Gakken sx-150
Page 2 of 3 [59 Posts]
Kenneth
PostPosted: Fri Apr 17, 2009 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried the F-V converter some more, it seems the amplitude has got more to do with it than the pich. I fed it with a fixed frequency sinus (440 Hz), nothing happen until I raised the volume, the higer I turned it up the higer the pich of the GAKKEN becamed, I could use the volume knob of my source to tune the GAKKEN. I tried a diffrent frequency for the sinus, same thing happend but it was responding diffrently to the volume. The higer the pitch of the sinus, the easier the GAKKEN responds.
It does not even have to be a clear wave, I also fed it with white noise and the same reaction occured.
An easy sequencer would be like use any sound for source and vary the output volume. (sequncer that controls a VCA that controls the volume of the source sound).
Kenneth
PostPosted: Fri Apr 17, 2009 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
When talking about sequencers:
Here
Specially here
I'm trying to learn some basics first, then I will start to collect parts for building one of those ("SQ-150").
Here is a demo from the tube of the two together
(the SX he's using has got a square wave mod so it is not only the sequencer, and of course the effects, but it's great anyway)
reve
PostPosted: Fri Apr 17, 2009 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think that's a product of you you feeding it a sine wave. As I understand it, most F-V converters are looking for square wave input. By giving it a a sine wave at different amplitudes, it sees a different "frequency" between the edges of the wave. For example, you can count the dashes (frequency) in the waveforms below. Depending on the amplitude, the Sine could be two, four or six. But the square will always be six.
Code:
Sine
Square
The sequencer you're looking at works by using a microcontroller to feed the SX-150 control voltages and gate signals, rather than leveraging the F-V converter. Seems like a cool little project.
Kenneth
PostPosted: Fri Apr 17, 2009 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, thank's, I try a square next time Smile
Yea, I know, it is CV/gate and yes, wery cool and intresting project for a begginer like me Very Happy
Kenneth
PostPosted: Sat Apr 18, 2009 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I think I got it now, the F-V input is digital, you feed it with a series of on/off like this: 10101010.... = a serial digital stream and depending on the BAUD rate you get diffrent voltages out! Smile
Kenneth
PostPosted: Sun Apr 19, 2009 3:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I just made my first mod to my GAKKEN, a very simple one, no soldering or anything complicated, just a simple wire job Smile
What I did was to put a jack to the resonace switch so I can connect a pot to it that gives me control over the amount Smile Smile Smile
I have to get a better pot though, this one is far too large = 470K Ohms so it only gives me about 5-10 degrees of action but for this test it works.
EDIT: this leads me to a futher qestion, this is probably complicated but what do I need to control the amount of resonance using let's say a LFO?
Or, how is a automated potentiometer constructed, ("VCR"? (voltage controled resistor))
A; the underside of the resonance switch
B; a mono jack
C; end of wires of the jack
D; wires wired to the legs of the switch
E; Ready to rock!
 Filesize:  58.34 KB
 Viewed:  372 Time(s)
NerveJam
PostPosted: Tue Apr 28, 2009 3:41 am    Post subject: Reply with quote  Mark this post and the followings unread
akrearke wrote:
Thanks for being so helpful. i have dabbled in electronic for many years, and still learn something new everyday! I want to gives you guys a heads up, on this I am currently building a Touch Keyboard, much like the Buchla 218, I found the documentation of the japanese clone on an EM forum, and began working on a 25 note version with the VC portamento included. The only thing left is the enclosure. I will keeps everyone up to date for who ever is interested. I am thinking about trying to sell them. I would also like those interested to keep in mind that all the boards, of which there are 8, are all hand made. also i have completed the layout for a 25 note vesrion of the Touch Keyboard and Programmer found in the Synapse article. if there is anyone interested in that
Cheers to everyone!
Hi.
I'm about to buy an SX-150, but I REALLY want a "proper" keyboard for it. (Might even build the Gakken into another case, and add bits..)
Does anyone have a keyboard circuit specifically for a Gakken SX-150?
(I could work out a keyboard circuit for myself, but hey, why re-invent the wheel?.. I did consider using VL-1 keyboard hardware..)
Cheers..
https://synteknik.com
Kenneth
PostPosted: Tue Apr 28, 2009 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm planning to do this:
Take any keyboard from a toy that has got a one, like these (BTW, dig the sequencer =) Normaly they got batterys so there is voltage on board, take that and put a switch for it under each of the keys so the key toggles voltage on/off and followed by that a pot that you can use to set the pitch for the key. A sequence of resistors or a restor for each key makes it simpler but you won't get perfect harmony from that, pots is the way to go (not wery cheap but there are some brands less than a dollar a piece, for 2 octaves this makes around $20, the switches you can get for free or really cheap from used or old elecrtonics, like telephone keyboards and such).
Now, if you connect a line with no current to the GAKKEN, + to the top of the stylus and - to ground and then put a current on = switch, any voltage between 0> and +5 then the GAKKEN will automaticly generate a trig signal!! The voltage is CV strait!
So there is no need to make modifications to the synth, you can connect and deconnect the keyboard at any time. Currently I have a bicycle rear ligth LED blinker, GAKKEN ground to battery connector and the stylus to one of the legs of the diode. I blinks in about 160 BPM and the voltage is pretty low = low feqency, with a bit of pich envelope, short AD and low filter setting I got a 808 kick/tom drum comming out from the synth Smile
PostPosted: Tue Apr 28, 2009 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
howabout this one?;
http://blog.makezine.com/archive/2008/12/how_to_sx150_button_mod.html
ACHTUNG!
Kenneth
PostPosted: Wed Apr 29, 2009 1:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a vid of my LED blinker trigger
http://www.youtube.com/watch?v=quhclEU7Khc
The blinker makes a bit of noise Sad
The signal is both trig and pitch.
So now I'm considering taking the printer port, it has got 8 separate lines, put a pot on each of them and I can play 8 diffrent notes just by outputting one bit at the time, a 8 step sequencer with variable gate time.
BTW; the easiest way to do this is to turn your GAKKEN upside down, put the tip of the stylus to where the square from the LFO goes into the LFO switch, use speed knob for tempo Smile
Problem is that it is 5V = high pitch, it will go ping ping ping... if you don't put a resistor or a pot on the line, a 1 meg pot gives full range.
NerveJam
PostPosted: Tue May 12, 2009 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd be more interested in adding a keyboard.
I have a couple of dead VL-1s kicking about.. (and an Excel-O-tone..)
How wide is the bit between the speaker and the rhs of the stylus track?
Kenneth
PostPosted: Tue May 12, 2009 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Around 10 cm, but you can also ommit the speaker, then you got near 15 cm.
But... this is related to the LED blinker, it shows how you can use a keyboard with 1v/oct, just connect to gnd and the tip of the stylus and go ahead, that's it! (hopefully your keyboard cuts the connection when no key is pressed, else you have to solve the trig somehowe, like use the keyboard gate out to turn the CV on/off)
Someone said the GAKKEN does not use 1v/oct but I think it does, maybe the confusion comes from the fact that the topmost position of the track does not give the higest pitch possible, you can still add full pitch envelop on top of it. I think it is about 1/3 missing, it can also go lower than on the track but not much...
BTW: I have built myself a GAKKENIZER, will post a pic soon...
Kenneth
PostPosted: Tue May 12, 2009 9:49 am    Post subject: Reply with quote  Mark this post and the followings unread
It is a astable using two 470u caps (from old telephones), two 546B transistors (old light organ), one 20k slider pot for PW (telephone bell volume) one 10k pot (to small, will change) for speed (bend arm of a broken guitar hero guitar), one red and one yellow LED (computer on and HD LED's). The output I take from both sides of the PW slider and I got a switch (computer turbo on/off) to choose any, the switch also breaks the connection in the middle so I get a retrig when switching, the switch is followed by a 200k pot (old VCR) that controls the end pitch a bit. "All" this is mounted on an upside down ice cream bucket, wires on the inside. To put the components there I have small metal pipes normally used for nylon fishing tackles, but I pinch one or two wires into one end and make a small hole in the buckets plastic and then push the other open end of the pipe so it goes out on the top side, two next to each other for diodes and caps, three for transistors, no soldering, you can switch to a diffrent cap (or whatever) in seconds. Power is a battery box 4*1.5 = 6V (bottom half of a telephone call logger) sitting next to the bucket Razz
(No, I don't have any diode protection resistors (470 or so), it is only 6V so it is not a problem I think)
OK, is this on the lower end of synth DIY or what? Cool Cool Cool
The sound?, Well it alters hi/low pitch, if I take the output from the side where the slider is then I get short high and long low, then I switch and get short low and long high instead, about 1-2 keys difference but it depends on the PW slider, in the middle it is only one pitch. The PW also controls the length of the two halfs (it also changes the speed, in the middle it runs fast, slower near ends and at the most ends of the slider it stops, all is on one side. The speed is also dependent on if I take the output from A or B side depending on the total resistance is changing, wery unstable =)
Well, I took my LED blinker showed in a previous post and used it to feed more power to one half of the circut but in pulses, then I also used the internal LFO + pitch envelop of the GAKKEN, then I used that sound together with chords of my electone and it sounded like Beach boys singing choruses??!! (No, I don't think a reproduction is possible =)
GAKKENIZER 1
 Filesize:  36.23 KB
 Viewed:  19801 Time(s)
Kenneth
PostPosted: Wed May 13, 2009 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Daylight so now I can take better pictures than last night, here is another view of my GAKKENIZER where you can see the constrction better:
 Filesize:  53.82 KB
 Viewed:  19765 Time(s)
reve
PostPosted: Mon Sep 21, 2009 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I finally got around to building a MIDI interface for my Gakken. I used the 2a revision of Motohiko Takeda's AVR-based design (http://beatnic.jp/SX-150/MIDI-IF2.html), and it's well worth the $5 in parts it'll cost you to make.
You could probably duplicate the analog portion of the circuit to scale v/oct down to gakken levels. Or you could cherry pick resistors and wire them directly to the keys, but the MIDI solution really is the fastest.
loss1234
PostPosted: Thu Oct 15, 2009 5:45 am    Post subject: vco waveform? Reply with quote  Mark this post and the followings unread
can anyone tell me what kind of wave the vco of this beast puts out?
is it simply a square? or a triangle? or a saw?
thanks so much
PostPosted: Thu Oct 15, 2009 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
It spits out a sawtooth. It's actually quite fat sounding, but pretty limited (on/off resonance anyone?)- which is a shame. Good value for the money though! Smile
ACHTUNG!
reve
PostPosted: Sat Oct 17, 2009 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Well... it's easy enough to swap that that switch out with a pot to give you a variable degree of resonance. Smile I'm not sayin' it's not a bit of work, but if you're interested in getting discernible notes outta the thing, you're gonna be doin' more work on it anyhow.
Stabilizing the expo converter to get more than a couple octaves out without retuning == a bit harder. :/
reve
PostPosted: Thu Mar 11, 2010 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
... and I now finally got around to properly mouting, powering, and housing it. I just tapped the battery outputs of the Gakken and ran that into a five volt regulator on the converter PCB. Power shares a cable with the control output; everything runs over a 1/8" TRS cable.
I love it so much that I would strongly reiterate my suggestion that all Gakken owners build the darn interface. Smile
p2b
PostPosted: Sat Mar 20, 2010 6:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey reve,
I've had my Gakken 150 for a bit and really want to make the mod for midi (I'd actually be happy to just run it through usb). I've seen a few solutions the most detailed being:
http://mrbook.org/blog/2008/11/22/controlling-a-gakken-sx-150-synth-with-arduino/
and with actual midi port:
http://mrbook.org/blog/2009/06/27/sx-150-synth-mod-schematics/
Is this the mod you did? If not do you have any instructions I could follow?
I'm pretty much a noob and had some problems. Basically every little problem led me to more areas I didn't understand...(the circuit and Processing...damn even getting the midi network on my mac working is mysterious)
I really want to understand as much as possible not just build this by following directions. Mainly so I can learn something.
reve
PostPosted: Sun Mar 21, 2010 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I used this dude's directions: http://beatnic.jp/SX-150/MIDI-IF2.html. Way better than the adruino based solutions, IMO. No tying up expensive adruino boards, no processing sketches, no need to solder anything onto your gakken board and no external power suppiles. I just plug midi in and go. Plus it adds a glide control for portamento sweetness. Smile
You'll notice it's in Japanese. Personally, I can't read Japanese but that didn't stop me. The schematic is here:
http://beatnic.jp/SX150-stuff/img/MIDI-IF2a-schem.gif
The unlabeled pot is glide. The schematic's a little vague on what happens on the gakken end... For the output, I just attached another wire to the same terminal the stylus is tied down to. The output jack's ground also has to go to the gakken's ground.
The source code (and hex file) is here:
http://beatnic.jp/SX150-stuff/img/SX150MIDI2.zip
I built it on a breadboard to see if it would work. Surprisingly, it did. I then moved it over to stripboard and put it in a permanent enclosure.
You'll need a AVR microcontroller (specifically an ATTINY2313). If you're not interested in buying a programmer from sparkfun or whomever , I'd be happy to program a chip and send it to you for say $5. (Though I would have to order the chip; I don't have 'em sitting around.)
That said, you should really think about just buying a programmer. I got a USB one for like $13. Between the Gakken MIDI converter and 4bitsynth (http://code.google.com/p/4bitsynth/ -- check it!!) I got my money's worth right there.
p2b
PostPosted: Sun Mar 21, 2010 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the quick reply. I'm going to see if I can do it though, it's a bit beyond my experience. I most likely will have to ask for your help along the way...We'll see.
Thanks again
alienmeatsack
PostPosted: Fri Apr 09, 2010 9:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I read about the Gakken SX-150 here, and thought I needed to see what the fuss was about.
Mine arrived last night. The packaging is large and confusing, the japanese does that to my brane. Very Happy
Anyway, so my first impression... Man this thing is cheap cheap cheap. My first goal is to remove it from the case, replace the cheap pots and switches, and then do some bends.
I do dig the sound, and for the money, I don't know of anything that can affect inputed sound like this.
So, why is this thing such a big deal? To me it appears to be a really cheap synth. (Cardboard back, seriously?)
I'm not bashing, I just expected something else after reading so many people talk about it.
My Circuit Bending Site (Coming Soon)
My Circuit Bending Blog
reve
PostPosted: Fri Apr 09, 2010 9:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
alienmeatsack wrote:
I I needed to see what the fuss was about.... Man this thing is cheap cheap cheap.
You answered your own question. Smile The gakken's got two things going for it:
1. It's not an analog synth. It's a magazine that -- for that issue -- came with an analog synth to help you understand what synthesizers are. That right there has got fantastic geek appeal. Like when they put a digital camera in a box of cereal, a bunch of people are going to go out and buy it and hack the camera. Not because it's the most awesome camera in the world but because... it was in a box of cereal. Same thing here.
2. Once you have a mechanism in place to get reliable pitches out of it, it's actually a pretty cool sounding and useful synth. Not really useful until then, though. Then again, that's why my WSG sits unused on a shelf. Smile
alienmeatsack
PostPosted: Mon Apr 12, 2010 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I do that a lot... It's kind of me thinking outloud. Very Happy I do like your cereal box analogy. Only problem is, the cool magazine is Japanese so it's like I got the cereal but can't eat it, so I just get the prize. Very Happy
I have plans to do a few things to mine... First off I want to put it into a decent case, replace the speaker and pots and switches.
Then, I am going to try and add the VC out, put a pot on the resonance switch, do the envelope trigger and LFO to filter cut off mod, add a slider pot to go along with the strip, and a keyboard mod.
I actually have a perfect case for it, the empty body of my failed Lil Tikes Keyboard bend. It has 8 working keys I can use for set pitches. Im hoping to run a primary pot to then control these so I can ptich them all up or down.
Going to be a fun little mod I think. Smile
