: 267
PostPosted: Sun Aug 31, 2008 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
do you mean miniAudicle? Audicle is experimental and not yet ready for prime time as far as I know.
d2leo
PostPosted: Sun Aug 31, 2008 4:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is Audicle not mini Audicle. I will try mini Audiclae and see if I have the same problem.
Pd
Inventor
Audio files: 267
PostPosted: Sun Aug 31, 2008 6:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, you may have much better luck with miniAudicle. Audicle seems to be so far ahead of it's time that it demands every ounce of computing power from the fastest of machines to run properly, or that's what I understand to be true.
Folks generally use either the command line version or miniAudicle. That should help.
d2leo
PostPosted: Sun Aug 31, 2008 6:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tried the miniAudicle I get the same result. I add any chuck and I get command not found. It seems I do not have it configured properly.
How do you use Chuck?
I wanted to use it in Ubuntu and have jack record my output into Ardour but I don't have the chops to configure it so I am using it in Vista.
Pd
Inventor
Audio files: 267
PostPosted: Sun Aug 31, 2008 6:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm on a Mac, but it should be similar for Vista. After installation, which consisted of just copying one file, i created an icon in my toolbar that points to that icon, then i click on the icon to start miniAudicle.
Alternatively I could just click on the icon in my Applications folder, if I didn't know how to make the toolbar icon.
Sorry but I don't have any Windows so I cannot advise specifically, but try reading the installation instructions - that should tell you.
kijjaz
PostPosted: Mon Sep 01, 2008 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm on linux also (Ubuntu, debian)
for compiling the newest miniAudicle and ChucK:
install bison flex build-essential libsndfile1-dev libwxgtk2.6-dev
then for jack support: install libjack-dev
and for ALSA support: install libasound2-dev
now the miniAudicle source code downloadable from ChucK website is version 0.1.3.8 and the ChucK included in the package is version 1.2.1.1 which is not the newest.
extract the whole miniAudicle-0.1.3.8.tgz, you'll see chuck-1.2.1.1 directory there,
you can just delete the files in there.
then get chuck 1.2.1.2 source code, extract and put in the chucl-1.2.1.1 directory we extracted from the miniAudicle package..
after than, in miniAudicle-0.1.3.8 directory, execute make linux-jack
that'd produce miniAudicle executable in wxw directory
i usually copy that to /usr/bin/miniAudicle-jack so i can execute from anywhere.
do the same and produce the ALSA version by make linux-alsa
i usually put the miniAudicle executable as /usr/bin/miniAudicle
Normally, if all the compilation and installation is correct,
i just run miniAudicle,
Edit -> Preferences, set for the sound card / sample rate you'd like to use,
Chuck -> Start Virtual Machine (or press start virtual machine in Virtual Machine window)
type in the code in the editor and add shred to test.
i think it'd usualy work.
d2leo
PostPosted: Tue Sep 02, 2008 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I think I am close. I made linux-jack and it ran but when I started it I got an error about looping.
I then tried to make the linux-alsa but it couldn't make it.
Pd
radarsat1
PostPosted: Tue Sep 02, 2008 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pd
can you give more detail? like maybe a console dump? you're not telling us anything about why "it couldn't make it".
d2leo
PostPosted: Tue Sep 02, 2008 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
When I try to run the jack install and click start Virtual Machine it hangs up.
and when I try to make alsa I get:
make -f makefile.alsa
make[1]: Entering directory `/usr/local/src/miniAudicle-0.1.3.8'
make -C chuck/src -f makefile.alsa
make[2]: Entering directory `/usr/local/src/miniAudicle-0.1.3.8/chuck-1.2.1.1/sr
c'
make[2]: `chuck' is up to date.
make[2]: Leaving directory `/usr/local/src/miniAudicle-0.1.3.8/chuck-1.2.1.1/src
g++ -o wxw/miniAudicle miniAudicle.o wxw/mAParentFrame.o wxw/mADocument.o wxw/mA
View.o wxw/mAVMMonitor.o wxw/mAMenuBar.o wxw/mAConsoleMonitor.o wxw/mAConfig.o w
xw/mAPreferencesWindow.o wxw/mAUIElements.o miniAudicle_import.o miniAudicle_ui_
elements.o chuck/src/chuck.tab.o chuck/src/chuck.yy.o chuck/src/chuck_absyn.o ch
uck/src/chuck_parse.o chuck/src/chuck_errmsg.o chuck/src/chuck_frame.o chuck/src
/chuck_symbol.o chuck/src/chuck_table.o chuck/src/chuck_utils.o chuck/src/chuck_
vm.o chuck/src/chuck_instr.o chuck/src/chuck_scan.o chuck/src/chuck_type.o chuck
/src/chuck_emit.o chuck/src/chuck_compile.o chuck/src/chuck_dl.o chuck/src/chuck
_oo.o chuck/src/chuck_lang.o chuck/src/chuck_ugen.o chuck/src/chuck_globals.o ch
uck/src/chuck_otf.o chuck/src/chuck_stats.o chuck/src/chuck_bbq.o chuck/src/chuc
k_shell.o chuck/src/chuck_console.o chuck/src/digiio_rtaudio.o chuck/src/hidio_s
dl.o chuck/src/midiio_rtmidi.o chuck/src/rtaudio.o chuck/src/rtmidi.o chuck/src/
ugen_osc.o chuck/src/ugen_filter.o chuck/src/ugen_stk.o chuck/src/ugen_xxx.o chu
ck/src/ulib_machine.o chuck/src/uana_xform.o chuck/src/uana_extract.o chuck/src/
ulib_math.o chuck/src/ulib_std.o chuck/src/ulib_opsc.o chuck/src/util_buffers.o
chuck/src/util_console.o chuck/src/util_math.o chuck/src/util_network.o chuck/sr
c/util_raw.o chuck/src/util_string.o chuck/src/util_thread.o chuck/src/util_xfor
ms.o chuck/src/util_opsc.o chuck/src/util_hid.o `wx-config --libs stc,adv,core
,base` -lasound -lpthread -lstdc++ -ldl -lm -lsndfile
chuck/src/rtaudio.o: In function `RtApiJack::closeStream()':
rtaudio.cpp:(.text+0x74b): undefined reference to `jack_client_close'
rtaudio.cpp:(.text+0x859): undefined reference to `jack_deactivate'
chuck/src/rtaudio.o: In function `RtApiJack::probeDeviceInfo(RtApi::RtApiDevice*
rtaudio.cpp:(.text+0x884): undefined reference to `jack_client_new'
rtaudio.cpp:(.text+0x89c): undefined reference to `jack_get_sample_rate'
rtaudio.cpp:(.text+0x8d7): undefined reference to `jack_get_ports'
rtaudio.cpp:(.text+0x92a): undefined reference to `jack_get_ports'
rtaudio.cpp:(.text+0x97c): undefined reference to `jack_client_close'
rtaudio.cpp:(.text+0xa10): undefined reference to `jack_client_close'
chuck/src/rtaudio.o: In function `RtApiJack::stopStream()':
rtaudio.cpp:(.text+0xd84): undefined reference to `jack_deactivate'
chuck/src/rtaudio.o: In function `RtApiJack::startStream()':
rtaudio.cpp:(.text+0xe77): undefined reference to `jack_activate'
rtaudio.cpp:(.text+0xeb2): undefined reference to `jack_get_ports'
rtaudio.cpp:(.text+0xefd): undefined reference to `jack_port_name'
rtaudio.cpp:(.text+0xf12): undefined reference to `jack_connect'
rtaudio.cpp:(.text+0x1054): undefined reference to `jack_port_register'
rtaudio.cpp:(.text+0x10d8): undefined reference to `jack_port_register'
rtaudio.cpp:(.text+0x11e1): undefined reference to `jack_get_ports'
rtaudio.cpp:(.text+0x121a): undefined reference to `jack_port_name'
rtaudio.cpp:(.text+0x1235): undefined reference to `jack_connect'
chuck/src/rtaudio.o: In function `RtApiJack::callbackEvent(unsigned long)':
rtaudio.cpp:(.text+0x330a): undefined reference to `jack_port_get_buffer'
rtaudio.cpp:(.text+0x33a7): undefined reference to `jack_port_get_buffer'
rtaudio.cpp:(.text+0x3464): undefined reference to `jack_port_get_buffer'
rtaudio.cpp:(.text+0x350b): undefined reference to `jack_port_get_buffer'
chuck/src/rtaudio.o: In function `RtApiJack::probeDeviceOpen(int, RtApi::StreamM ode, int, int, unsigned long, int*, int)':
rtaudio.cpp:(.text+0x36c1): undefined reference to `jack_get_sample_rate'
rtaudio.cpp:(.text+0x3718): undefined reference to `jack_get_buffer_size'
rtaudio.cpp:(.text+0x380d): undefined reference to `jack_client_new'
rtaudio.cpp:(.text+0x381f): undefined reference to `jack_get_sample_rate'
rtaudio.cpp:(.text+0x3832): undefined reference to `jack_client_close'
rtaudio.cpp:(.text+0x3978): undefined reference to `jack_set_process_callback'
rtaudio.cpp:(.text+0x3995): undefined reference to `jack_set_xrun_callback'
rtaudio.cpp:(.text+0x39ae): undefined reference to `jack_on_shutdown'
rtaudio.cpp:(.text+0x416b): undefined reference to `jack_client_close'
chuck/src/rtaudio.o: In function `RtApiJack::initialize()':
rtaudio.cpp:(.text+0x511e): undefined reference to `jack_set_error_function'
rtaudio.cpp:(.text+0x512a): undefined reference to `jack_client_new'
rtaudio.cpp:(.text+0x529c): undefined reference to `jack_client_close'
collect2: ld returned 1 exit status
make[1]: *** [wxw/miniAudicle] Error 1
make[1]: Leaving directory `/usr/local/src/miniAudicle-0.1.3.8'
make: [linux-alsa] Error 2 (ignored)
d2leo57@d2leo57-desktop:/usr/local/src/miniAudicle-0.1.3.8$
I appreciate your help
Pd
PostPosted: Tue Sep 02, 2008 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like you tried to compile a source directory that you already used to compile once? that would mean it'd be full of files, created by the compiler before, that it would now assume to be fine, but in this case they likely aren't because of the new settings (all of your errors deal with Jack).
I think you can use something like "make clean" or something along those lines to fix this. I never got that bit and tend to simply delete the whole directory and extract the .tar.gz file again and try again. This will probably sound terrible to C++ pro's like Radarsat1 but it works and erases all traces of previous compiling attempts, giving a blank slate.
radarsat1
PostPosted: Wed Sep 03, 2008 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
No, you're perfectly right, he needs to "make clean". The dependence on 'jack' functions when compiling against 'alsa' is the tip. This wouldn't be a problem if ChucK used tools like autotools or SCons, but as it is, Make is not smart enough to tell that those object files need to be recompiled for the new configuration.
d2leo
PostPosted: Fri Sep 05, 2008 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you the make clean worked and I reinstalled linux-jack. I still have the problem with the virtual machine hanging on the start up.
Pd
d2leo
PostPosted: Mon Sep 08, 2008 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much.
MiniAudicle is now working with jack.
kijjaz
PostPosted: Mon Sep 08, 2008 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
wow.. exciting. that's great.
