LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Mon Nov 02, 2009 10:45 am Post subject:
Modular cabinet Subject description: Which wood etc.. |
I'm planning on building a cabinet to fit 5U MOTM modules, 16U wide x 4 modules high. I'm wondering which is the best wood, where to buy in the UK, best ways of fixing modules in place, etc. Basically everything I need to know before starting the project (I'm no carpenter either)... Also, I'd like to hear your opinions on Varnish / Stain / French polish etc. _________________ LektroiD |
RF
Audio files: 28
bf
Posted: Tue Nov 03, 2009 5:54 pm Post subject:
I also used oak, and standard rack rails mounted horizontally to mount the modules (although that was a bit finicky due to the rails I used).
I just used tung oil as a finish with no stain. |
peng
Posted: Tue Nov 03, 2009 9:41 pm Post subject:
| bf wrote: | I also used oak, and standard rack rails mounted horizontally to mount the modules (although that was a bit finicky due to the rails I used).
That's a beauty! Great job.
p. |
Joined: Jan 07, 2009 Posts: 1226 Location: Scottish Borders
Audio files: 161
richardc64
Audio files: 26
Posted: Fri Nov 06, 2009 3:28 pm Post subject:
| RF wrote: | | For the next two I used aluminum 'angle' stock and used self tapping screws. |
Did you pre-drill a bunch of evenly spaced pilot holes or did you drill as holes were needed? If the latter, how did you prevent any shards of aluminum from an upper level from landing on boards on a lower level?
I favor wood strips, but knowing how well the Lunetta case worked out, maybe I'll try aluminum angles on my next case, whenever that might be.
Thanks. _________________ Revenge is a dish best served with a fork... to the eye |
RF
Audio files: 28
Posted: Sun Nov 08, 2009 8:09 pm Post subject:
| richardc64 wrote: |
Thanks. |
Although evenly spaced holes would be wonderful....my homebrew panels have not been that precise I drill them as I go. I use a vacuum after drilling - and to this point shards in the electronics has not been an issue.
The wood will be easier to adjust if I move panels around - fill the previous holes with wood bits and glue, and drill another hole...
bruce _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
