today> Twyndyllyngs reschedule: Sunday, Dec 6 Chez Mosc
download upgrades
Page 1 of 1 [16 Posts]
PierreV
PostPosted: Thu Apr 30, 2009 12:37 am    Post subject: download upgrades
Subject description: downloading on an off-line pc
L.S. My misic pc is not connected to the internet but "stand alone"
How can I download my upgrades ?
Thanks in advance for your reaction.
Pierre
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Apr 30, 2009 1:16 am    Post subject: Reply with quote  Mark this post and the followings unread
well...you need the computer you used to write this message, download whatever you need on it, copy the file/files on a removable support (USB key, HD) connect it to the "misic pc" and copy the files over there...and welcome to electro-music.com Wink
PierreV
PostPosted: Thu Apr 30, 2009 1:41 am    Post subject: Reply with quote  Mark this post and the followings unread
That is a nice answer but........
The first question that appears when trying to up grade is :" indicate the midi channel you want to etc..... ". since this pc has no midi connection I am a little bit lost on how to procede.
Pierre
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Apr 30, 2009 3:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Pierre
ignore that question and go on.... and see what happens.... nothing is going to explode... Cool
PierreV
PostPosted: Thu Apr 30, 2009 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello Seraph, I love your reply but hey , if the road just ends , just go on driving and see what happens ?
It will not explode , I know , but I will fall of the clip ?
I will try to-night and let you kow what happened.
Pierre
PierreV
PostPosted: Thu Apr 30, 2009 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
So the next instruction the pc gives is :" connect your keyboard to the pc ".
No, it did n't explode . But what to do now ?
Pierre
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Apr 30, 2009 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
doesn't it allow you to go on without a keyboard Question
PierreV
PostPosted: Thu Apr 30, 2009 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
No, it does'nt , that's the problem.
Pierre
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Apr 30, 2009 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
don't you have a friend with a keyboard Wink Question
PierreV
PostPosted: Thu Apr 30, 2009 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I could connect my DX7 but I hardly believe this would solve the problem.
Pierre
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Apr 30, 2009 1:12 pm    Post subject: Re: download upgrades
btw, what upgrades are you talking about Question
PierreV
PostPosted: Fri May 01, 2009 12:53 am    Post subject: Reply with quote  Mark this post and the followings unread
From the manual I had the impression that I had to upgrade the OS from 3.0 to 3.04.
Meanwhile I found out that it is 3.04 already.
Thanks for your response.
Pierre
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri May 01, 2009 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
so, you are saying you asked for help to upgrade something you already had installed Question
Shocked mad, short circuit head banging monitor sigh
BobTheDog
Audio files: 32
PostPosted: Fri May 01, 2009 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
That ones easy, just do nothing and it will work.
PierreV
PostPosted: Fri May 01, 2009 4:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Totally true , from the manual it looked like I had OS 3.00, however it appered to be already 3.04. So nothing had to be done.
So much for my knowledge on this subject but , hey , I am a musician and not a software spicialist.
Although many times it looks like you need to be both to play an instrument nowedays.
Pierre
PostPosted: Fri May 01, 2009 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah well, you've spent more icons on it than text anyway Wink
