today> Twyndyllyngs Chez Mosc
 Forum index » Instruments and Equipment » Cwejman Sound
S1MK2 and MIDI
Page 1 of 1 [5 Posts]
Sound
PostPosted: Fri May 01, 2009 2:12 pm    Post subject: S1MK2 and MIDI Reply with quote  Mark this post and the followings unread
Hello,
After repair my s1mk2 I have problems with the midi.
I mean that it holds the first note , and i need to reset from the keyboard.
I remember that it happens to me before, but now seems much more. Its not possible to play anything.
I updated to the 5.0 firmware correctly without results.
Any of you have or had problems with the MIDI in his S1mk2? Is there a solution?
Thanks.
Sound
PostPosted: Fri May 15, 2009 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I reinstalled again the firmware 5.0 and seems better but still sometimes seems that do not receive the "note off " order.
What a great synthesizer.
If any of you could contact me with experience regarding this issue i will be very grateful.
Maybe any of you have older firmware releases and they are working correctly?
Thanks.
Sound
PostPosted: Sat May 16, 2009 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Seems that was the cable! was 4m long, maybe was this. I have made a new cable according this article http://www.harmony-central.com/MIDI/midi-cable.txt and it is working.
Regards.
PostPosted: Sat May 16, 2009 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah yes, that makes sense, a lot of MIDI cables are not up to specs indeed.
Sound
PostPosted: Sat Feb 27, 2010 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
Seems that the cable improved the issue but still I have problems.
Seems that the S1 not always receives the note-off message.
For example if from the DAW in a 4/4 time signature I draw four quarter note(crotchet), the S1 will hold the first note when finished the four beats.
I have to solve this drawing eighth notes (quaver), so in this way the S1 receives the note-off message.
Its the same if I play fast in the keyboard, sometimes a note is hold.
So my question is: is this an issue of the S1 or only happens in mine. Do you have experimented this?
If not I will open my S1 again. Please let me know.
