<on air> Modulator ESP Adventures In Sound
Solina or Onmi ensemble board?
Page 14 of 16 [394 Posts]
Goto page: Previous 1, 2, 3, ..., 12, 13, 14, 15, 16 Next
If I'd make a string chorus PCB, what kind of multi-BBD circuit would you prefer?
Solina style (also: Crumar Performer, Böhm Phasing Rotor, and others)
62%
 62%  [ 28 ]
ARP Omni style
13%
 13%  [ 6 ]
Elka Synthex 4 BBD circuit
11%
 11%  [ 5 ]
other (please name in thread)
6%
 6%  [ 3 ]
I would want neither - it's old fashioned and overused, and if I need it, there are digital FX boxes
6%
 6%  [ 3 ]
Total Votes : 45
numbertalk
PostPosted: Wed Sep 24, 2008 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I missed out on this and would love to have one as well. Actually I saw something on bridechamber just last night that this project would be available there sometime in October. That would be amazing.
krisp14u
PostPosted: Thu Sep 25, 2008 1:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I think that’s just the front panel
Paul Darlow
www.krisp1.com
numbertalk
PostPosted: Thu Sep 25, 2008 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Damn. I emailed Scott asking him about this but no response yet.
211
PostPosted: Tue Sep 30, 2008 1:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi numbertalk,
Some news from Scott ? I have some TDA waiting for a board !
numbertalk
PostPosted: Tue Sep 30, 2008 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I did. He is unfortunately only planning to carry panels.
211
PostPosted: Tue Sep 30, 2008 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Sad news.. Perhaps if more DIYers show their interest, we could expect a new batch ?
numbertalk
PostPosted: Tue Sep 30, 2008 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Unless those BBD chips are more readily available in Europe and someone is willing to do a parts kit it will be of limited good to U.S. builders unfortunately it seems.
jhaible
PostPosted: Tue Sep 30, 2008 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Triple Chorus PCBs ?
Certainly! If there are enough binding pre-orders, I'll make a re-run.
I even started a list of people who are interested.
So if you are interested, please send me an email (no PM, no forum message - an email!) expressing your interest in [number of] boards and I'll add you to that list.
JH.
numbernone
PostPosted: Tue Mar 03, 2009 6:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fired up the Solina for the first time tonight, it sounds like it will be a killer when its dialed in. However mine is bellowing out a warbly high pitch from the main out. I only have it strung up for testing, so I will begin poking around now, but any pointers on where I might look are appreciated.
I should add that it is running from my 15v supply rather than onboard power.
jhaible
PostPosted: Wed Mar 04, 2009 1:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you substitute any opamp type?
JH.
numbernone
PostPosted: Wed Mar 04, 2009 6:23 am    Post subject: Reply with quote  Mark this post and the followings unread
All opamps are as specified on the silkscreen. A single 71, pair 0f 72s, and a half dozen 1458s, I had initially used the pair of switches illustrated on the wiring .pdf, then switched to a rotary. No difference. The EQ is working but seems to have no effect on this high pitch oscillation.
jhaible
PostPosted: Wed Mar 04, 2009 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Where in the signal chain is that oscillation generated?
JH.
numbernone
PostPosted: Wed Mar 04, 2009 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
To be completely honest I have no idea. To my ears it seems late in the path, since the EQ has no noticeable effect. I am not exactly sure where to look. I will try swapping out some amps tonite if I have the time. I would also add that my amazing arsenal of test equipment includes my ears and a nice Fluke meter.
As it stands, at power up, at the main out (the only one I have wired thus far, will examine the individual ones soon) a high pitch is emitted. The pitch wobbles a bit, and is omnipresent, regardless of input. Inputted signal passes thru the chorus and whooshes like crazy (sounds great!)
Thanks for the assitance Juergen, I imagine its a small error someplace. I wanna get this one straightened out before I give in to my desire to wire up the Compact A and Tau.
jhaible
PostPosted: Wed Mar 04, 2009 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, you have to go thru the signal path from opamp output to opamp output, and measure the signal there, without an input signal applied.
A scope would be good. Alternatively, a probe with an audio amp, and your ears. But a scope would be *really* good.
JH.
numbernone
PostPosted: Wed Mar 04, 2009 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds great, I will trace the path tonight. What are the optimal output levels I should be hoping to find?
jhaible
PostPosted: Wed Mar 04, 2009 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Zero - with no input signal applied!
Just search along the signal path where the oscillation comes from.
JH.
numbernone
PostPosted: Wed Mar 04, 2009 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
HEADSLAP!!!
Serious thanks for suffering the fools like me Juergen.
I now remember I cut up some headphones ages ago and made a signal tracer from them. Time to hunt them down, and I will report back with what I find.
update:
OK high pitch oscillation is coming from pin 7 of U7-8-9B. All the surrounding component values appear to be correct, as is continuity from pad to pad. However the funny thing is probing the individual outs gives me the squeal at only 1 and 2, NO signal at all at output 3.
Swapped a few 1458s, all to the same effect, But now we are getting someplace! Cant wait to kill that bugg cuz this thing sounds amazing
numbernone
PostPosted: Thu Mar 05, 2009 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
So I spent some quality time probing around the Solina, to no immediate gains. I see that U7/8 are spec'ed on the schematic as TL082 and 072 on the silkscreen. Amazingly I had no spare 082s (havent made a parts order in a long time) to test against. Could this have any effect?
jhaible
PostPosted: Thu Mar 05, 2009 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
That squeal obviously comes from the modulation circuit then. I suspect it's from U7B, as U8B and U9B come "after" U7B.
Hart to tell what could cause something like that, though.
(TL082 vs. TL072 makes no difference here.)
JH.
jhaible
PostPosted: Sat Mar 07, 2009 7:30 am    Post subject: 2nd batch, maybe Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/topic-32720.html
JH.
numbernone
PostPosted: Sat Mar 07, 2009 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Man oh man I think I have lost 99% of my mind trying to get this thing straightened out. Output 3 was merely a cold joint, thats fine now. In hopes that a similar situation was jinxing the modulators, I reflowed every joint in that area. Unfortunately no such luck!
ANYONE with a clue as what might be making the horrid banshee squeal in the modulators, feel free to pipe in. I have tried several batches of 072s to no effect. I might just rebuild the entire modulator section, but it seems like overkill at the moment, tomorrow maybe not!
jhaible
PostPosted: Sat Mar 07, 2009 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
And yet a similar thing is likely to be the culprit. Something you'll be surprised, once you've found it, and what neither you, nor me, from afar, would have predicted ...
JH.
numbertalk
PostPosted: Sun Mar 15, 2009 6:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi JH,
Could you offer any advice on calibrating the 2 speed trimmers for the Solina sound (especially if we don't have a Solina to compare to) - either by ear and/or roughly how far up (i.e. both 1/2 way up, etc...)? Sounds like they don't have a wide range but I saw where someone mentioned here that it takes careful setting of these 2 trimmers along with the waveform trimmer to get the Solina sound. (I see on one of the audio samples on your site you give a tip on how to get the waveform set correctly).
jhaible
PostPosted: Mon Mar 16, 2009 12:06 am    Post subject: Reply with quote  Mark this post and the followings unread
numbertalk wrote:
Hi JH,
Start with 1/2 and fine adjust by ear.
JH.
numbertalk
PostPosted: Mon Mar 16, 2009 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jürgen!
jhaible wrote:
numbertalk wrote:
Hi JH,
JH.
