 Forum index » Clavia Nord Modular » G2 Patches - Completed » Audio In
10,800seconds delay/looper at 96khz.
Page 1 of 1 [8 Posts]
Moody33
G2 patch files: 16
PostPosted: Sun Oct 24, 2010 1:55 pm    Post subject: 10,800seconds delay/looper at 96khz.
Subject description: Simple delay up to 10,8sec at 96 khz
Here is a "long" delay looper at 96 khz on an unexpanded G2.
This patch use bus1/2 and bus 3/4.
Should provide 21,6 seconds on an expanded one but it needs 2 more audio bus or an expert in multiplexing...
I'm trying to get more delay times using blue hell's method ( http://electro-music.com/forum/viewtopic.php?highlight=longdelay&t=7979 ) but it don't seems to work with my patch . Also, I'd like to use multiplexing to save one audio bus, but I don't know where to start, and my attempts are Crying or Very sad .
If you have ideas...I don't care if it works at 48 khz. I just need a long delay !
Thanks for your advices.
10800msLooper-mdy.pch2
 Filename:  10800msLooper-mdy.pch2
 Filesize:  1.88 KB
 Downloaded:  2107 Time(s)
Moody33
G2 patch files: 16
PostPosted: Sun Oct 24, 2010 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ooooops...just discover this topic: http://electro-music.com/forum/viewtopic.php?highlight=delay+looper&t=23211
My patch is the same... Very Happy Laughing
A few hour for a patch that already exist. Laughing
Sorry.
PostPosted: Sun Oct 24, 2010 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing no worries .. the fun part is the experiment Wink
Moody33
G2 patch files: 16
PostPosted: Sun Oct 24, 2010 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
No worries...but my G2 made me mad.
My patch is the same but when I try to increase the delay time by using one of your building block ( at 48 khz = timex2 ), it don't work.
However , I've try the same thing with your original patch and...it works and i've got a 16 seconds delay looper ! But if I change a parameter , or copy paste a module , it stop working. I really don't understand why. If I increase the delay time to 2,7 sec ( to get 21,6 seconds) , it stop working.
Could you please take a look to this patch and let me know if it works on your G2?
Thanks you and sorry for my english (once again)!
16seclooper-mdy.pch2
 Filename:  16seclooper-mdy.pch2
 Filesize:  1.56 KB
 Downloaded:  2071 Time(s)
Moody33
G2 patch files: 16
PostPosted: Thu Oct 28, 2010 3:46 am    Post subject: Reply with quote  Mark this post and the followings unread
This one seems to work: http://electro-music.com/forum/post-311614.html#311614
PostPosted: Thu Oct 28, 2010 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Will look at this again ... but currently setting up a couple of patches and stuff for the Halloween event here and busy otherwise too .. so not much time.
Moody33
G2 patch files: 16
PostPosted: Thu Oct 28, 2010 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Problem is solved. The 16 seconds looper is working now. Wink
PostPosted: Thu Oct 28, 2010 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
