TZFM SAW VCO
Page 1 of 22 [537 Posts]
Goto page: 1, 2, 3, ..., 20, 21, 22 Next
frijitz
Audio files: 54
PostPosted: Fri Sep 26, 2008 5:24 pm    Post subject:  TZFM SAW VCO Reply with quote  Mark this post and the followings unread
This looks somewhat promising. It's a SAW VCO with thru-zero FM. So far just a proof of principle. But quite simple and cost effective. None of that doo-dah with rectifying the CV, separately reversing the core direction, etc. Just modulate the core's input current back and forth and carefully process what comes out...
Ian
 Filesize:  1.98 KB
 Viewed:  80896 Time(s)
 Filesize:  20.52 KB
 Viewed:  80897 Time(s)
guitarfool
PostPosted: Fri Sep 26, 2008 5:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very exciting! I don't believe anybody has every done anything other than a triangle core TZVCO. Scope shot looks right with the phase reversal Very Happy
jnuaury
Audio files: 9
PostPosted: Fri Sep 26, 2008 6:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
wowzas!
when you say simple... is it a low parts count too? or just simple in implementation? im imagining a stack of 4 or so of these......
Peake
PostPosted: Fri Sep 26, 2008 7:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
If sine waves (or triangle core oscillators shaped to sine) produce FM such as the DX7 (or roughly equivalent), then would this, saw shaped to sine, sound different?
And mp3s please!
Scott Stites
Audio files: 96
PostPosted: Fri Sep 26, 2008 7:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think it would be extremely cool if it did, not that I would kick it out of bed for eating crackers if it didn't......
My Site
yusynth
PostPosted: Sat Sep 27, 2008 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting, I look forward to seeing more !
Yves
EdisonRex
Audio files: 172
PostPosted: Sat Sep 27, 2008 2:40 am    Post subject: Reply with quote  Mark this post and the followings unread
That looks quite unique. If it's simple in design, that would be encouraging too.
Hope you write more about this, Ian.
Garret: It's so retro.
usw
PostPosted: Sat Sep 27, 2008 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
what's the modulator's waveform in the scope sample ?
frijitz
Audio files: 54
PostPosted: Sat Sep 27, 2008 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
It's a sinusoid.
I'm currently working on improving the implementation before more careful characterization. Right now it has 8 opamps plus the OTA. Two of the opamps are for deriving the correct time-reversed waveform from what comes out of the core (which is an interesting signal on its own.)
Ian
bridechamber
PostPosted: Sat Sep 27, 2008 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Drooool............
I'll take ten!
Scott
neandrewthal
PostPosted: Sat Sep 27, 2008 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
bridechamber wrote:
Drooool............
I'll take ten!
Scott
That's not enough for everyone Surprised Wink
Junk Rhythm
PostPosted: Sat Sep 27, 2008 8:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Peake wrote:
And mp3s please!
Shocked Shocked Shocked Oh yes please.
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger
usw
PostPosted: Sat Sep 27, 2008 11:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
are the improvements you mention (partly) related to the way the fm input tends to clip/distort (it seems like it does, am I wrong) ?
frijitz
Audio files: 54
PostPosted: Sun Sep 28, 2008 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, thanks for pointing that out. It looks like I was overdriving something there -- probably pushing past the end of the frequency range. There are some levels that need to be looked at more closely.
Ian
bridechamber
PostPosted: Sun Sep 28, 2008 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
neandrewthal wrote:
Scott
That's not enough for everyone Surprised Wink[/quote]
10 for me, 10 for you?
neandrewthal
PostPosted: Sun Sep 28, 2008 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
bridechamber wrote:
neandrewthal wrote:
Scott
10 for me, 10 for you?[/quote]
Sure, why not Very Happy
dar303
PostPosted: Mon Sep 29, 2008 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
We are looking forward to more data and information!
Your projects are great, I learn a lot from your posts even if I don't always build the circuits!
frijitz
Audio files: 54
PostPosted: Tue Sep 30, 2008 7:38 pm    Post subject: 2 demos Reply with quote  Mark this post and the followings unread
This project is moving along bit by bit. I was stuck for a while getting the bipolar discharge switch comparators working right, but finally it seems OK. Still lots of work to do, but for now here are a couple of demos.
The first has sawtooth carrier and triangle fm modulation, in unison. Three sections: (1) no modulation, (2) modulation just slightly into the negative frequency regime and (3) deep TZ modulation.
The second has a 3/2 frequency ratio. Modulation is either by triangle or square wave. Various depths of dynamic modulation in several patterns.
Thanks for all the interest! This is beginning to look like it might fly.
Ian
unisondemo01.mp3
 Filename:  unisondemo01.mp3
 Filesize:  232.78 KB
 Downloaded:  2837 Time(s)
threetwodemo03.mp3
 Filename:  threetwodemo03.mp3
 Filesize:  709.51 KB
 Downloaded:  2906 Time(s)
urbanscallywag
PostPosted: Tue Sep 30, 2008 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow the second demo is great! Cool
guitarfool
PostPosted: Tue Sep 30, 2008 8:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wonderful! My soldering iron is quivering in anticipation Very Happy
frijitz
Audio files: 54
PostPosted: Thu Oct 02, 2008 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
This just keeps getting better and better. I was afraid it would be hard to get good tracking with the control current passing through an OTA. It took almost a whole day, but I got it working right yesterday. It runs up to over 100 kHz and tracks to within 0.2% up to 20 kHz. Better than a lot of standard VCOs out there. Wheee ...
Ian
loss1234
PostPosted: Thu Oct 02, 2008 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I CANT WAIT Till you make a pcb for this!!!
Also..i love that second sample! you are really rocking out Ian!
it feels like a good time to be making synths Smile
usw
PostPosted: Thu Oct 02, 2008 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy I'd really like to understand how this works ?
johans121
PostPosted: Thu Oct 02, 2008 7:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yummy!!!!!!
phdinfunk
PostPosted: Thu Oct 02, 2008 9:03 pm    Post subject: In
Subject description: Like Flynn
Okay, I'll buy. You and your oscs said all you freakin' need to say to get my vote. How soon do you think we can expect a PCB/project? (I'm not trying to rush you, I just want to know what to expect--I have no idea how to guess and I'm curious [Smile
I'll probably take 8 depeding on PCB cost and BOM
Peace,
JP
