 Forum index » DIY Hardware and Software » Supercollider
Changing parameters of stored patterns.
Post new topic   Reply to topic Moderators: v-un-v
Page 1 of 1 [8 Posts]
Ataxian
PostPosted: Sun Mar 08, 2009 12:03 pm    Post subject: Changing parameters of stored patterns. Reply with quote  Mark this post and the followings unread
Say I have the following PDef:
Code:
   Pdef
      \Pattern1,
      Pbind
         \instrument, "bass",
         \midinote, 40,
         \dur, Pseq([0.75, 0.25, 0.25, 0.25, 0.5], inf),      //Infinite Repeat
         \legato, Pseq([0.9, 0.3, 0.3, 0.3, 0.3], 1),
         \amp, 0.5,
         \detune, 0.005
Why can't I change the \midinote using this command:
Code:
Pdef(\Pattern1).set(\midinote, 15);
Is there a preferred method for storing a pattern, referring to it by a unique name and changing its parameters?
Thank you.
dewdrop_world
PostPosted: Sun Mar 08, 2009 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pattern proxies.
http://supercollider.svn.sourceforge.net/viewvc/supercollider/trunk/build/Help/Streams-Patterns-Events/A%20Practical%20Guide/PG_Cookbook02_Manipulating_Patterns.html
James
Ataxian
PostPosted: Mon Mar 09, 2009 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks James, I have read the article and have the following code working perfectly but it only brings another question to mind that I haven't been able to solve.
Here is the working code:
Code:
   SynthDef("bass",
      arg freq = 440, gate = 1, amp = 0.5, slideTime = 0.17, ffreq = 1100, width = 0.15,
      detune = 1.005, preamp = 4;
      var sig,
      env = Env.adsr(0.01, 0.3, 0.4, 0.1);
      freq = Lag.kr(freq, slideTime);
      sig = Mix(VarSaw.ar([freq, freq * detune], 0, width, preamp)).distort * amp
      * EnvGen.kr(env, gate, doneAction: 2);
      sig = LPF.ar(sig, ffreq);
      Out.ar(0, sig ! 2)
   }).load(s);
   //Pdefn(\Pattern1).set(\instrument, \midinote, \dur, \legato, \amp, \detune);
   // Set Pattern1 environment first with initial values
   Pdefn(\Pattern1).set(\midinote, 40);
   // Need to refer to Pattern1 environment in some way so create a variable = envir
   e = Pdefn(\Pattern1).envir;
   // Define Pattern1
   Pdefn //(key,Pattern)
      \Pattern1,
         arg e;
         Pbind
            \midinote, e.midinote,
            \dur, Pseq([1.0,1.0,1.0,1.0], inf),      //Infinite Repeat
            \amp, 0.5,
            \detune, 0.005
   ).asStream;
   p = Pseq([Pdefn(\Pattern1)], inf).play;
// Change the midinote via the control environment
Pdefn(\Pattern1).set(\midinote, 60);
The question is this:
How can I set the midinote via the environment so it affects the next note played (next note in the sequence) rather than having to wait for the sequence to finish before the midinote value is updated.
A more on the fly approach would be most welcome.
Thank you.
dewdrop_world
PostPosted: Mon Mar 09, 2009 7:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's JITLib stuff, which I don't use extensively. Julian Rohrhuber is the main author of JITLib, but he doesn't hang around here, only on the mailing list.
My approach to this problem is outlined here. It's a heavier weight structure than pattern proxies, but it also takes on more responsibilities.
That document is a bit old... since then, I made another syntax possible to change the parameter:
Code:
BP(\cmaj).degree = Pbrown(0, 7, 2, inf);
James
Ataxian
PostPosted: Mon Mar 09, 2009 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Link doesn't work...
Using ~out and JITLib doesn't allow for .set commands only replacement of the entire Pattern.
I could do this by resending the entire Pdefn each time one arg in the Pdefn is changed, would this be recommended?
dewdrop_world
PostPosted: Tue Mar 10, 2009 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
The link is working for me...??
http://www.dewdrop-world.net/sc3/tutorials/forums.html?id=6
JITLib is more than NodeProxy (~out = ...). Pdef, Pdefn are all part of JITLib. I only rarely use them so I am not the best person to ask.
What I do know about Pdef etc. is... Pdefn is not meant for "event patterns" (Pbind and cousins). Pdefn should be only for "value patterns."
Code:
// these are value patterns - they generate values to use in Pbind
Pdefn(\degree, Pwhite(0, 7, inf));
Pdefn(\dur, Pwrand(#[0.25, 0.5, 0.75], #[3, 2, 1].normalizeSum, inf));
Pdef(\whitekeys, Pbind(
   \degree, Pdefn(\degree),
   \dur, Pdefn(\dur)
)).play;
Then, to change the degrees:
Code:
Pdefn(\degree, Pseries(2, Prand(#[-1, 1], inf), inf).fold(-4, 11));
I don't know where this .set is coming from. Seems more complicated than necessary.
Anyway, if you have more questions about this, ask Julian on the mailing list. I don't know all the nuances.
James
Ataxian
PostPosted: Tue Mar 10, 2009 6:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
After posting to the mailing list Julian came up with the following (in case anyone reading this was interested):
for me it seems to change immediately.
I needed to use store rather than load.
if you write:
\midinote, Pfunc { e.midinote },
this should work out.
As for the website, I'm getting the following:
This is your custom 404 "Not found" Error page. This page is displayed whenever a file that a web browser requests is not found on your website.
If you would like to change this page, edit the file "404.html" in your "www" dir.
Important!!!!
If you use Microsoft Internet Explorer, please read this important article about "404" pages. It will save you a lot of frustration!
Force IE5 to display your 404 and not its own
You may also wish to read this article:
click here for Microsoft Knowledge Base article
dewdrop_world
PostPosted: Wed Mar 11, 2009 6:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know what's going on with your web browser -- I'm afraid I can't troubleshoot it because I can't reproduce it. The link works perfectly for me (attached).
Try going to my main site - http://www.dewdrop-world.net - and then navigating to SuperCollider > Intermediate Tutorials (link is in the page body, toward the top) > chucklib intro (menu bar at left).
Question Question
James
 Filesize:  88.64 KB
 Viewed:  802 Time(s)
