Jackout
Posted: Thu Mar 12, 2009 8:26 am Post subject:
Using the G2 multitimbrally in Cubase |
I'm wondering if anyone can tell me how I can use two patches at once in the G2 - on two tracks in Cubase SX? The multitimbral bit in the manual is only a paragraph long. I just want to be able to play and record MIDI for more than one patch in Cubase.
Cheers! |
doctorno
Joined: Apr 10, 2007 Posts: 46 Location: Erkelenz, Germany
G2 patch files: 8
Posted: Thu Mar 12, 2009 9:02 am Post subject:
| Use the performance mode and load the patches that you want to use into slots A, B, C and D. Then create 4 midi tracks in Cubase - one for midi channel 1 (slot A), one for midi channel 2 (slot B), one for midi channel 3 (lot C) and one for midi channel 4 (slot D). I hope this helps. |
Jackout
Posted: Thu Mar 12, 2009 10:01 am Post subject:
| ok, I choose "new performance" from the menu and the editor initializes. Then I choose a couple of .pch patches I like and load them into slot A and B respectively. I notice the perf light is no longer blue when I load these patches in. In Cubase it's only playing the patch in slot A across all midi tracks. Any ideas? |
Joined: Apr 03, 2004 Posts: 24584 Location: The Netherlands, Enschede
Audio files: 309
Posted: Thu Mar 12, 2009 11:07 am Post subject:
From the file menu you can select load into slot, that will leave performance mode on. Alternatively you can set back performance mode manually by shift or control clicking the perf button in the editor. _________________ Jan
doctorno
G2 patch files: 8
Posted: Thu Mar 12, 2009 12:37 pm Post subject:
| When you are in performance mode, you can use the editor to load the patches to the slots the way BlueHell has described or, if you have got the keyboard version and do not currently work with the editor, hold down the A keys, select a patch and then release the A key, do the same with the B key and so on. In the end save the performance. |
Jackout
Posted: Fri Mar 13, 2009 6:58 am Post subject:
| Erm... I've got two patches loaded into the slots but they're both playing at the same time. I need some way to tell each patch to transmit on a specific midi channel (I think) but I'm not sure if I should be doing this in Cubase or the editor? |
doctorno
G2 patch files: 8
Posted: Fri Mar 13, 2009 7:04 am Post subject:
| By default, slot A is always adressed by the MIDI channel 1; slot B by channel 2 a.s.o. So if you have not changed these default settings of the G2, I guess that you have not chosen the right MIDI channels in Cubase. I have not worked with Cubase for years and do not have a copy of it, but there will certainly be a way to select the MIDI channel of a track in Cubase. A MIDI track might be set to "ALL" channels by default - if you choose 1 instead, only slot A of the G2 will be addressed. |
Jackout
Posted: Fri Mar 13, 2009 7:52 am Post subject:
| I'll have to fiddle around a bit more I think. I can control the patch in slot A fine and it transmits to midi channel 1. Slot B is not transmitting though on channel 2 and I've checked volumes and midi messages are getting through to Cubase when I strike a key - just no sound at the mo. |
dasz
Joined: Oct 16, 2004 Posts: 1644 Location: victoria, canada
Audio files: 29
G2 patch files: 56
BobTheDog
Jackout
Posted: Sun Mar 15, 2009 8:24 am Post subject:
Cracked it guys! Thanks. I opened to slot A as BlueHell described but also had to change the midi channels in the G2 synth settings which were a bit higgledy piggledy.  |
3phase
G2 patch files: 141
Posted: Mon Mar 16, 2009 1:33 pm Post subject:
and dont forget...
pressing shift/perf while beeing in patchmode creates a new performance with the actual slot assignings... a must usefull fuction
probably reduntand info...but who knows..if somebody dont knows and nobody tells? i never read the manual of synths ...maybe one or two years later... and i dont buy synths that dont work out of the box for me...
and i dont buy machine wher you cant ereas the factory programs  |
