Appendage Parts Order Feedback
Page 5 of 5 [112 Posts]
Goto page: Previous 1, 2, 3, 4, 5
PostPosted: Sat Jan 16, 2010 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Julian
there is a lot going on, this looks like it is going to have many more applications then were immediately apparent.
Thanks for the nice compliment and be sure to check all of Scott's videos that exploit all those applications Wink Many to be viewed on Youtube. He worked so hard to put those together and they are a great resource. Cool
Bill
GraeT
PostPosted: Mon Jan 18, 2010 2:22 am    Post subject:   Reply with quote  Mark this post and the followings unread
I received my replacement PCB today , all safe and sound.
Very happy with Bill's excellent service and attention.
Very Happy Very Happy
numbernone
PostPosted: Tue Feb 02, 2010 10:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Obviously I did not order the kit, however the 2n poly cap is proving to be quite elusive. Digikey is sold out and noone else seems to stock anything similar.
Any advice?
adambee7
PostPosted: Tue Feb 02, 2010 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I found 2nf polys at mouser. Link below.
http://gb.mouser.com/Passive-Components/Capacitors/Film-Capacitors/Polyester-Film-Capacitors/_/N-5g7w?P=1z0x7vw
I hope this helps. Very Happy Very Happy
hadal-drop
PostPosted: Thu Feb 11, 2010 9:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
would be interested in another run of appendage parts kits!!!!
pushing it I know. just putting it out there Laughing
oldmanfury
PostPosted: Sun Mar 14, 2010 4:51 pm    Post subject: Built! Reply with quote  Mark this post and the followings unread
Managed to finish up my appendage this afternoon. Went through the cal procedures, and all looked good, but when I brought it inside and hooked it to a rack full of modules, the gate is constantly lit now, and the output sits high until I press on the ribbon, then it dips to a normal value. It's kind of like inverted behavior. I tried adjusting VR1 again, and got it to turn the gate off when I press the ribbon, which is really odd. I'll probably have to re-cal it from scratch with the power supply that I intend to use instead of the one in the garage?
Anyway - here's a pic.
-gerald
 Filesize:  333.25 KB
 Viewed:  274 Time(s)
oldmanfury
PostPosted: Mon Mar 15, 2010 5:07 pm    Post subject: oops! Reply with quote  Mark this post and the followings unread
Ah... it's a good thing that I have a horrid commute on which to ponder circuit issues. Turns out that the problem with the "gate always on" I was having was because the appendage wasn't fully plugged in. It's up and running! Too freekin' cool!
Something useful - an error in the manual? Pg 178 step 2, should (I believe) read
2. Ensure that the Gate Mode Switch (SW102) is in the “SAMPLE” position
That, and the before mentioned issues with trimpots fitting (esp. with the terminal strip), and that's all I found... amazingly little for a complex build with a 216 page manual!
-gerald
PostPosted: Mon Mar 15, 2010 6:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Gerald
Wow, OK great news there. I just started to think on this when suddenly I see that you answered your own question. The thing that blew me a away was the fact that the calibration went off well and then things went wonky on you when you got "connected". Sorry for the late reply BTW. Glad you got it up and running and controlling your synthesizer Cool
Thanks for the heads up on the manual and thanks for the feedback on the trimmer spacing. I will have that fixed for the next batch of boards.
The documentation was really rung out for sure. I constructed a PC board using the documentation and tried to catch as many things as I could during this time. Scott and Andy Sharp did also and we felt that we nailed most of the "gotchas" !! Oh yes, that is QUITE the bible of Appendage building. lol ....
Wonderful piece of literature thanks to Scott and his wonderful writing abilities!
EDIT:
OK, I took a look at the documentation to what what context the step you pointed out was in:
2. Ensure that the Gate Mode Switch (SW102) is in the “RIBBON” position
I believe that the original above is correct as here is why. This section is calibrating the external SAMPLE input so the GATE mode is set such that pressure on the ribbon allows the external sample voltage to be presented to TP1 for alignment.
Chat more and GREAT work BTW !
Bill
oldmanfury
PostPosted: Sun Mar 21, 2010 8:23 pm    Post subject: appendage video Reply with quote  Mark this post and the followings unread
I managed to make an ok video of the appendage in action.
http://www.youtube.com/watch?v=ATK2MxrIWlo
Short but sweet.
llumen
PostPosted: Mon Aug 16, 2010 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I would also appreciate another run of the appendage
superlewing
PostPosted: Tue Sep 14, 2010 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I too would very much appreciate another run
Captain Biscuits
PostPosted: Tue Oct 26, 2010 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Count me in too please - I'd love to add this to my growing list of pending projects - looks heaps of fun Smile
