panel finish
Page 1 of 1 [6 Posts]
numbertalk
PostPosted: Tue Nov 18, 2008 6:55 pm    Post subject: panel finish Reply with quote  Mark this post and the followings unread
Just wondering why the black panels I get from FPE are so shiny versus the ones from Bridechamber or Synthtech? Is it possible to get that same kind of finish using FPD?
urbanscallywag
PostPosted: Tue Nov 18, 2008 10:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
FPE is anodized while Synthtech is painted.
numbertalk
PostPosted: Thu Nov 20, 2008 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info.
funkyfarm
PostPosted: Thu Nov 20, 2008 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool
Damn !
The "info" is : it's not possible to get that same kind of finish using FPD, is it ?
I've understood FPD panels to be "too" shiny, at least you seem, numbertalk, a little bit dissappointed.
cheers
numbertalk
PostPosted: Thu Nov 20, 2008 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
[quote="funkyfarm"]Cool
quote]
Indeed. I like the finish on the Bridechamber & Synthtech panels better.
clickmrmike
PostPosted: Thu Nov 20, 2008 6:29 pm    Post subject:
Subject description: !
I've gotten pretty close with rattle cans from the local big box store...I've got the color right on, but the splatter texture is hard to match without an airgun. I can get close using a combination of primer, textured paint, color coat and sealer. The texture is just a bit finer than a commercial panel. Buzz me if you want the recipe.
Of course, Synthtech is going powder coat for new panels due to the EPA rules for the two-part DuPont epoxy they use now. If a cheap HF powder coat gun, a couple of pounds of the correct powder, and a toaster oven from the thrift store works, I'll let you know. Very Happy
click!
