Clock synching problems (of a different kind)
Page 1 of 1 [10 Posts]
AngusHastie
PostPosted: Wed Nov 24, 2004 7:20 pm    Post subject: Clock synching problems (of a different kind) Reply with quote  Mark this post and the followings unread
In the attached performance, I have a sequenced line going on in slot A at about 60bpm that starts when you press a key and runs for as long as you hold down the key. Tempo controlled by ClkGen set to Master. In slot C, there is a factory patch for a bass sound that I want to bring in later and use with the arpeggiator function - will come it at the same bpm because I've set the ClkGen module in A to "Master".
However, despite being the same bpm, the two patches can still be out of synch in terms of where they fall on the beat. I suppose this is because the ClkGen in A is patched to be manually reset by the Keyboard gate, whereas the arpeggiator function is based on some clock that just keeps ticking away!! However, I do need to be able to start the sequence by pressing a key rather than by just firing up the patch.
Has anyone come up with a solution to this problem - I assume it must be quite a common problem...? Obviously, the problem is more pronounced if you're using a slower arpeggiator rate that 1/16 notes.
Cheers, Angus
Bit of an animal.prf2
 Filename:  Bit of an animal.prf2
 Filesize:  7.78 KB
 Downloaded:  1480 Time(s)
egw
G2 patch files: 8
PostPosted: Thu Nov 25, 2004 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I've experienced problems similar to this with all different devices.
Some devices can be manually synced with a key or button press.
This is necessary any time you want to sync up more than one arpeggiator or sequencer. Unfortunately, the G2 arpeggiator doesn't seem to have this capability. I believe it does respond to song position pointer, but then you have to be using something that can send SPP.
One solution is to program your own arpeggiator patch on the G2, or a sequencer-like patch that does something similar.
AngusHastie
PostPosted: Fri Nov 26, 2004 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
So basically, the arpeggiator is not much use at all if you require any sort of synching Confused
Is there a way of gating the manual Clock reset so that it only lets a reset signal through at the same time as a clock pulse so that the reset is synched to the nearest beat? Question
Alternatively, what are the principles underlying the arpeggiator and is there an easy, economical way to emulate the same effect by building it into a patch?
Cheers, Angus
PostPosted: Fri Nov 26, 2004 7:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure you can do that.
Rob has posted some examples in the past. It might help to have a look at the logic workshop for the NM Classic : http://www.clavia.se/nordmodular/Modularzone/LogicIntro.html
Or the last paragraph in http://www.xs4all.nl/~rhordijk/G2Pages/HandlingMusicalEventsInLogicalWays.htm , Also by Rob.
There should be some patches posted on this forum as well illustrating synchronization,.
Jan.
AngusHastie
PostPosted: Fri Nov 26, 2004 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice one Jan. I'll check it out. Think S&H might be the answer.
And hopefully the arpeggiator runs in synch with the master clock when you first load up the patch so that any manual resets that are gated through an S&H module to clock impulses will stay in time.
By the way, don't suppose you have an answer to my other issue I posted - can't seem to record sequences by connecting the keyboard note and gate outputs to the NoteSeq Rec and Trig inputs. Sometimes it recognises the keyboard pitch, but it never advances a step with each key press.
Thanks again, Angus Very Happy
PostPosted: Fri Nov 26, 2004 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Indeed I don't have an answer. I did see your question & know that it can be made work but I never tried it myself.
Jan.
3phase
G2 patch files: 141
PostPosted: Sun Nov 28, 2004 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
This should work better..i ve no G2 here to check..
In general its beter to use pulses to reset devices and never use the reset input of the clock generator when you want to be in sync with other slots or extaernal gear.
Sven
Bit of an 2.prf2
 Filename:  Bit of an 2.prf2
 Filesize:  7.9 KB
 Downloaded:  1775 Time(s)
3phase
G2 patch files: 141
PostPosted: Sun Nov 28, 2004 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry..This one should work better...its better to dont reset the clockgenerator with the keygate...it should run in sync with the system clock without being disturbed...
and i found it usefull to have the the active state as a resetsource..But that mostly helps when you patch while things are running because ayou will have a resetpuls after recompilation than....
And an edit... The sequencer is now reseting on the syncpuls and on the gate pulse... If you dont want that just remove the one you dont like and get rid of the mixermodule...
The main thing is to dont use the reset input of the clockgenerator
Bit of an 2.2.prf2
 Filename:  Bit of an 2.2.prf2
 Filesize:  7.9 KB
 Downloaded:  1703 Time(s)
AngusHastie
PostPosted: Mon Nov 29, 2004 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
3Phase - I checked out your patch and it had some quirks that sometimes made it reset in strange places!
Actually, on Jan's recommendation, I just stuck an S&H module in the line for the manual reset so that keyboard gate manual clock resets are synched with 1/16 note clock pulses and it seems to work perfectly. Also used the same signal to reset the clock divider that triggers the OscPerc module (which I am using to send to outputs 3/4 for a metronome for our drummer) to avoid triggering the metronome on off beats.
32 note harmonised sequence + metronome with manual reset synched to nearest 1/16 note clock pulse.
 Filesize:  7.81 KB
 Downloaded:  1445 Time(s)
PostPosted: Mon Nov 29, 2004 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually it was Rob's recomendation :-)
Jan.
