today> Twyndyllyngs reschedule: Sunday, Dec 6 Chez Mosc
Voltage Controlled OpAmp RingMod (Modulator)
Page 8 of 9 [209 Posts]
Goto page: Previous 1, 2, 3, ..., 6, 7, 8, 9 Next
PostPosted: Fri Nov 19, 2010 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
wow!
that demonstration is awesome!
BTW did you try the VCmodulator for control voltages as well?
I will try out some control voltages with it and I'll let you know how it works out.
brother303
PostPosted: Fri Nov 19, 2010 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Fonik,
one question on the power supply : 12V possible without changes in any values? Schematics says "15V".
Best regards
Greg
PostPosted: Fri Nov 19, 2010 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
will work with 12V without any modifications.
numbertalk
PostPosted: Fri Nov 19, 2010 6:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
A couple photos. Thanks so much for sharing this module!
Edit - not sure why they're being rotated when I attach them.
 Filesize:  1.54 MB
 Viewed:  687 Time(s)
 Filesize:  1.71 MB
 Viewed:  649 Time(s)
brother303
PostPosted: Sat Nov 20, 2010 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks lot!
crashlander42
PostPosted: Sat Nov 20, 2010 1:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I wish I ordered two of these. It sounds great!
vc ring mod in my crappy looking but functional modular
 Filesize:  258.31 KB
 Viewed:  719 Time(s)
When they plug me in the lights go down in Hong Kong.
http://www.myspace.com/isaciongun
http://www.youtube.com/user/Crashlander42
My DIY stuff Flickr
numbertalk
PostPosted: Sat Nov 20, 2010 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Spent a lot of time playing with this module today - loving it. Attaching a short sample.
rm-sample.mp3
 Filename:  rm-sample.mp3
 Filesize:  786.65 KB
 Downloaded:  1376 Time(s)
brother303
PostPosted: Thu Nov 25, 2010 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
pcb arrived safely,thanks for fast shipping!
Best regards
Greg
XCenter
PostPosted: Thu Nov 25, 2010 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Same here.
How may I be of disservice?
Music for conscious listening @ http://www.fmdelight.de/
TekniK
PostPosted: Fri Nov 26, 2010 12:28 am    Post subject: Reply with quote  Mark this post and the followings unread
May i ask you where you did buy the knobs with orange and white caps?
XCenter
PostPosted: Sun Dec 05, 2010 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Mmh, can´t find the 2N3908 transistor at any standard supplier I usually order from. Maybe s.o. could give me a tipp here? I´m located in Germany. Thx.a lot.
Dego
PostPosted: Sun Dec 05, 2010 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
2n3906...
XCenter
PostPosted: Sun Dec 05, 2010 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Is this a substitute to the 08 or have I missed s.th.?
[edit]
Doooh! Thx for opening my eyes. It HAS to be the 2N3906. Embarassed
tommi
PostPosted: Wed Dec 08, 2010 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why am I always late for fonik PCB offers? Confused
I 'll go with stripboard as usual...
http://tideofsound.net
PostPosted: Thu Dec 16, 2010 7:37 am    Post subject: Reply with quote  Mark this post and the followings unread
i found that one could improve the range of potentiometer P4 by connecting the CCW (pin1) via a 10k to GND.
if you use the module for audio in the first place, you could even solder a 100k resistor across CW and wiper (pins 3 & 2) of the potentiometers (P3 & P4).
sorry. Crying or Very sad
tommi
PostPosted: Fri Dec 17, 2010 2:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. I'll add these little changes on the stripboard!
It would have been easy adding these changes to the PCB too Crying or Very sad
PostPosted: Fri Dec 17, 2010 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
true. however, you actually could do these changes off board at the potentiometers.
tommi
PostPosted: Fri Dec 17, 2010 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Not to be honest, because I choosed to use pcb mounted pots. I choose that way to reduce the number of cables running from the board to the panel mounted components for a cleaner build Very Happy
Anyway I'll put those resistors on the board.
But I planned to mount R3,4,7 and 8 on the jacks and this will make the stripboard less crowded (and less deep).
tommi
PostPosted: Mon Dec 27, 2010 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I got my stripboard version working now! I posted pictures on the 2010 build thread. After some troubleshooting due to brutal mistakes, such as forgetting one resistance and putting all trannies backwards (!). Watching fonik's pcb i realized that 2n3906's pinout is the opposite of what i decided it was..
I am not sure about how to calibrate this module.
I don't have a scope so i just followed the procedure told by fonik on page 7:
-with no signal applied and all pots down exept for carrier initial wich is fully up, I turn the trim (T1) until i got 0V at TP1.
The same procedure for the modulator signal.
So in both cases i got 0V at Test Point when the 'initial' pot is fully up and about - 1,2V when that pot is fully down. Is that ok?
There is some bleedthru between channels when i mixed two audio signals.
When i mix two DC signals (i tried with CV out from a sequencer and a sine wave from an lfo), bleedthru (from lfo's sine) is much more evident.
I am not sure if my calibration is ok and just wanted to share my experience..
cheers
PostPosted: Mon Dec 27, 2010 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
all is okay, even the bleedthrough. you cannot expect VCA action from this design anyways...
tommi
PostPosted: Mon Dec 27, 2010 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
That's right! Anyway this module have its own character and me too i was hit by the demo of kkissinger!
Any suggestion about some interesting patch that modulates two DC signals?
cheers
the_ufo
PostPosted: Mon Jan 31, 2011 8:27 am    Post subject: what to do Reply with quote  Mark this post and the followings unread
i've soldered over some of the holes and the braid isn't removing the solder... help?
softfin
PostPosted: Mon Jan 31, 2011 9:53 am    Post subject: Re: what to do Reply with quote  Mark this post and the followings unread
Sounds like a situation where a desoldering pump would come in handy. Smile
the_ufo
PostPosted: Mon Jan 31, 2011 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
thankyou!
emdot_ambient
PostPosted: Tue Feb 01, 2011 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, desolder pump is your friend. Best purchase I've made for DIY (next to a somewhat decent soldering station). Desolder pumps can be a bit of a pain--you've got to keep them cleaned out--but they're WAY better than desoldering braid. Less potentially damaging as well.
