 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
MacBook Pro, 10.4.11, Java 1.5.0_19, MIDISport 2x2 No Go
Page 1 of 1 [3 Posts]
toneburst
PostPosted: Wed Jul 01, 2009 1:42 pm    Post subject: MacBook Pro, 10.4.11, Java 1.5.0_19, MIDISport 2x2 No Go Reply with quote  Mark this post and the followings unread
Can't get Nomad to work on my machine.
Tried 3 different Java Midi SPIs.
mmj:
I can select my interface, but no communication with Modular
osxmidispi:
I can select the MIDI interface and ports, but again, no communication with Modular.
In both the above cases, I get no MIDI activity lights on the interface.
Mandolane:
I get an 'invalid MIDI plugin' error
The Clavia editor works fine.
I really wanted Nomad to work- I never managed to get it to work in my old iBook G3, so I brought this MacBook Pro home from work specially, to see if it would work on that. I hope there's some way of getting it to work.
Anyone any advice on what, if anything, I can try next?
a|x
toneburst
PostPosted: Fri Jul 03, 2009 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
It was user error.
I forgot to hit the button to connect the synth- assumed the application would connect to the synth automagically, as soon as I had set the MIDI ports etc.
Seems to be working now, sorry to have wasted your time guys,
a|x
mercu80
PostPosted: Thu Sep 24, 2009 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
hi, i have the same problem: micro modular+midisport 2x2+powerbook 10.4.11
can't see either the micro or the midisport in the nomad...
no connection at all..
anyone has suggestions?
