steampump
G2 patch files: 14
Posted: Mon Jan 03, 2005 4:17 pm Post subject:
Clkgen reset |
My question is howto reset the Clkgen when the G2 Engine is set as slave. Midi timeclock starts and stop from a master keyboard. It only works when the patch is saved when sequence is at start position. But when i stop in live situation it is just continiuing from this position when i restart. But my sirius synth restart at first bar. So i'm no more synchron in time. A sample of my problem is in this thread.
http://electro-music.com/forum/topic-4562.html
Has anybody an idea. _________________ Artworks Music Computer |
Joined: Apr 03, 2004 Posts: 24544 Location: The Netherlands, Enschede
Audio files: 299
Posted: Mon Jan 03, 2005 6:25 pm Post subject:
I moved this thread from the experimental patches area to here, as I thought it would have a better chance of being picked up by others this way.
Jan. |
egw
Joined: Feb 01, 2003 Posts: 1569 Location: Asheville NC
G2 patch files: 8
Posted: Mon Jan 03, 2005 6:35 pm Post subject:
I don't think there's a simple way to do it, since the patches don't have access to the midi start and stop commands.
I usually end up setting one of the front panel buttons to do a manual resync. It resets the sequencers, clock dividers or whatever.
Useful also for syncing to someone else if we're not midi-connected. |
steampump
G2 patch files: 14
Posted: Tue Jan 04, 2005 7:32 am Post subject:
Good idea to change the place |
I just love the frontpanel of my G2 Engine......
Any other suggestion ? _________________ Artworks Music Computer |
egw
G2 patch files: 8
Posted: Tue Jan 04, 2005 7:42 am Post subject:
Isn't it great?
It's the best control surface I've seen, because
1. the knobs can be assigned to anything, including combinations via morph
2. the knobs are already in the right position when you pull up a patch
3. you can assign your own labels to them
4. the paging scheme gives you quick access to lots of knobs, laid out in way you can decide yourself
5. there are also buttons for momentary or on/off functions
I tend to set the first row of knobs to be the things I will most likely want to control in real time. |
egw
G2 patch files: 8
Posted: Tue Jan 04, 2005 7:44 am Post subject:
Oh sorry, you said you have an engine.
Look what you're missing!
Get yourself a Behringer BCR2000.
It's the next best thing, and not too expensive. |
3phase
G2 patch files: 141
steampump
G2 patch files: 14
ian-s
Audio files: 42
G2 patch files: 626
Posted: Tue Jan 04, 2005 11:42 am Post subject:
A gate in OR mode will display the state of a logic signal on it's LED.
You only need one input connected. |
steampump
G2 patch files: 14
Posted: Tue Jan 04, 2005 12:00 pm Post subject:
Just for egw,
Thanks i have a Remote 25 merged with a Elka MK55 to control the Engine. My problem was, or is still "how seq module are they really working" It is still a bit foggy.
English is only my third language after german and french. So sometime the manual is not completely clear for me. _________________ Artworks Music Computer |
egw
G2 patch files: 8
Posted: Tue Jan 04, 2005 12:33 pm Post subject:
| That's ok the manual isn't always completely clear for English speakers either! And some things you only learn by playing around with it for a while. |
Joined: Jan 31, 2003 Posts: 18272 Location: Durham, NC
Audio files: 232
Posted: Tue Jan 04, 2005 1:40 pm Post subject:
| egw wrote: | | That's ok the manual isn't always completely clear for English speakers either! And some things you only learn by playing around with it for a while. |
Be sure you are using the new 1.2 manual which is avaliable from Clavia's web site here http://www.clavia.com/products/manuals.htm
This manual is much improved over the 1.0 manual which was shipped with the first G2s. Also, don't overlook the online help files. Right click on a module and select HELP. There are lots of goodies hidden in there, including clever tricks and suggestions. _________________ --Howard
my music and other stuff |
