Variable Slope Filter / Phaser
Page 1 of 8 [181 Posts]
Goto page: 1, 2, 3, ..., 6, 7, 8 Next
interested?
yes
88%
 88%  [ 38 ]
no
11%
 11%  [ 5 ]
Total Votes : 43
jhaible
PostPosted: Sun Mar 15, 2009 11:30 am    Post subject: Variable Slope Filter / Phaser
Subject description: Interested?
A mean little module from my JH-3 Modular.
6 filter poles, realzed with OTAs and combined FET / Bipolar buffer stages.
Variable Slope function for 6-pole VC LPF.
Voltage controlled Pole Spread for Phaser mode.
Zeroes switcahbel in pairs, i.e. a lot of combinations of all pass and low pass stages. Positive and negative feedback. Positive and negative wet/dry mix. Rather special overdrive behaviour (Dirty!), and (IMO) pleasant way of breaking into oscillation.
JH.
 Filesize:  649.56 KB
 Viewed:  1222 Time(s)
jhaible
PostPosted: Sun Mar 15, 2009 11:53 am    Post subject: Demo Reply with quote  Mark this post and the followings unread
Arpeggio from OB-8, with delay and reverb.
First few seconds dry - then playing with phaser.
JH.
variable_slope_phaser_arpegg.mp3
 Filename:  variable_slope_phaser_arpegg.mp3
 Filesize:  13.75 MB
 Downloaded:  6212 Time(s)
b-funk
PostPosted: Sun Mar 15, 2009 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jürgen!
You are crazy!!! This sounds fantastic (and also reminds me that I still have a broken OB-8 standing around collecting dust Embarassed )...
Go for it.
Best wishes,
Tobias.
jhaible
PostPosted: Sun Mar 15, 2009 2:18 pm    Post subject: another demo Reply with quote  Mark this post and the followings unread
This is something I recorded a few years ago. I don't remember all the details. But it was a Split on the OB-8, bass sound on left hand and organ sound on right hand, and the whole thing was processed with the Variable Slope Phaser / Filter to get that "pulsating" sound.
(Lots of delay and reverb as well, obviously.)
JH.
oct_06_zwischenstand_edit.mp3
 Filename:  oct_06_zwischenstand_edit.mp3
 Filesize:  8.94 MB
 Downloaded:  4053 Time(s)
Luka
PostPosted: Mon Mar 16, 2009 12:34 am    Post subject: Reply with quote  Mark this post and the followings unread
hell yes
sounds awesome
problemchild
melbourne australia
Funky40
G2 patch files: 5
PostPosted: Mon Mar 16, 2009 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
The Demo sounds very good, but to be honest:
filters and phasers are the least i need for now,
and i might be not the only one.
what i like to see first:
__ very good VC ADSR
__ BBD
__ Vocoder
the accent is on the term "first".
mono-poly
PostPosted: Mon Mar 16, 2009 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I wanna join.
krisp14u
PostPosted: Mon Mar 16, 2009 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hook line and sinker I will be taking 2 me thinks Very Happy
Paul Darlow
www.krisp1.com
norman phay
PostPosted: Mon Mar 16, 2009 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, that sounds great. I emailed you to put me down for 2 boards, thanks.
vtl5c3
PostPosted: Mon Mar 16, 2009 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds good Juergen! Is this related to the variable slope VCF in Electronotes? IIRC, that one was also 6 poles, but it did not have feedback.
Romeo
numbertalk
PostPosted: Mon Mar 16, 2009 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be in for a board!
jhaible
PostPosted: Mon Mar 16, 2009 11:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Romeo
It's a combination of two ideas I found in EN.
One was a variable slope VCF, the other was a combination of LPF and Phaser. (But this has been so long ago, I don't remember the details.)
JH.
Sound
PostPosted: Tue Mar 17, 2009 1:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Intrerested in one or two. Very Happy
pdub
PostPosted: Wed Mar 18, 2009 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very cool! I am in for one or two.
Thanks, Charles.
Electronicant
PostPosted: Wed Mar 18, 2009 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome sound.
But is yet another phaser, so why not use either the Tau phaser or the Schulte phaser as the phaser part in this project? Smile
jhaible
PostPosted: Wed Mar 18, 2009 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Electronicant wrote:
Awesome sound.
Totally different architecture. Smile
JH.
jhaible
PostPosted: Sun Mar 22, 2009 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
This one is fun to layout!
Finished the audio part.
Lots of space left on the board.
I will include a Noise + Sample & Hold Circuit, so you get these clocked random modulations without any outboard modules. Also, an on-board power supply, so this can become a stmp box as well as a modular synth module.
JH.
Now playing: Kitaro, Silk Road
 Filesize:  85.86 KB
 Viewed:  55293 Time(s)
jhaible
PostPosted: Sat Mar 28, 2009 5:12 am    Post subject: More Features! Reply with quote  Mark this post and the followings unread
Just wanted to tell you my further plans for this.
The Variable Slope Filter / Phaser will get a very special on-board LFO that is derived from my JH-4 synthesizer.
Voltage controlled Rate and Depth, of course.
But there is is more:
You will be able to crossfade between waveforms with a potentiometer, or with another control voltage.
Starting from ccw end, the waveforms will be:
Triangle, fading into Sine, fading into Square, fading into Sample&Hold, fading into audio rate self-modulation.
Let me explain that choice:
Triangle fading into Sine means rounding the edges.
Square fading into S&H means rhythmic modulation with more or less randmness thrown in.
S&H fading into audio self modulation means mixing and fading two different flavors of madness. Especially with high resonance.
JH.
Funky40
G2 patch files: 5
PostPosted: Sat Mar 28, 2009 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
sounds very good,
please incloude a LFO Out too !!
Your LFOs are anyway great, but this one seems to be very special
TekniK
PostPosted: Sat Mar 28, 2009 7:28 am    Post subject: Re: More Features! Reply with quote  Mark this post and the followings unread
JH.
sexy
numbertalk
PostPosted: Sat Mar 28, 2009 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Keeps sounding better and better!
vtl5c3
PostPosted: Sat Mar 28, 2009 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
That's great news about the LFO. Are you using some sort of interpolating scanner for the waveform xfading?
jhaible
PostPosted: Sat Mar 28, 2009 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes. But yet another variant that allows different height, width and slope for each window, and uses only 2 transustors plus an OTA per channel. Smile
JH.
bugfight
PostPosted: Sat Mar 28, 2009 9:07 am    Post subject: Reply with quote  Mark this post and the followings unread
sheesh, you're too productive lately, i can't keep up!
2 for my infinite queue...
dig the c.s. lewis quotes, btw. one of my fave writers since i was a kid...
jhaible
PostPosted: Sun Mar 29, 2009 3:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I read about every book of his adult fiction and his theological work, in my twenties. Now I re-discoverd him, currently reading his collected correspondence. And I finally started reading his spiritual teacher, George MacDonald. Very heavy stuff, in beautiful Victorian English, challenging and comforting at the same time.
JH.
