today> Twyndyllyngs Chez Mosc
Subtle Chorus BBD
Page 1 of 1 [22 Posts]
etaoin
PostPosted: Fri Jan 09, 2009 6:49 am    Post subject: Subtle Chorus BBD Reply with quote  Mark this post and the followings unread
I'm slightly puzzled here. Finished this today but can't get my MN3007's to work in it. These are known good BBD's (they work fine in a Tonepad chorus). I have clock from the MN3101 (71.7 kHz) and the correct smaller voltage on pin 4. Still I only get clock bleed through on pin 7and nothing on pin 8. (and yes, input does get up to pin 3).
I've had BBD's not shifting signals before, but I can't remember what it was then....
Chorus BBD Board
 Filesize:  142.52 KB
 Viewed:  17705 Time(s)
http://www.casia.org/modular/
etaoin
PostPosted: Fri Jan 09, 2009 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, never mind, the same ICs work perfectly fine in the right channel, so I probably just made a mistake somewhere in the left...
[edit] incredible noob-error by the way; I reversed C16... It works fine now.
whomper
PostPosted: Mon Feb 09, 2009 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am testing my BBD boards and have some difficulties:
1. The LFO rate is fast. Even when lowering the rate via the pot, it does not go slow enough. Only when coupling the pot with CV can I get a low enough rate.
2. The DEPTH POT only works between step 2-3, the rest it does nothing. Can I have a faulty 13600?
What does 100K trimpot? I though it could change the LFO rate initial setting, but turning it does nothing.
Erez Yaary
Home Page: http://www.yaary.com
Buy my CDs at http://www.mellowjet.de
jhaible
PostPosted: Mon Feb 09, 2009 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
whomper wrote:
Wrong resistor value somewhere?
That's merely an offset pot - its effect is rather ... subtle. (pun intended)
JH.
whomper
PostPosted: Tue Feb 10, 2009 2:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I went through the resistors values (of the Option A and B in schematics 2, the LFO and summing) and they seem ok. I have also noted that my interpolating scanner has a similar problem of depth and rate (I noted a similar circuit).
I have used 100k lin pots.
I must have done in those three cases (I have 2 BBD and 1 scanner) something wrong to get a similar result out of the CV LFO.
Any inputs as to trace the LFO signal across the components? What should be the ballpark voltages at important sections with a mid point setting of rate and depth?
Erez Yaary
jhaible
PostPosted: Tue Feb 10, 2009 6:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I get ca. 2Hz in mid position of Rate.
This will vary a lot from board to board because of unmatched transistors in the expo converter. But the range of that pot is so huge that the actuall mid position rate shouldn't matter much.
To decrease overall Rate, increase C82.
This is specified as 220nF (Do you actually have 220nF in here?).
Increasing that value by factor x will drop the Rate by the x.
JH.
whomper
PostPosted: Wed Feb 11, 2009 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
JH.
Thanks for the tip, I have increased to 1uF and it eased the rate a little. I might go higher.
I have also noted that I have used BC557C for the matched pair as a substitute for the BC560C. Might this be the cause of the problem?
As for the depth, any insights as to how I can extend the depth range as currently it is only good for between pos 1-2 of the pot, 0-1 and 2-10 are producing no effect at all.
Erez Yaary
jhaible
PostPosted: Wed Feb 11, 2009 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Unlikely.
Increase R113. Try 270k.
JH.
jayjayevans
PostPosted: Tue Mar 10, 2009 2:26 pm    Post subject: beginner help Reply with quote  Mark this post and the followings unread
Hello,
I am a total beginner at this and i am troubleshooting my boards-- Dimension D version.
The bypass signal is fine but the wet signal has a pretty loud hum, a bit like a loud ground loop. I decided to check the power supply to the BBD. I am using the 15vac wall wart PSU. at the pins of the connection to the BBD i get 9.6v and -9v, not +-15v. is it not supposed to be +-15v to the BBD board? could i have blown the regulators? how can i check them? any help appreciated.
thanks in advance,
jay
jhaible
PostPosted: Tue Mar 10, 2009 2:32 pm    Post subject: Re: beginner help Reply with quote  Mark this post and the followings unread
jayjayevans wrote:
Hello,
thanks in advance,
jay
You probably need a bigger wallwart.
15V AC @ 800mA works for my prototype.
JH.
jayjayevans
PostPosted: Tue Mar 10, 2009 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi JH thanks for replying,
mine is 1000ma. do you have any other suggestions?
jay
jhaible
PostPosted: Tue Mar 10, 2009 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
jay
That should be big enough!
But your symptoms all direct at anot enough power - either a voltage too low, or a voltage breaking down due to too much current.
Of course it could be *anything*, drawing too much current, on the boards. Sad
JH.
jayjayevans
PostPosted: Tue Mar 10, 2009 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok i will start to take it apart.
jayjayevans
PostPosted: Wed Mar 11, 2009 6:51 am    Post subject: stupid me Reply with quote  Mark this post and the followings unread
oh my god i found out that i had a LM317m instead of a LM317. the label was covered by the heatsinks so i didnt check it. i cut 3 traces already trying to isolate the problem. Rolling Eyes
i will replace it and let you know. thanks again for your help
jhaible
PostPosted: Wed Mar 11, 2009 3:04 pm    Post subject: Re: stupid me Reply with quote  Mark this post and the followings unread
Isn't the 317M an SMT part?!
JH.
jayjayevans
PostPosted: Thu Mar 12, 2009 8:10 am    Post subject: Reply with quote  Mark this post and the followings unread
hello i am back! Wink
well i cut enough traces and lifted some resistors so that the power section is completely isolated. no power is going to the rest of the board, anywhere. still i have only +-10v. so what are my possibilites?
1. the PSU is fucked. it doesn't put out the current that is written on it. here it is, in case i am doing something stupid:
http://www.velleman.be/be/en/product/view/?id=365838
but what are the chances of a wall wart not working as it is written on it?
2. the diode rectifier is somehow not working right. i checked continuity and it seems to be OK at each point.
3. something else? i have replaced both regulators, so thats not it. i have moved the 470u caps around with a known good one, i dont think thats it. i checked resistor values both with a multimeter and by color code, so i guess the are probably right.
4. its supposed to be that way. Shocked
aaah its driving me crazy.
please help!
thanks
jay
jhaible
PostPosted: Thu Mar 12, 2009 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
please help!
thanks
jay
The wallwart looks good.
First step: look at the 470uF caps with a scope, and see if you have a DC voltage with saw-shaped ripple there.
JH.
jayjayevans
PostPosted: Thu Mar 12, 2009 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
ok i will have a shot at it. will a soundcard oscilloscope work? i don't have a real one.
EDIT: i googled it and i guess not.
jhaible
PostPosted: Thu Mar 12, 2009 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you have a friend with a scope?
JH.
jayjayevans
PostPosted: Thu Mar 12, 2009 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
no i dont know anyone w/ a scope. Crying or Very sad
jhaible
PostPosted: Thu Mar 12, 2009 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Then it's really hard.
I don't have experience with soundcard scopes, but I reckon they only have AC coupling. Well, in that case, you still could mesure the DC with a multimeter, and the AC ripple with that soundcard scope. But then again, the 20-something volts DC might be too much for your soundcard ...
I don't really recommend this.
JH.
jayjayevans
PostPosted: Fri Mar 13, 2009 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
i did some more research and figured out what the problem was. it was really ignorant on my part: i wired the AC leads wrong. i thought ac leads should have been on the far right and left (i told you i was a total beginner). Embarassed well at least i know now how a power supply works. anyway i might have more questions...please be patient with me.
thanks again for your help.
jay
