TekniK
Posted: Mon Mar 08, 2010 2:34 pm Post subject:
Buchla 'Timbre' [Easel/259] |
If U remember fron this Topic:
http://electro-music.com/forum/viewtopic.php?highlight=buchla+adaptations&t=36554
Concerning this page:
http://users.ece.gatech.edu/~lanterma/buchla/boards/mea_timbre/
I made a DiY friendly Single Sided PCB redraw with easy readable wiring diagram.
A hell of a work,Not tested,Its Maxed over-checked ,but i cannot exclude an error.
Oh yeah BTW,this is a full fixed version with all modifications done as
explained by Lanterman on his site.
EnjoY!
83.49 KB |
| Viewed: |
1543 Time(s) |
 Download (listen) |
| Filename: |
Buchla Timbre.pdf |
839.07 KB |
| Downloaded: |
1350 Time(s) |
Sebo
forbin
Joined: Jan 29, 2009 Posts: 120 Location: Fremantle, Australia
Posted: Mon Mar 08, 2010 5:52 pm Post subject:
| Excellent! Thanks very much for posting the layout! I was very tempted to have a go at a layout for this myself but another couple got in the way (i will post those over the next couple of days) -- having said that i really don't need a another board project... never mind i will make an exception in just this case... again... |
Luka
adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
Posted: Tue Mar 09, 2010 3:10 am Post subject:
Thanks man. Been waiting for something like this for ages.  |
The Bad Producer
Joined: Mar 08, 2009 Posts: 282 Location: The Manhole
Posted: Tue Mar 09, 2010 4:37 am Post subject:
This is great Teknik, thanks! Just wondering, this is different to the circuit on Mark Verbos' Simple Answer site? or is it the same but with different chips?
http://www.simple-answer.com/DIY.html
I have just scored some 2N3958's for that, and I was going to try it out later in the year, just need some CA3160's anyone know where to get them?
Anyway, this looks easier, as there are no difficult parts to find, so maybe I'll try this first!
Charlie
edit: ah, I see it is the circuit from the Easel... _________________ http://loudestwarning.tumblr.com/ |
parasat
The Bad Producer
synthi
Posted: Tue Mar 09, 2010 7:33 pm Post subject:
Great!! Thanks teknik! |
davemoog
Posted: Tue Mar 09, 2010 10:53 pm Post subject:
| re: CA3160 from Electronic Goldmine. Bought these from them for my 259 clone - good price and delivery. Chips worked fine. |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Fri Mar 12, 2010 2:04 am Post subject:
great work teknik!
when are you gonna do the vco?
TekniK
Posted: Fri Mar 12, 2010 5:46 am Post subject:
| mono-poly wrote: | great work teknik!
Yeah,i regret that i din't buyed your 259 kit... |
parasat
Posted: Fri Mar 12, 2010 9:35 am Post subject:
Thanks Teknik-just added it to my build list.
(And thanks to Dr. Lanterman and obviously to Mr. Buchla!) |
abovenyquist
Posted: Sat Apr 03, 2010 10:50 pm Post subject:
Nice work! |
| I just ran across this on Matrixsynth. Fantastic work! I'm really happy to see people taking this and running with it. |
frenchyinmunich
Posted: Tue May 11, 2010 4:15 am Post subject:
Buchla "Timbre" [Easel/259] |
Hello,
Did someone already did it or not?
Should I be the first cobaye ... |
ChrisCoady
Posted: Mon May 24, 2010 7:47 pm Post subject:
| has anyone made a BOM or a panel for this circuit? |
forbin
Posted: Tue May 25, 2010 1:29 am Post subject:
| Found a few missing tracks off the PCB... I almost have it going so I will post the final fixes tomorrow afternoon in one go! |
emdot_ambient
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
Posted: Tue May 25, 2010 9:36 am Post subject:
| Cool, can't wait to hear/see how this comes out! |
forbin
forbin
Posted: Tue May 25, 2010 9:47 pm Post subject:
Oh an i forgot! had some grief getting some of the resistor values. And ended up doing the following:
75K - 68K & 6.8K in series
49.9K -- two 100K in parallel
The existing 75K and 1.5M in parallel give you 72K -- this can be more easily achieved with a 180K and a 120K in parallel.
The existing 49.9K and 390K in parallel give you 43K -- this can be more easily achieved with 470K and 47K in parallel. |
TekniK
Posted: Wed May 26, 2010 1:19 am Post subject:
| Forbin,many thanks for the debug,i start the fixes right now and uploud the update asap |
TekniK
Posted: Wed May 26, 2010 3:14 am Post subject:
I fixed the pcb layout,no jumpres where added, one jumper has moved to another trace (place) and 1 resistor is moved to.
The PDF in the first post is Updated: the pcb layout and Components implementation are fixed ,the wiring picture is unchanged note so this means it still has the errors in it but that doesn't matter. |
forbin
forbin
TekniK
Posted: Thu May 27, 2010 3:40 am Post subject:
ooo,i recognice those waves,looks ok  |
