Resonant Lopass Gate PCB's (New Batch 4/29/12)
Page 17 of 38 [927 Posts]
Goto page: Previous 1, 2, 3, ..., 15, 16, 17, 18, 19, ..., 36, 37, 38 Next
Sine
PostPosted: Tue Nov 18, 2008 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
wmonk wrote:
Boards arrived in the Netherlands today! WHeeyaa!
Thanks Thomas!
\o/ Yes, they arrived here too, great work Thomas !
krisp14u wrote:
Had some fun building and playing with a triple LPG this afternoon/evening
All I can say is what a sweet project to build 10 out of 10 Thomas for the board layout may you do many more
Oohh ... I have been looking for a good source for these knobs, but without a name they are hard to google Wink
Do you know anyone who sells them ?
slo
PostPosted: Tue Nov 18, 2008 7:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Boards arrived in Canada, thanks for this Thomas.
Dego
PostPosted: Wed Nov 19, 2008 12:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I got mine this monday in Sweden....
intercorni
PostPosted: Wed Nov 19, 2008 3:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Boards arrived in Germany, thanks for this Thomas.
krisp14u
PostPosted: Wed Nov 19, 2008 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.maplin.co.uk/Module.aspx?ModuleNo=1803
Maplin only have that size and the large ones I would love the size in the middle that the Modcan B modules use
Paul Darlow
www.krisp1.com
fadeddata
PostPosted: Thu Nov 20, 2008 9:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
I received the boards. Thanks Thomas!
Attached is my Modcan layout...
 Filesize:  40.75 KB
 Viewed:  335 Time(s)
djthomaswhite
PostPosted: Thu Nov 20, 2008 11:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Where is your "offset" control?
Thomas
PS. Looks nice otherwise! Great use of almost all mixer inputs!!!
Thomas
www.naturalrhythmmusic.com/diy.html
LektroiD
PostPosted: Thu Nov 20, 2008 11:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
still nothing arrived here Sad
fadeddata
PostPosted: Fri Nov 21, 2008 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Woops! Smile
Hah! Fixed.
-dustin
sduck
PostPosted: Fri Nov 21, 2008 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Great looking panel Fadedata! I'm liking modcan stuff more and more....
I think he's got the offset control labeled as Freq - in fact that's how it's labeled on one of your panels, Thomas. When I was deconstructing your 2u/1lpg panel design to suit my needs, I debated about whether to change the label to offset, and eventually did.
BananaPlug
PostPosted: Fri Nov 21, 2008 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
When you make a Modcan A panel where do you get the piece of metal and how do you do the graphics. FYI folks, the Modcan A panels are about .15" thick.
fadeddata
PostPosted: Fri Nov 21, 2008 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
sduck:
The original image didn't have either Wink I fixed it...
What should the labeling be? Offset or Frequency, I guess I don't understand how that control would be an offset from watching the videos...
BananaPlug:
I've built a few EFM modules with aluminum panels I made out of stop sign material and taping panel controls to the front (yuck). My current direction is to use Front Panel Express to get the panel with holes cut and then use my companies laser engraver to do the graphics. From the tests I've done it should come out very similar to Bruce's masking method.
-dustin
BananaPlug
PostPosted: Fri Nov 21, 2008 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, FPE for the holes and a laser for the graphics. That's what I've settled on too. Laser shop #1 didn't turn out to be practical but I'm about to try another place. Hey, can you laser other people's panels at work, for some fee?
djthomaswhite
PostPosted: Fri Nov 21, 2008 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
WARNING... WARNING... WARNING!!!
It has come to my attention that my US builder list for Mouser has INCORRECT part numbers for the pots. The module needs linear pots and somehow I listed audio-taper ones in the BOM. Take heed of this warning and make sure to use linear, particularly for the OFFSET pot. The resonance pot could be audio and not make too much difference in operation. SO SORRY guys! I guess for this one thing to slip through the crack is not too bad considering, but I hate mistakes none-the-less. I'll get the BOM corrected ASAP.
Thomas
numbertalk
PostPosted: Sun Nov 23, 2008 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you have part #s for those 16mm pc mount alpha pots for 50K & 10K in Linear taper? All the pc mount ones I found at Mouser were either Audio taper or 24mm.
fadeddata
PostPosted: Sun Nov 23, 2008 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
BananaPlug:
Currently I'm not all that interested in starting any kind of business around laser engraving panels. Sorry...
-dustin
Luka
PostPosted: Mon Nov 24, 2008 5:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
boards arrived today
thanks mr white
problemchild
melbourne australia
LektroiD
PostPosted: Thu Nov 27, 2008 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Still nothing has showed up. I'm considering selling the components I bought as a batch for anyone that hasn't yet got round to purchasing them. This includes ICs, Vactrols, and basically everything you need to complete two boards, minus resistors. I have a pair of VTL5C3 & a pair of VTL5C4's, my intention was to build both slower and faster versions of the same circuits. Preferably someone in the UK to save on postage. If anyone shows interest, I'll list out everything I have and what I want for it all.
Tasmanian Alkaloid
PostPosted: Thu Nov 27, 2008 6:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
My boards arrived in Oz, thanks Thomas.
sduck
PostPosted: Thu Dec 04, 2008 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I bought a bunch of 17mm alpha linear taper pcb mount pots that work -
10k - mouser # 31CW401F
50k - mouser # 31CW405F
The pcb leads seem a bit flimsy, so you might not want to do a panel mount using just these, but with a bracket they should be fine.
And there's also the old standby spectrol 249's but for some reason the price has gone up to 11 dollars and some change for each of these - I think I just bought the last 2 of these I'll be getting.
The Alison Project
PostPosted: Fri Dec 05, 2008 11:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
What's the degree of turn on these, I ordered the 31CA401F and 405F and they turn from 0 to approx 8, so I won't be using these ones..
The Alison Project
www.thealisonproject.com
sduck
PostPosted: Sat Dec 06, 2008 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I hadn't thought to check that. But I just did. The ones I got go from 0 to about 9. Not ideal but useable. There's probably a better option out there...
numbertalk
PostPosted: Sat Dec 06, 2008 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Will the ones from Futurlec work?
a_guy_called_tom
PostPosted: Sun Dec 07, 2008 12:28 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Just finished two boards. Great project, great documentation, great sound thanks
finished dual 292c
 Filesize:  82.21 KB
 Viewed:  12877 Time(s)
djthomaswhite
PostPosted: Sun Dec 07, 2008 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks awesome Tom! Cleam, mean and with the silver gleam!
Please post details of your power hook up... Looks like goes to Doepfer?
Thomas
Thomas
