Delta VCF pcbs
Page 1 of 4 [95 Posts]
Goto page: 1, 2, 3, 4 Next
peng
PostPosted: Thu Nov 20, 2008 3:16 pm    Post subject: Delta VCF pcbs Reply with quote  Mark this post and the followings unread
The core is nearly the same as the original but the surrounding circuitry is different. It can sound like the original and SO much more.
Here's a link to the module page:
http://www.megaohmaudio.com/deltaVCF.html
Thanks,
p.
Here are the schematics and BOM. Tell me if there any mistakes/inconsistencies.
At the moment I am no longer selling these pcbs.
The attached is for the benefit of those who already bought/have these.
Delta VCF v2 SDIY BOM.pdf
 Filename:  Delta VCF v2 SDIY BOM.pdf
 Filesize:  7.77 KB
 Downloaded:  190 Time(s)
Delta VCF Ver2SDIY.pdf
 Filename:  Delta VCF Ver2SDIY.pdf
 Filesize:  37.17 KB
 Downloaded:  262 Time(s)
peng
PostPosted: Thu Nov 20, 2008 3:19 pm    Post subject: Delta VCF pcbs Reply with quote  Mark this post and the followings unread
This link has some additional info:
http://www.megaohmaudio.com/modules.html
fluxmonkey
PostPosted: Thu Nov 20, 2008 8:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm in for one. thx!
bbob
www.fluxmonkey.com
PostPosted: Fri Nov 21, 2008 12:46 am    Post subject: Reply with quote  Mark this post and the followings unread
hey peng,
can't see anything on your site, just the navbar to the left (IE6, WinXP), neither at home, nor at work.
peng
PostPosted: Fri Nov 21, 2008 1:20 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
hey peng,
Yes. this is a known problem. My ladyfriend who built the site hasn't figured out how to fix it yet. With Firefox and IE above 6 it should be good.
We're stumped so any suggestions are welcome.
PostPosted: Fri Nov 21, 2008 1:31 am    Post subject: Reply with quote  Mark this post and the followings unread
don't have any clue about the site.
anyways, how much will the PCB be? what is the current source like? i wanted to ask just because i have coincidently already designed a PCB myself last month, but not etched yet. it uses a simple 1V/oct current source utilizing common unmatched transistors.
andrewF
PostPosted: Fri Nov 21, 2008 1:35 am    Post subject: Reply with quote  Mark this post and the followings unread
worx for me - mozilla
nice one Peng
peng
PostPosted: Fri Nov 21, 2008 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm don't know the price yet. I'm making the pcb a little more DIY friendly and correcting some silkscreen errors.
The current source is is a typical op amp summer to the base of a matched PNP pair. The pcb is made for a discrete matched pair or 8 pin DIP (SSM2220, etc.).
There is also an op amp biasing the tied emitters, much like a VCO current source.
Input has gain so you can distort things a bit if you want. The modules I'm making only have one input but the pcb will accommodate three.
Cutoff control will go down to completely off.
FM 1 is bipolar
FM 2 is switchable between EXP or AC coupled linear modulation (if you use a three position switch, C&K7211, it could be EXP, LIN, or AC LIN).
The original synth has the resonance trimmed to just below oscillation. My modules can go past that into oscillation. When oscillating the levels jump up quite a bit (approx. double). It's kind of nasty (in a nice way). There is a trimmer to set max resonance level so if you want a faithful clone you can trim it so it won't oscillate.
The VCA circuit can be completely independent of the VCF. The circuit is based almost entirely on a Mike Simms EDN article. It uses both sides of a LM13700. A huge improvement over the standard 3080 / 13700 VCAs.
Try it out if you haven't already.
There is some normalling which can be left out...but it's one of the best things about this VCF!
VCF out -> VCA IN
VCA out -> FM 2 IN
odd warpings, pitchshift like sounds, subtle bends, sheer chaos and noise.
Lot's of fun.
Try it with want you got.
p.
PostPosted: Fri Nov 21, 2008 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
great features, peng. well done! Very Happy
it's obvious much more than a simple korg delta filter clone.
vtl5c3
PostPosted: Fri Nov 21, 2008 9:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
2 for me. I can haz, plz? Wink
johans121
PostPosted: Sat Nov 22, 2008 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll get a couple.
Don't feed me Indian, you WILL regret it!
-Jim
machine.cuisine
PostPosted: Sat Nov 22, 2008 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I would be happy to buy one PCB. Thanks.
Funky40
G2 patch files: 5
PostPosted: Sat Nov 22, 2008 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
the Demos sound good !
I take one, depending on price and time maybe two. ( January would be cool, or later )
oh, if you anyway change the boards:
please make a third CV input .
Two with inverting would be fine but one is finally allready nice .
And it would be fine to have own pads for the Inverter, this way one is free how to use the inverter
= polarised Pot, or inverting with a switch ( what i prefer and do )
But it's not that important
thanks for this offer !
janvanvolt
PostPosted: Sat Nov 22, 2008 6:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
one pcb for me as well please.
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
peng
PostPosted: Sat Nov 22, 2008 7:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is a third one. Forgot to list it here:
FM 1 bipolar (easy to use a switch if you prefer)
FM 2 with attenuator
1V/Oct input. Does not track perfectly. It's not temp compensated but the expo pair are matched. It wasn't one of the design goals to make it track perfectly. It tracks well enough for me but I wouldn't expect it to track your VCOs perfectly. I'll try to make an alternative tempco resistor footprint. That way you can experiment with temperature compensation if one wants or not worry about.
FM 1 and FM 2 expect 5V CVs, but can deal with anything within the rails.
Thanks all for the interest. I'm trying to get everything together so I can place an order next week. Won't arrive until Xmas or just after. If all goes well, then January is the likely month I can ship these out.
p.
newdendrite
PostPosted: Sat Nov 22, 2008 7:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm interested in two boards!
Thanks,
Michael
TekniK
PostPosted: Tue Nov 25, 2008 3:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi,am interested in 1 pcb
peng
PostPosted: Sun Mar 08, 2009 7:18 am    Post subject: Delta VCF pcbs Reply with quote  Mark this post and the followings unread
It has a been months since I planned to do the Delta VCF run. I was delayed (let's leave it at that!).
Here's the update.
I placed an order for ten. This is the prototype run. If it checks out OK then I'll order more. I'm estimating that there are 20 or so people who have been wanting/waiting for this pcb. I'll probably order 50 to start with unless more people express their interest.
Here is the run down followed by some attachments:
PCB is 3.5" X 5"
2 oz. copper
Lead free HASL
The traces and pads are large to withstand multiple reworkings. Silk screen has text for pots indicating pin 1 (typically connected to ground in the standard input attenuator configuration) and other useful hookup info such as name and pin function for some. Jacks and trimmers are also named.
2 pin MTA.100 header for CV normalling schemes
Double footprints for filter core caps (use 5mm Wima or the clear foil polystyrene), single turn trimmer (Bourns or Vishay (Vishay is half the price)), and power supply header (4pin MTA156 or 6pin MTA100). There is also an extra 4pin MTA156 header at a different angle for frac rack builders.
I still have to clean up the schematics and write up a builders guide. Should be done with this by the time I get the prototype batch (approx. 2 weeks).
First pic is a screen shot of the pcb (I use FreePCB which is GREAT!!).
other pics are my Fracanana version (fracanana.com will be up and going shortly), and the silver face 1/4" version (dotcom/Moog size) shows normalized signal flow (follow the arrows).
Get in touch, anyone, if interested.
Thanks,
p.
 Filesize:  140.83 KB
 Viewed:  214 Time(s)
 Filesize:  229.19 KB
 Viewed:  181 Time(s)
 Filesize:  155.17 KB
 Viewed:  178 Time(s)
mono-poly
PostPosted: Sun Mar 08, 2009 10:03 am    Post subject: Reply with quote  Mark this post and the followings unread
count me in
neandrewthal
PostPosted: Sun Mar 08, 2009 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
WOW! The frac version looks great! I thought I was going to be the first to have color matched jacks/knobs, but you beat me to it. We even have the same color scheme: blue cv in, green audio in and yellow audio out.
whomper
PostPosted: Sun Mar 08, 2009 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
1 4 me.
Erez Yaary
Home Page: http://www.yaary.com
Buy my CDs at http://www.mellowjet.de
The Bad Producer
PostPosted: Sun Mar 08, 2009 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Peng,
I'd be interested in two or so, what sort of price are you thinking for the boards?
Ta,
Bad
PS that Fracanana looks really very cool...
fluxmonkey
PostPosted: Sun Mar 08, 2009 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Two boards for me.
The frac layout looks cool... but any chance you'll also offer 1/8" frac version as well? i for one would be more likely to purchase...
b
www.fluxmonkey.com
scriptstyle
PostPosted: Sun Mar 08, 2009 10:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
i might be interested depending on funds when this happens. i will be keeping track...
PostPosted: Mon Mar 09, 2009 12:19 am    Post subject: Reply with quote  Mark this post and the followings unread
hi peng, great work. i love this one!
