today> Twyndyllyngs Chez Mosc
Synthmonger "mini"-guitar synth
Page 1 of 1 [21 Posts]
synthmonger
PostPosted: Thu Oct 09, 2008 7:44 am    Post subject: Synthmonger "mini"-guitar synth
Subject description: having troubles deciding layout...
I've been working on a guitar synth the past few days. I'm building a mini and mega version. Basically the mega version has more sub-octaves, pwm, and a vca for A/D controls.
I'm stuck on the layout. I just can't decide how I want things laid out. Ideally, I want each section (mixer/pwm/EF, etc) together but trying to lay them out symmetrically has been difficult for me. The posistion of the knobs must follow to the layout in order to fit in the case properly. Any suggestions would be greatly appreciated!
Just to let you know I'm not using 1v/oct frequency converter to control the vco's and it tracks pretty darn well. I'm sync'ing 40106 vco's that are based around my design. It's a fairly simple circuit that is a helluva lot of fun to play with!
The layout doesn't have the stompswitch or led indicator on there yet, but it'll go in the middle towards the bottom. The back will have vc inputs for each pwm, vco freq, and vcf.
 Filesize:  60.68 KB
 Viewed:  360 Time(s)
StephenGiles
PostPosted: Thu Oct 09, 2008 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds just like my cup of tea, look forward to hearing samples!
synthmonger
PostPosted: Thu Oct 09, 2008 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll post some later tonight. The ones I recorded so far were done before I built a proper tracking section, vcf, pwm or envelope follower. I'm waiting until I have the design done before I post good quality videos/samples.
StephenGiles
PostPosted: Thu Oct 09, 2008 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.4shared.com/file/21289268/ee1dd026/CClark_synth1.html
http://www.4shared.com/file/21289267/7ea2cdb7/CClark_synth2.html
Talking of the 40106, have you seen this? Also, please take a look at these, which use an interesting type of sweep generator.
http://www.4shared.com/file/39556305/8587cb8c/EHcrashpad.html
http://www.4shared.com/file/37898877/e1132137/spacefilter.html
synthmonger
PostPosted: Thu Oct 09, 2008 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Where exactly is the 40106 in those designs? All I saw were 4046's.
StephenGiles
PostPosted: Fri Oct 10, 2008 1:26 am    Post subject: Reply with quote  Mark this post and the followings unread
It's IC4 in drawing 1.
In the Crashpad circuit, while at rest the CV is set by the Stop Frequency pot. When energised, the CV shoots up to that set by the Start Frequency pot, then falls back to it's original level at a speed determined by the Sweep Time pot. I have made this work from a guitar, suitably amplified. It would be interesting to make the voltage at the wiper of the Start Frequency pot proportional to the strength of each note played, but preserving a totally independent sweep time. I think it calls for a peak follower which is sampled momentarily and applied to the Start Frequency buffer IC, but I have not had much success. It sounds simple enough in theory!
What it should achieve though is a sweep generator for a VCF, the peak of which follows the strength of each note played and has a smooth sweep, free of ripple.
synthmonger
PostPosted: Fri Oct 10, 2008 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah there it is! It looks like the two gates are setup to square up the signal to drive the 4046 and another for the EG.
I love how the EH VCF is setup. A very unique way of getting up and down sweeps.
For my sweep generator I'm just running an envelope follower through a polarity mixer.
synthmonger
PostPosted: Sun Oct 12, 2008 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I nixed the layout and have decided to build two different boxes. One for voice another for control. The voice will have the fundamental, sub-octave, and 2nd sub-octave, with ring modulation, vcf, vca and possibly an aliaser. The control box will have a couple EF's, LFO's, S&H, 2-4 photocells and maybe dual joysticks.
I will also be building one giant box that includes everything.
Here are some samples I recorded using an MT-240 on the 'accordion' setting. All raw, recorded in cool edit pro and no digital effects -other than lowering the amplification and adding a fade out. I haven't conditioned the signal yet so the tracking isn't anything to brag about. These demos give you an idea of it's interesting sonic capabilities.
I am using just the outputs of the digital ring modulation section.
StephenGiles
PostPosted: Sun Oct 12, 2008 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is an amazing sound. Many thanks.
richardc64
Audio files: 26
PostPosted: Sun Oct 12, 2008 2:09 pm    Post subject: Re: Synthmonger "mini"-guitar synth
Interesting samples.
What exactly are you using to get the vco's to track?
synthmonger
PostPosted: Sun Oct 12, 2008 7:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well actually I'm syncing the 'vcos' with an amp tied to a diode facing the input of one 40106 oscillator. I'm using another gate of the 40106 as a high frequency exponentially controlled VCO that is driving a 4066 switch. The input to the switch is connected to the input of the sync'd 40106 oscillator and the output of the switch is connected to the output of the 40106 oscillator. The switch is basically an easy peasy VCO/resistor. I'm getting -.06 to 500k resistance on +9v power. I haven't tested the resistance with different power supplies yet.
I tested the same VCO/resistor method with a number of things with 100% success (toy voice changer, BPF, LPF, aliaser, to name a few). One super-awesome-cool-fun thing to do, is controlling 4 40106 gates with one vco/resistor that each have optional manual frequency control. The best thing about the VC resistor is the sync/linear/expo control via the vco driving the switch.
You can use 1 of 2 switches (4053) to act as a vco/resistor too (i.e. voltage divider). I haven't tested out the 1 of 4 (4052) or any other electronic switches yet.
Now all I need to figure out is voltage controlled capacitance!
I'll post schematics of my guitar synth after I get everything finished. For now, here's a tri/square vco with a few different control options. Also, you'll need to add some extra circuitry to get a symmetrical triangle wave. If you leave it as is in my schematic it's a lil floppy.
EDIT: The VC resistor is in the VCO schematic. just leave off everything after the switch. Use the input and output pins on the switch as a floating vco resistor.
 Filesize:  164.35 KB
 Viewed:  624 Time(s)
snufkin
PostPosted: Mon Oct 13, 2008 2:18 am    Post subject: Reply with quote  Mark this post and the followings unread
this is amazing i look forward to more updates
StephenGiles
PostPosted: Mon Oct 13, 2008 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
How many 40106 chips will be needed, so I can put in an order?
loss1234
PostPosted: Mon Oct 13, 2008 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
what program is that .sch file from ????
synthmonger
PostPosted: Mon Oct 13, 2008 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Ray Wilson schematic builder. I accidently upped that while I was uploading the .png
I know you were looking for an easy VC resistor a while back and I think you could get a ton of use out of mine. Give it a shot! Very Happy
synthmonger
PostPosted: Mon Oct 13, 2008 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
3 for the voice 1 for the controller, so far. I'll know for sure by this coming weekend.
StephenGiles
PostPosted: Mon Oct 13, 2008 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Many thanks.
StephenGiles
PostPosted: Sat Oct 18, 2008 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
How's it going Synthmonger?
richardc64
Audio files: 26
PostPosted: Sat Oct 18, 2008 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Do I understand this correctly, 'monger? You're NOT doing any F/V conversion, but only syncing your oscillator to the input signal? If so, that's pretty slick.
synthmonger
PostPosted: Sat Oct 18, 2008 4:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep. Just syncing. I'm really surprised it works this well for how simple it is.
I really need to finish this super soon ;d
inlifeindeath
PostPosted: Fri Mar 25, 2011 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
hey synthmonger, did you ever have any success with this design?
