today> Bill Fox solo tonight! Chez Mosc
super simple 40106 VCO with expo or linear control
Page 1 of 4 [77 Posts]
Goto page: 1, 2, 3, 4 Next
synthmonger
PostPosted: Mon Sep 08, 2008 11:49 pm    Post subject: super simple 40106 VCO with expo or linear control
Subject description: Only uses one gate and it runs on DC or bipolar power
Be sure to read the notes! ;D
 Filesize:  44.86 KB
 Viewed:  22399 Time(s)
synthmonger
PostPosted: Mon Sep 08, 2008 11:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Err there's an error in the schematic. The linear cv should be +9 volt not +12. It'll work on 12 but you'll have to change some values I'm sure.
slabman
PostPosted: Tue Sep 09, 2008 2:02 pm    Post subject: Nice! Reply with quote  Mark this post and the followings unread
Thanks for sharing this. Looks like a great way to munge together a Weird Sound Generator with a Soundlab.
synthmonger
PostPosted: Tue Sep 09, 2008 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
bunch more uses of the 40106 on the way.
Rykhaard
PostPosted: Tue Sep 09, 2008 9:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Even more uses for the 25 that I recently bought? Smile Thanks Ray Wilson for influencing me on this chip! Very Happy
Can't wait to get finished moving my studio around, so that I can get back to experiments for the Liquid Hihat and new experiments with the CD40106! Smile
scriptstyle
PostPosted: Sun Sep 14, 2008 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
i bread boarded this up the other day on 5v. and got nothing i think im going to try and knock down the 1m's to 100k and see what happens? excited to get a tri out of a 40106 though!!
synthmonger
PostPosted: Sun Sep 14, 2008 11:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was using 9V and 12V. Not sure if 5V will work.
The linear portion really isn't linear and only have a range of a couple volts. Make sure you're connections and transistors are facing the right way, I'm 100% certain this works.
scriptstyle
PostPosted: Mon Sep 15, 2008 11:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
got it going i had a 2n reversed. very cool thanks!!
synthmonger
PostPosted: Sat Oct 11, 2008 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Remove C1 and add trim pot on the negative end of the manual voltage control to get a high frequency vco.
Pehr
PostPosted: Sun Oct 19, 2008 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
is there any chance of getting exponential control with single supply psu?
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
synthmonger
PostPosted: Tue Oct 21, 2008 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Still working on that. I tried using an expo the way fonik did in his wasp edp but no luck.
scriptstyle
PostPosted: Sun Mar 15, 2009 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok so I looking at this cuircuit again the other day. On a 5v supply I changed r1 to 10m, and c1 needs to be atleast .22uf. Now I was using a .22uf Mylar cause it was the biggest I had on hand. This gave me a frequency of about 1.6k hz. I wanted more freq I tried a 1uf electro and the top end of the ramp rounds out? Is this because the electro cap? I'm going to be making a local run to a shop that has polystyrene caps in higher numbers. Maybe this is what I need...
synthmonger
PostPosted: Mon Mar 16, 2009 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I haven't tested this on a 5V supply to be honest with ya. If I can find some time later I will test it out. A bit busy building a 100% lunetta vco right now.
What application are you using it for?
scriptstyle
PostPosted: Mon Mar 16, 2009 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm building my lunetta almost as like a 5v CMOS learning lab. I should prototyping cause nothing has made it off the breadboard or off cardboard yet. I may re concider 12v? Idk....
Rykhaard
PostPosted: Mon Mar 16, 2009 6:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
My Lunetta ..... monster, is so far running beautifully from +/-9VDC. Smile
scriptstyle
PostPosted: Mon Mar 16, 2009 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
So ryk you are using 9v? Synthmonger is using 12v. I honestly thought you where using 12v also. I keep hearing using 12v will make of easier to intergreat to my modular. But what iwas thinking was that. I will have any easier time seeing what the CMOS is doing on 5v?
scriptstyle
PostPosted: Mon Mar 16, 2009 7:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Something occured to me just now while reading the thread you just started about using a 4007's gates. This is my secound time working with this schematic and the last time I remember geting a good range of osc with a cap around 1n, but like I mentioned earlier ihad no such luck this time. Just high freq osc. Then I remembered I did have a pullup resistor before c1 the first time around. Should that make the difference?
Rykhaard
PostPosted: Mon Mar 16, 2009 7:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
The most important thing to me for running my machine, were the ability to run it from batteries as well. That, ruled out running my machine from +/-15V.
Also, the voltage limit for CMOS chips, depending on the chip type is +18 or +20V.
So - to make sure that I could run all of the CMOS chips that I would be using, I thought it better to operate the system on the +18 / 2 voltage, or +/- 9VDC. I just happened to have 7809 and 7909 1 amp voltage regulators that I had purchased in the early 90's as well. Smile
That, will allow me to run my system from 2 x 12V batteries hooked up in the +/- format, as well as interface to my modular's +/- 15V, as long as I don't let anything higher or lower than 9V into my Lunetta machine.
I've been doing ok so far. Smile
ashaxx
PostPosted: Fri Sep 04, 2009 5:38 am    Post subject: vco Reply with quote  Mark this post and the followings unread
sorry for such an amatuer question here but is the Circled A the audio out?
jean-louise
PostPosted: Fri Sep 04, 2009 8:41 am    Post subject: Re: vco Reply with quote  Mark this post and the followings unread
no, i think it's just the point where either the linear or expo CV input are connected to the circuit
jan
slacker
PostPosted: Fri Sep 04, 2009 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah that's right it's just the point where you connect either of the converters. The audio out is the "Falling ramp out".
You could technically use point A as an audio out providing that what ever you connected it to had a high input impedance, otherwise it would load the input of the inverter and stop it oscillating. That's basically what Q3 is already doing in the circuit.
Psyingo
PostPosted: Sun Sep 13, 2009 9:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I boarded one of these and it's really great. thanks for posting a schematic. I enjoy your circuits, synthmonger.
synthmonger
PostPosted: Mon Sep 14, 2009 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
By the way, use an op-amp buffer on the 'sawtooth' output. 4069 inverter gates would probably do the trick too. This gives it better if not perfect symmetry.
Youtube!
modular demos!
Whacky tunes!
synthmonger
PostPosted: Mon Sep 14, 2009 7:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh and if ya plan to build multiple VCOs out of one chip I'd limit it to a max of 4 so they won't bleedthrough/modulate each other. Keep the middle inverters grounded.
I like to stick with two VCOs in a single chip. I use three inverters wired in series with the first two for the sync input and the last one as the vco core.
Oh and I found a neat way of getting 1-100% PWM using 3 gates. It sounds pretty different than you're typical op-amp pwm configuration.
...I should spend some time posting schematics for these...
Youtube!
modular demos!
Whacky tunes!
Psyingo
PostPosted: Mon Sep 14, 2009 8:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes please, moar schematics!
