 Forum index » Clavia Nord Modular » G2 Patches - Completed » Drones
XOR Drones
Page 1 of 1 [5 Posts]
varice
Audio files: 29
G2 patch files: 54
PostPosted: Thu Jul 15, 2010 11:54 pm    Post subject: XOR Drones Reply with quote  Mark this post and the followings unread
Four square wave oscillators processed through three XOR logic gates to derive a single nasty and dark digital aliasing bit stream, then ran through filters in an attempt (in vain?) to tame and temper…
XOR Drone 01.pch2
XOR Drone 01
 Filename:  XOR Drone 01.pch2
 Filesize:  2.57 KB
 Downloaded:  3066 Time(s)
varice
cebec
G2 patch files: 31
PostPosted: Fri Jul 16, 2010 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I really like this! Nice wavetablish/digital drone.
http://www.soundcloud.com/cebec
varice
Audio files: 29
G2 patch files: 54
PostPosted: Sat Jul 17, 2010 10:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks cebec! I’m glad that you like it.
That XOR drone has stable oscillator pitches so that there is a slow and relatively cyclical nature to the sound.
This next XOR drone patch has four wave shapeable LFOs that are entangled and intertwined with each other to generate four pseudo random/chaotic control signals which are then used to slightly detune the square wave oscillators resulting in a little random pitch drift over time.
Check out the variations.
And if you would like some crazy industrial noise sequencing, start the clock! Stop the clock at different points to check out the resulting drone.
Note: Although this patch will work in the G2 Demo software, it will not sound exactly the same as the G2 hardware. The oscillators in the Demo do not seem to have the same pitch resolution.
XOR Drone 02.pch2
 Filename:  XOR Drone 02.pch2
 Filesize:  4.96 KB
 Downloaded:  2742 Time(s)
varice
Roland Kuit
G2 patch files: 127
PostPosted: Sun Jul 18, 2010 3:01 am    Post subject: Reply with quote  Mark this post and the followings unread
nice one!
i notished Shaper Static 4 was off. by clicking on it sounds better.
varice
Audio files: 29
G2 patch files: 54
PostPosted: Sun Jul 18, 2010 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Roland!
But, I like that particular sequence with that shaper turned off. Laughing
Of course, please feel free to tweak. I assigned many parameters to panel knobs. Experiment!
varice
