Interfacing CVs and microcontrollers.
Page 1 of 1 [11 Posts]
reve
PostPosted: Wed Jun 09, 2010 11:33 am    Post subject: Interfacing CVs and microcontrollers.
Subject description: (again)
So I'd like to interface my modular CV signals to a microcontroller based LFO. The microcontroller ADC is expecting 0-5v positive. My envelopes are going 0-10 positive and my analog LFOs are +/- 5v. I'd like to handle the input as efficiently as possible, so I was hoping to pick some of your collective brains.
It seems like a voltage divider followed by a diode clamp would get the incoming voltages where I need them to be. But I also want manual control – so I would also want a pot wired to 5v and ground. And I might want multiple CV inputs. Smile
Aaaannnnd that's where I run into trouble. As I already have four opamps on the outputs of my simple digital project, I was hoping to get out of constructing like, a DC mixer. Is there a way around that? Could I just use a couple zeners and just straight clip the voltage or something to keep inside the 0-5 box?
Doing it right is more important than doing it easy here, but... I’d like both right and easy if all y'all have any suggestions. Smile
clee
PostPosted: Thu Jun 17, 2010 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're going to have to build a DC mixer if you want to mix CV inputs. Or bring each CV input to a PIC pin and share the A/D converter (the harder of the 2 I would think).
As far as protecting the PIC from overvoltage, I'm having the same issue with a Quantizer I'm building, I'd be interested in some ideas others have. Just using a zener and a resister will give you a very non-linear response near 5 volts.
Here are 2 bits of info:
This is nice, but the voltage break is changed by the input impeadance
http://books.google.com/books?id=1NcSBP2OA-QC&pg=PT278&lpg=PT278&dq=precision+clipper+op+amp&source=bl&ots=oLn5X37G35&sig=IFR5vOZfbEpnXTR4WEpw9TSXo2A&hl=en&ei=UH8RTLaeJZCUMvPC7cgF&sa=X&oi=book_result&ct=result&resnum=6&ved=0CDAQ6AEwBQ#v=onepage&q=precision%20clipper%20op%20amp&f=false
and this tread seems to be saying don't worry about it
http://www.electro-tech-online.com/micro-controllers/22046-i-o-pin-over-voltage-protection.html
but I'm not so sure...
life in many forms...
http://clsound.com
PickNick
PostPosted: Fri Jun 18, 2010 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
hi!
here is some info about modified Edruid LFO/sync in, FM in...:
http://www.acoupel.com/LFO/Schema/Schema%20LFO%20edruid.htm
and the original schema with optional external CVins:
http://www.electricdruid.net/forums.html?page=projects.lfo9
reve
PostPosted: Fri Jun 18, 2010 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the responses, guys. Extra thanks to Wavemultiplier... I see now the problems with the nonlinearity in the zener solution -- it winds up working as a voltage divider. Boo. Hiss.
That said, it looks like both AVRs and PICs have internal protection diodes in place as long as you use a current limiting resistor in series. The bad is that it winds up biasing the other ADC inputs when the protection diodes kick in. :/
So here's my crazy idea: (for my scenario) we've gotta build a DC mixer, ya? So I've got an inverting opamp followed by a voltage follower. What if I used a rail to rail op amp powered by 0v/+5v as the voltage follower? A regular opamp would work for protecting the micro from overvoltage, but... it'd mess up the scaling, which needs to be real close to 0-5v.
Would that work?
PickNick
PostPosted: Fri Jun 18, 2010 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
for -5/+5 cvin maybe?
http://www.acoupel.com/sequencer/schemas/ACS%20Sequencer%20schema.pdf
for multiple 1v/oct cvins///0-8v:
http://www.electricdruid.net/datasheets/VCLFO9DDatasheet.pdf
sorry if i misunderstood something Smile
clee
PostPosted: Sat Jun 19, 2010 6:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is what I came up with the other day. I have not actually hooked this up to a PIC yet, the person doing the programing has it, but it SHOULD work. Resister values may change.
The circuit is putting out about -1 volt when going negative right now. I need to try a schottkey diode for D1 and see if it gets it to -.3v
R6 sets the CV from 0 to 5v R7 sets CV IN to no gain at the center, full gain with the wiper at CV IN and Inverted full gain with the wiper at GROUND
EDITED: Error IN DESIGN! javascript:emoticon('Embarassed')
 Filesize:  106.68 KB
 Viewed:  450 Time(s)
http://clsound.com
Rykhaard
PostPosted: Sat Jun 19, 2010 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
PickNick wrote:
hi!
Thankee for those links. Smile I've just ordered 5 x 16F684's. I'm going to try working with this, to teach myself working with the PICKit 3 - backwards. Study the code for these devices and from THAT direction, learn how to properly work with everything, in modifying them further / etc. Smile
clee
PostPosted: Sat Jun 19, 2010 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
So, don't build the circuit I posted. The 2 pots interact with each other. The clipper does work though.
Craig
http://clsound.com
Rykhaard
PostPosted: Sat Jun 19, 2010 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Craig
No worry. I've posted a request for code, at Electric Druid's website.
Junk Rhythm
PostPosted: Sat Jun 19, 2010 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I thought the ASM code and HEX file was included on the Electrc Druid website?
[twitter] [blog] [flickr] [toppobrillo] [buzz]
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger
Rykhaard
PostPosted: Sat Jun 19, 2010 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Uh oh .... maybe I were blind in the eye that would have seen it then. Surprised I sent him off email, requesting permission for his code, explaining my dilemma in learning and having ordered the 16F684's today ...
Shall see. And, I'll go back and have a look ... feeling silly if it's still up there. Surprised Smile
