 Forum index » News... » Gear News
Multimode MIDI controlled audio signal switcher
Page 1 of 1 [4 Posts]
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Nov 05, 2003 8:50 am    Post subject: Multimode MIDI controlled audio signal switcher Reply with quote  Mark this post and the followings unread
http://www.advancetubetech.com/eng/midiloop.shtml
MIDILOOP is a MIDI-controlled audio** signal switcher, for use with preamplifiers, pedal effects, etc.... MIDILOOP puts your MIDI-less audio equipment under control, allows bypass and audio signal path changes, thus maximizing your rig's flexibility.
MIDILOOP can be used to enable or disable an audio loop (your favourite pedal effect can be bypassed or enabled in your signal path), or can be used as a MIDI A/B switcher, to switch between two different amplifiers, for example.
MIDILOOP's own audio circuitry works completely in passive mode, with relays and resistors only, this ensures that the sound always stays unaffected from outer factors and free from unwanted colorations.
MIDILOOP features a SOFT function, which can be set on or off for each memory location, which uses a 70/100 milliseconds crossfade between the signals to create a smooth, clickless switching.
Ground lift switches: To eliminate unwanted noises, two different ground lift switches are provided: a DIGITAL GND LIFT switch cuts the ground connection between the digital circuits, power supply and the external box, while the AUDIO GND LIFT switch removes the ground connection between OUT A and the external box.
MIDILOOP can be controlled with any device capable of sending MIDI program change commands, such as foot controllers, sequencers, multieffects, keyboards.
There are 128 memory locations available, MIDI IN and MIDI THRU ports, and thanks to the 7 pins MIDI connector, phantom power can be used to power the unit.
and it's an Italian product (like Ferrari Very Happy )
PostPosted: Wed Nov 05, 2003 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
HEY! Brilliant! And it comes in red too?
Audio files: 235
PostPosted: Wed Nov 05, 2003 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
This is a very useful product, I could use two of them right now...
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Nov 05, 2003 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
it does not look red to me
maybe it's available in Ferrari Red color too Very Happy
