Voltage Controlled OpAmp RingMod (Modulator)
Page 6 of 9 [209 Posts]
PostPosted: Mon Oct 25, 2010 5:05 am    Post subject: Reply with quote  Mark this post and the followings unread
hi folks,
i just wanted to let you all know that i did not ship any PCBs yet. it is just because i have been occupied by my daily job last week. nevertheless all your payments have been received thankfully. you e-m forum members show a valuable discipline and responsibility.
i will ship the PCBs this week and will inform you on that via paypal.
thank you.
mono-poly
PostPosted: Mon Oct 25, 2010 6:35 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
mono-poly wrote:
Is this also coming as an euro module?
look this:
VC Modulator
Love a few of those Very Happy
Lbarros
PostPosted: Wed Oct 27, 2010 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
well,one for me too please.
Thanks Matthias.
valis
Audio files: 6
PostPosted: Thu Oct 28, 2010 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
This sounds like a fun and easy project. If you have any pcbs left please let me know as I'd like one. Thanks!
PostPosted: Thu Oct 28, 2010 3:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Documentation
VCRingMod building docs
rosch
PostPosted: Thu Oct 28, 2010 4:08 am    Post subject: Reply with quote  Mark this post and the followings unread
mine arrived today! thank you very much!!
numbertalk
PostPosted: Thu Oct 28, 2010 5:58 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
Documentation
Hi Matthias,
How do you properly adjust the 2 trimmers? It looks like they're for minimizing the offset of the OTAs, right? What is the proper procedure though - feeding an LFO into the mod input, looking at the test point with a scope and adjusting the trimmer until the bleedthrough of the LFO signal is minimized there?
Very much looking forward to getting my board, thanks!
e-grad
PostPosted: Thu Oct 28, 2010 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Just have received mine. It's tiny! Shocked
Thanks! Very Happy
PostPosted: Thu Oct 28, 2010 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
almost.
feed the input with an audio sine, and look at the testpoint to get the shape of the sine corrected.
i will look deeper into this on the weekend to come up with a good procedure, that could be implemented to the documentation then...
emdot_ambient
PostPosted: Thu Oct 28, 2010 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
...feed the input with an audio sine...
I just read a post from someone in an old thread complaining about how most VCOs these days don't include sine waves.
valis
Audio files: 6
PostPosted: Thu Oct 28, 2010 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry if I'm a little dense but are these pcbs through-hole or SMT?
e-grad
PostPosted: Thu Oct 28, 2010 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Through hole no SMT parts involved.
valis
Audio files: 6
PostPosted: Thu Oct 28, 2010 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
a100user
PostPosted: Fri Oct 29, 2010 1:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias
Are you likely to be producing Euro front panels for this module?
Thanks
David
LektroiD
PostPosted: Fri Oct 29, 2010 1:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm now wondering how to do a 5U for this, If I do standard MOTM 1U, I'll have nowhere to put the extra socket, and it seems a little wasteful to use a 2U panel just to accommodate 1 extra socket. I may have to use smaller rotary knobs and place the sockets next to each of those
Any other 5U guys out there building this?
LektroiD
PostPosted: Fri Oct 29, 2010 2:03 am    Post subject: Reply with quote  Mark this post and the followings unread
a100user wrote:
Hi Matthias
Thanks
David
actually not.
a100user
PostPosted: Fri Oct 29, 2010 2:14 am    Post subject: Reply with quote  Mark this post and the followings unread
OK thanks Matthias
David
magman
PostPosted: Fri Oct 29, 2010 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I've got 2 on the way, so I'm planning to squeeze 2 rows of 5 sockets on a 2U panel (You can just get away with this using Switchcraft jacks) for the both of them on one panel.
Regards
Magman
TekniK
PostPosted: Fri Oct 29, 2010 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
recieved mine,realy cute pcb's
10x Matt!
numbertalk
PostPosted: Fri Oct 29, 2010 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
almost.
LektroiD
PostPosted: Fri Oct 29, 2010 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Regards
Magman
Pretty much what I started planning (interestingly before even reading this), although I chose smaller knobs for this, as you will see in my example (even though I have not yet received the boards yet).
 Filesize:  154.18 KB
 Viewed:  250 Time(s)
LektroiD
magman
PostPosted: Fri Oct 29, 2010 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a first pass MOTM 2U Panel.
Regards
Magman
Ringmod 2U MOTM Panel.PDF
2U MOTM Panel in PDF Format
 Filename:  Ringmod 2U MOTM Panel.PDF
 Filesize:  176.67 KB
 Downloaded:  296 Time(s)
Fonik 2U Ringmod.fpd
2U MOTM Panel in FPD Format
 Filename:  Fonik 2U Ringmod.fpd
 Filesize:  2.79 KB
 Downloaded:  266 Time(s)
LektroiD
PostPosted: Sat Oct 30, 2010 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Boards arrived! Thanks Fonik.
Just wondering if there would be much degradation in sound if I used ceramic caps for C3, C4, C5, C6, C7, C8? Just that I've run out of 100n poly caps..
LektroiD
PostPosted: Sat Oct 30, 2010 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
no. these are not part of the actual signal path, but just used to decouple the ICs from the power rails.
LektroiD
PostPosted: Sat Oct 30, 2010 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's ok, I used ceramics at the PSU stage, and I found a couple of polyester film capacitors for the rest of the circuit. I didn't realise they were decoupling caps at the time, as I only just got your reply, and was impatient to build this, or I'd have just used ceramics throughout. Oh well, they're built now (not tested yet though).
LektroiD
