One-Line ChucK Crazy
Page 3 of 5 [121 Posts]
kijjaz
PostPosted: Sun Sep 14, 2008 6:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Code:
// Start the Party!
Step s => dac; float x; while(samp=>now) (now/3::ms)%3-x => x => s.next;
PostPosted: Sun Sep 14, 2008 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice! I'll have to listen to it again for a longer time later.
It seemed to me that you could drop the "x" and use s.last() instead. For the first few minutes that sounded basically the same to me but it *is* feedback (and introduces a samp of delay) so after a longer time it might get radically different?
kijjaz
PostPosted: Sun Sep 14, 2008 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh yes Kassen, it should be reduced much more so we can do some other things also.
Yes this system can get a little bit chaotic.
first, each time we spork it, it sounds a little bit or very different..
second, sometimes we can notice a little chaotic adjustment in the beginning.
changing the numbers really help finding new sounds out of this system.
many quickly come to a stop. many stay active for a very long time or just forever.
Underwaterbob
PostPosted: Mon Sep 15, 2008 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Watch out! It starts off unassuming but gets annoying pretty fast:
Code:
Noise a => BPF f => dac; for(1 => int x; x < 360; x++){ f.set((x%7+1)*Std.fabs(2*Math.sin(x%73*x)+1), 20); 200::ms => now; }
Whatever you do don't turn the volume up in the beginning, it takes about 5 or 6 seconds to get going. Messing with the constants gets some similar and interesting things going:
Code:
Noise a => BPF f => dac; for(1 => int x; x < 360000; x++){ f.set((x%7+1)*Std.fabs(2*Math.sin(x%73*x)+1), 20); 2::ms => now; }
Digital fire!
kijjaz
PostPosted: Mon Sep 15, 2008 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
some more simple patches
Code:
// robot scan
Step s => Gain g => g => SinOsc x => dac; while(Std.rand2(1, 100)::ms => now) Std.rand2(-1, 1) => s.next;
Code:
// Woo! .. hey anybody? woo woo!
Phasor a => SinOsc b => SinOsc c => SinOsc d => Gain e => SinOsc f => dac; e.gain(800); day => now;
Code:
// Robotic circle of fifth
SinOsc a => dac; while(125::ms => now) a.freq() * -1.5 => a.freq;
Code:
// Rise of the (cute) machine.
SinOsc a => dac; while(20::ms => now) a.freq() * -1.01 => a.freq;
Code:
// a short 3n+1 melody
SinOsc a => dac; while(40::ms => now) if (a.freq()%2==0) a.freq()/2=> a.freq; else a.freq()*3+1=>a.freq;
Code:
// Analysing...
SinOsc a => dac; while(100::ms => now) if (a.freq()%4==0) a.freq()/4=> a.freq; else a.freq()*6+1=>a.freq;
kijjaz
PostPosted: Mon Sep 15, 2008 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Code:
// Great String!
Mandolin a => SinOsc b => dac; 1 => b.sync; 4 => a.freq; 1000 => a.gain; a.noteOn(1); day => now;
using Sitar instead of Mandolin is nice also. StifKarp <-- very powerful and majestic.
Underwaterbob
PostPosted: Tue Sep 16, 2008 6:30 am    Post subject: Reply with quote  Mark this post and the followings unread
This crashes on me and I can't figure out why:
Code:
SinOsc s[400]; for(0 => int x; x<400; x++){ (x+1)*10 => s[x].freq; (1/(x/4)) => s[x].gain; s[x] => dac; 100::ms => now; }
If I remove (1/(x/4)) => s[x].gain; it works, but clips like crazy quickly since it's stacking with so many oscillators.
It's not really what I want anyway. I'd rather a polynomial approximation of the equal loudness curve so each frequency could be weighted to have the same perceived volume.
PostPosted: Tue Sep 16, 2008 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
kijjaz wrote:
Code:
// Great String!
Extended remix!
Code:
3 => b.sync;
4 => a.freq;
1000 => a.gain;
a.noteOn(1);
while(1)
   4 => a.freq;
   while(maybe || maybe) a.freq() +2 => a.freq;
   Std.rand2(30, 42) * 3 => Std.mtof => b.freq;
   if(maybe && maybe)a.noteOn(1);
   1::second => now;
PostPosted: Tue Sep 16, 2008 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Code:
SinOsc s[400]; for(0 => int x; x<400> s[x].freq; (1/(x/4)) => s[x].gain; s[x] => dac; 100::ms => now; }
Hmm, I figured it was because you divide by zero when x=0, but it doesn't work if I change the starting value for x to 1, 2 or 3 either. 4 and onwards, it works. Bizarre.
/Stefan
PostPosted: Tue Sep 16, 2008 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Here you go;
SinOsc s[400]; for(0 => int x; x<400; x++){ (x+1)*10 => s[x].freq; (1/(x/4.0)) => s[x].gain; s[x] => dac; 100::ms => now; }
The ".0" turns the division into float math instead of integer math, which avoids a divide by zero caused by rounding to a integer.
example;
Code:
<<< 1 / 3>>>; //yields "0, (int)"
<<< 1 / 3.0>>>;// gives "0.333333 (float)"
[/code]
PostPosted: Tue Sep 16, 2008 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Not at all; if you round down then x/4 will be 1 for x=4 and 0 for anything smaller.
PostPosted: Tue Sep 16, 2008 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Shouldn't you get a division by zero anyway because of the first zero (tried it, you don't)? I know that you can't rely on integers converting to exact floats, but zero should surely always be zero?
/Stefan
PostPosted: Tue Sep 16, 2008 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Erm, you are right!
So we now have a issue where we think the VM *should* crash, yet it doesn't! That's a new sort of thing for ChucK! Ok, this is really weird, let me try some stuff.
PostPosted: Tue Sep 16, 2008 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got it;
Code:
<<<1.0 / 0.0>>>;
divide by zero in integer math crashes yet in floating point math it's "inf".
I'd say that would explain the clipping :¬)
Here is a version of the whole thing, reformatted for readability and with debugging print commands, I also turned down the amount of oscillators as we don't need that many for debugging;
Code:
SinOsc s[4];
for(0 => int x; x<4; x++)
   <<<"x is", x>>>;
   <<<"(x/4.0) is", (x/4.0)>>>;
   <<<"(1/(x/4.0)) is", (1/(x/4.0))>>>;
   s[x] => dac;
   100::ms => now;
Audio files: 299
PostPosted: Tue Sep 16, 2008 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why not just write 4.0/x instead of 1/(x/4.0) ?
PostPosted: Tue Sep 16, 2008 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah yes, the IEEE standard allows for those mysterious numbers in floats. Another case solved!
Here's another one-liner:
Code:
0.0 => float x; x/x => float y; <<< "y=",y>>>;
That produces "y= nan" (not a number).
/Stefan
kijjaz
PostPosted: Tue Sep 16, 2008 9:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
ho..! Wow Nice..
Underwaterbob
PostPosted: Wed Sep 17, 2008 12:01 am    Post subject: Reply with quote  Mark this post and the followings unread
It was the way I approached it. Initially it was just 1/x but I thought the gain would scale down too quickly, so I slowed down the rate of change by dividing x by 4. I didn't even realize until now that that will also make the first value greater than 1... I'm out of math practice.
I'm not surprised I missed dividing by zero.
Audio files: 299
PostPosted: Wed Sep 17, 2008 6:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, a good optimizing compiler would optimize it out for you probably - don't know if ChucK has an optimizer though.
Underwaterbob
PostPosted: Thu Sep 18, 2008 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Macro FM synthesis:
Code:
SqrOsc s => dac; 0 => int x; while(200::ms => now){ 500+(440*Math.sin(x*3*Math.sin(x/4.0))) => s.freq; x++; }
Almost sounds like a melody sometimes.
Inventor
Audio files: 267
PostPosted: Fri Sep 19, 2008 6:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
ChucK studies Shakespeare...
Code:
// to be or not to be, that is the computation
for (int B; B < 2; B++) if (2*B | !(2*B) == true) <<<"to be">>>; else <<<"not to be">>>;
It doesn't make any sound, but optimistically, the answer is "to be" for all values of B. Hmmmm!
kijjaz
PostPosted: Tue Sep 23, 2008 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
new mini-projects:
(1) creating a drum set. each drum piece are constructed with only one line patch
(only the way to generate sound, doesn't need to trigger)
(2) creative a whole drum set with only one line patch..
ahh is this (2) possible -_-" ??
kijjaz
PostPosted: Tue Sep 23, 2008 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
easy electro set:
// bass drum (use velocity number => trig.next to trigger)
Impulse trig => LPF tone => SinOsc drive => dac; tone.set(50, 30); 1 => drive.sync;
// same family:
// clave
Impulse trig => HPF tone => SinOsc drive => dac; tone.set(2000, 100); 1 => drive.sync;
// cleaner clave
Impulse trig => BPF tone => SinOsc drive => dac; tone.set(2000, 100); 1 => drive.sync;
// tom tom (set frequency at tone.set(freq, Q)
Impulse trig => LPF tone => SinOsc drive => dac; tone.set(140, 30); 1 => drive.sync;
// cute rim-shot
Impulse trig => LPF tone => TriOsc drive => dac; tone.set(600, 3); 1 => drive.sync;
// crude rim-shot
Impulse trig => LPF tone => SawOsc drive => dac; tone.set(600, 5); 1 => drive.sync;
// GM High-Q-like sound, not nice
Impulse trig => Gain g => g => Gain freq => SinOsc drum => dac; .99 => g.gain; 100 => freq.gain;
// longer High-Q
Impulse trig => Gain g => g => Gain freq => SinOsc drum => dac; .999 => g.gain; 100 => freq.gain;
// electro bass drum, not nice
Impulse trig => Gain g => g => Gain freq => TriOsc drum => dac; .9995 => g.gain; 1 => freq.gain;
// industrial china
Impulse trig => LPF f => NRev rev => SinOsc drive => dac; f.set(6000, 2); 1 => drive.sync;
now i'm too sleepy. gonna create some more and hopefully advanced sounds tomorrow.
Inventor
Audio files: 267
PostPosted: Wed Sep 24, 2008 4:55 am    Post subject: Reply with quote  Mark this post and the followings unread
kijjaz, these drum kit one-liners look really cool but they don't run. Can you make a master file that plays them or at least make them work? The code lacks the impulse stim and the time delay. I forgot how to stim an impulse and I'm feeling lazy today, haha. I like the idea of the drum kit a lot!
kijjaz
PostPosted: Wed Sep 24, 2008 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
oh just send a number to trig.next;
for example 50 => trig.next; to make it plays.
adjusting the number is like adjusting hit velocity.
