today> Twyndyllyngs Chez Mosc
how to calculate Cutoff Freq of passive HPF
Page 1 of 1 [15 Posts]
PostPosted: Wed Apr 21, 2010 4:07 am    Post subject:  how to calculate Cutoff Freq of passive HPF
Subject description: need help with maths again...
hi all,
again i need some help/clarification with the maths:
f = 1/(2*pi*R*C)
so C = 1/(2*pi*R*f)
correct?
if i wanted a 1kHz filter using a 100k resistor i would have to calculate the following:
C(n) = 1/(2*pi*100000 Ohm*1000 Hz) = 1.59e-9n = 1.6n
correct? i just wanted to make shure i got the decimals right Wink
PostPosted: Wed Apr 21, 2010 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Fonik, I've got it down as f*R not R*f.
Dunno if that will influence your output?
the app screenshot is electronic toolbox;
http://www.electro-music.com/forum/topic-41036.html
 Filesize:  38.08 KB
 Viewed:  6049 Time(s)
ACHTUNG!
Sebo
PostPosted: Wed Apr 21, 2010 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi fonik:
I alway use this site: http://www.muzique.com/schem/filter.htm to do the
calculations, the funny thing is that in that site, the calculated cap value is 2nF
I think the calculator approximates the value a lot.
Sebo
My Music:
PostPosted: Wed Apr 21, 2010 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Sebo wrote:
Hi fonik:
great. thanks. at least i got the measures and decimals right, and that's what i wanted to know.
frijitz
Audio files: 54
PostPosted: Wed Apr 21, 2010 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Your formula looks wrong, but you got the right answer. If you use Ohms and Hz then the answer is in Farads:
C(F) = 1.59e-9F = 1.59nF.
(Oh, and I hope that comment about algebra maybe not commuting was meant as a joke.)
Ian
PostPosted: Wed Apr 21, 2010 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for indication, ian. it was a typo... Laughing
Rykhaard
PostPosted: Wed Apr 21, 2010 6:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whoa! Thank you for posting THAT link / pic for the i-Touch software! Just grabbed and for $3, am VERY impressed! Smile That'll assist me in learning more about filters in the future. (Still at the stumbling point as to VCF and VCO design. My last real stumping areas.)
PostPosted: Thu Apr 22, 2010 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey, thanks for replying there Rich! For a moment then I thought I had died and no one could actually see that I'd posted anything!! Shocked Laughing
ACHTUNG!
Rykhaard
PostPosted: Thu Apr 22, 2010 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
No prob. chief! That, is what I'm paid to do! Laughing Razz
andrewF
PostPosted: Thu Apr 22, 2010 4:55 am    Post subject: Reply with quote  Mark this post and the followings unread
i found this software in a post from Ricko
but it is excellent
texas instruments freeware active filter designer
http://focus.ti.com/docs/toolsw/folders/print/filterpro.html
Audio files: 316
PostPosted: Thu Apr 22, 2010 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Well ... Ian did react on your post Laughing
Scott Stites
Audio files: 96
PostPosted: Sun May 02, 2010 8:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've been getting a lot of mileage out of Don Lancaster's "Active Filter Cookbook" lately. As I understand it, it remains relatively the same even in later printings. It makes filter design pretty easy for mathematically challenged people like me. It *really* helped a lot in allowing me to understand filters to a far greater degree than I did before.
Take a look around, you might be able to find a used version of it somewhere. I got an autographed copy (an authentic swirl of a felt tip pin on the opening page) at MPJA here for something like $20.
My Site
Scott Stites
Audio files: 96
PostPosted: Thu May 27, 2010 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Speak of the devil:
25% off
http://www.mpja.com/email/05-18-10.asp?r=195316&s=21
My Site
PostPosted: Thu May 27, 2010 11:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the pointer, scott. unfortunately no off-price for me, they ship to the states only.
Scott Stites
Audio files: 96
PostPosted: Fri May 28, 2010 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Those bastages... Laughing
My Site
