What guitar sound do you prefer?
Page 1 of 1 [9 Posts]
Inventor
Audio files: 267
PostPosted: Tue Jan 04, 2011 11:50 pm    Post subject: What guitar sound do you prefer?
Subject description: from a signal analysis perspective
I've just downloaded the demo version of Electroacoustic Toolbox, which is basically a spectrum analyzer, scope, and other stuff for your soundcard. I measured some signals from the OYT guitar invention in both factory and invention switch position, and was rather surprised at what I saw.
In particular there was no additional harmonic content with the invention. I also noted that a super-sharp initial transient occurs with the factory setup that is not there for the invention (attack i guess you'd call it), and a greater content at discordant frequencies, i.e. frequencies not at harmonic multiples.
Much to my surprise one guitarist on another forum said that he prefers the factory pickups because he likes the "richer harmonic content". Maybe guitarists like a little bit of dissonance, maybe a lot? This got me thinking about ways to make the invention more acceptable to the guitarist community. I could purposely create more discord if that's desired. I could add circuitry that increases the same stuff.
Backing up a bit, I guess I should just ask: what do you want in your guitar spectrum / waveform?
Les
BobTheDog
PostPosted: Wed Jan 05, 2011 12:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Les,
Can you post some images of the frequency graphs?
Andy
Inventor
Audio files: 267
PostPosted: Wed Jan 05, 2011 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure Andy,
In this example I have placed the magnets near the bridge for the invention, and used the bridge pickup for the factory position. Pluck was done at middle pickup location of low E string, open (unfretted).
The spectrum in this case is very similar so it makes a good frame of reference for future comparison i suppose.
Les
Spectrum of Invention Low E STring
 Filesize:  101.75 KB
 Viewed:  947 Time(s)
Spectrum of Factory pickups low E String
 Filesize:  104.88 KB
 Viewed:  973 Time(s)
Inventor
Audio files: 267
PostPosted: Wed Jan 05, 2011 3:01 am    Post subject: Reply with quote  Mark this post and the followings unread
And here is an audio sample of the two waveforms along with some discussion from me.
Les
Bridge Position Similar Sound 20110105 0449.1.mp3
audio sample of prior posted spectrum
 Filename:  Bridge Position Similar Sound 20110105 0449.1.mp3
 Filesize:  3.69 MB
 Downloaded:  1604 Time(s)
BobTheDog
PostPosted: Wed Jan 05, 2011 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Les,
I bet if you tried other different mag pickups you would notice similar differences.
Different pickups sound very different, even combinations of different string types with different pickups produce very different sound.
My bet is also the attack changes as well but I must admit I have never thought of this before but it makes sense.
Andy
Inventor
Audio files: 267
PostPosted: Wed Jan 05, 2011 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
As requested by woody monk, the next measurement is with the high E string. Magnets slightly adjusted also.
Les
Spectrum with Factory pickups when high e string is plucked
 Filesize:  124.79 KB
 Viewed:  1089 Time(s)
Spectrum with invention, high e string plucked
 Filesize:  128.09 KB
 Viewed:  999 Time(s)
GovernorSilver
PostPosted: Sat Jan 15, 2011 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
My favorite electric guitar tones, with minimal or zero processing (aka "clean guitar sounds") are the Fender Strat single coil tones, as represented by:
Mark Knopfler (of Dire Straits, around the time of this song):
http://www.youtube.com/watch?v=-HUfFtCHEzk
Eric Johnson (ok there's delay on the guitar, but the character still comes through):
http://www.youtube.com/watch?v=5liGR7dGL0Q
Wayne Krantz:
http://www.youtube.com/watch?v=AHviiarmV2M
With processing, well, all bets are off.
Some old stuff on VIRB
Inventor
Audio files: 267
PostPosted: Mon Jan 17, 2011 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Well thanks for your comments, though I still do not have a feel for what subset of the market will be best for these pickups. I'm actually starting to think of piano and violin and lute or other instruments (maybe banjo) that people actually want to hear what the instrument itself sounds like.
What I've learned from playing with the measurement software is four things.
1. there is NOT more harmonic content with the new pickup. It is about the same.
2. there is much lower dissonance with the new pickup (see above 1khz on low E string plots above)
3. the attack is much lower with the new pickup
4. the bass is less enhanced with the new pickup (a known flaw of coil wound pickups).
I'm wondering what part of the market is best suited for this pickup given those four observations.
Les
GovernorSilver
PostPosted: Mon Jan 24, 2011 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Les
My guess is the metal guitar market. They are the ones who are enthusiastic unusual pickups such as Q-Tuners, Lace Alumitones, etc.
