today> Twyndyllyngs - canceled because of back pain - sorry Chez Mosc
JH Varilogic problem
Page 1 of 1 [5 Posts]
AnalogCustom
PostPosted: Thu Sep 03, 2009 12:02 am    Post subject: JH Varilogic problem Reply with quote  Mark this post and the followings unread
Hello:
Transistors in red circle, very hot.
If input A = High and B = Low, both LEDs are ON.
Equally If input A = Low and B = High, both LEDs are ON.
What will be the problem?
The model used is:
2N4401 (NPN)
2N4403 (PNP)
Thank you.
Marco.
 Filesize:  102.28 KB
 Viewed:  429 Time(s)
jhaible
PostPosted: Thu Sep 03, 2009 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Wrong pinout?
JH.
AnalogCustom
PostPosted: Thu Sep 03, 2009 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
Wrong pinout?
JH.
Hello:
Pinout is correct.
I attached a new file
Thanks.
Marco
 Filesize:  103.11 KB
 Viewed:  394 Time(s)
jhaible
PostPosted: Thu Sep 03, 2009 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Ha, I have an idea. The transistor whose base is switched to GND will go into zener mode when its BE junction is reverse-biased!
Funny I never noticed this in all these years in my JH-3 synth. Maybe a current limit from the on-board regulators prevented heating.
Cure: Put a 1N4148 diode in series with each emitter of these two transistors.
JH.
AnalogCustom
PostPosted: Thu Sep 03, 2009 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
Hello. Thank Very much!! I noticed of overheating for the smell.
I attached a new scheme with diodes.
Now works correctly.
Thanks again for your help.
Marco.
 Filesize:  98.11 KB
 Viewed:  395 Time(s)
