Not receiving midi msg data
Page 1 of 1 [3 Posts]
Khepri
PostPosted: Mon May 17, 2010 7:16 pm    Post subject: Not receiving midi msg data Reply with quote  Mark this post and the followings unread
Hi all. Sorry if this has been covered recently.
I recently switched to a Vista 64-bit laptop. I'm wondering if that has anything to do with why midi isn't working for me. Or maybe I'm just missing something.
I have "Project 5" (32-bit software) sequencer sending midi to
"Out to Midi Yoke: 1." The P5 track's "MIDI Activity" light flashes, so I assume data is sent to the port.
I'm running the latest mini-audicle package, 1.2.1.3 Dracula. All the included midi examples work, as far as being able to "detect" all the 8 available Midi Yoke ports, and when actually opening a port.
This code:
<<<MIDI> ", min.name() >>>;
results in . . .
Console message: "MIDI device: 0 -> In From MIDI Yoke: 1"
But that's it. This code . . .
while( min.recv(msg) )
// print out midi message
<<<msg>>>;
. . . or similar never results in anything. The same goes for no sound. So - looks like the correct port is open, but no message is ever received.
Any ideas as to what's up here, or how I could test further?
Don't fear mistakes. There are none.
- Miles Davis
Kassen
PostPosted: Tue May 18, 2010 12:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Your example code doesn't chuck the midi device to now. Is that because you simplified it for posting, or did you forget this?
Kassen
Khepri
PostPosted: Tue May 18, 2010 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
EDIT: After searching the net a bit, I suspect it has nothing to do with ChucK. The problem may be getting Midi Yoke properly installed in Vista (with its over-done security features.) Thanks, anyway. I'll report back if I get it working.
I simplified. Below is the complete "gomidi.ck" from Chuck's examples folder. The only result it gives is . . .
"[chuck](VM): sporking incoming shred: 1 (*gomidi.ck)...
MIDI device: 0 -> In From MIDI Yoke: 1 "
//gomidi.ck
// number of the device to open (see: chuck --probe)
0 => int device;
// get command line
if( me.args() ) me.arg(0) => Std.atoi => device;
// the midi event
MidiIn min;
// the message for retrieving data
MidiMsg msg;
// open the device
if( !min.open( device ) ) me.exit();
// print out device that was opened
// infinite time-loop
while( true )
// wait on the event 'min'
min => now;
// get the message(s)
<<<msg>>>;
- Miles Davis
