Jack_Hertz
Audio files: 101
G2 patch files: 7
Joined: Apr 24, 2009 Posts: 2517 Location: Bristol UK
Audio files: 505
nobody
Posted: Tue Dec 28, 2010 4:26 pm Post subject:
| I think I heard the show once. Very nice! I'd love to be a guest some time. |
Jack_Hertz
Audio files: 101
G2 patch files: 7
Posted: Tue Dec 28, 2010 5:21 pm Post subject:
| audiodef wrote: | | I think I heard the show once. Very nice! I'd love to be a guest some time. |
I would love to have you. Everyone, are most welcome to send me your drones and loops. I will be glad to use them on the show.
Likewise, if you'd like to join me for a live stream drone jam. Send me a note so we can set something up. _________________ Jack Hertz.com | Aural Films Last edited by Jack_Hertz on Tue Dec 28, 2010 6:51 pm; edited 1 time in total |
Joined: Feb 04, 2005 Posts: 2877 Location: Nottingham, UK
Audio files: 280
nobody
Posted: Thu Dec 30, 2010 8:06 am Post subject:
I was just reading the brain/thought controlled music thread that 1:11 started when I came up with an idea, sitting in view of an electric range-top oven. This idea would work well for Time Drone, as it requires patience and time.
Put a (or more than one) heat sensor above an electric range-top. Maybe even a heat sensor inside the oven. Fiddle with the heat levels of the individual coils (and oven, if used). Now that I think of it, this would work better with individual sensors for each coil. Have the heat sensors control whatever - cutoff, resonance, VCA and pitch, for example.
Get some pretty sensitive heat sensors and I'm guessing you could introduce variations by waving your hands (or something fireproof) between the stove coils and the sensor.
Now I wish I had the means to do this. |
nobody
Posted: Thu Dec 30, 2010 8:11 am Post subject:
| Another idea: tie strings between small trees on a windy day, with the strings triggering controls when pulled or relaxed. Have multiple instances of this going further back into a forest so that the outer trees make more pronounced changes while the inner trees make less pronounced changes. |
Jack_Hertz
Audio files: 101
G2 patch files: 7
DES
Posted: Thu Dec 30, 2010 8:59 am Post subject:
My wife and I have tossed around the idea of making an Aeolian Harp. You can see some types here: http://www.harmonicwindharps.com/ Very cool sounding instruments
Might be pretty cool to use pickups to capture the sound - and also have several strings control sensors routed to control MIDI CC or CV type controls that are connected to filters, etc.. _________________ Dave
www.davesneed.com |
Jack_Hertz
Audio files: 101
G2 patch files: 7
Posted: Sat Jan 01, 2011 10:54 am Post subject:
Huh, that was a cool Dave. The harmonic sanctuary is very inspiring. I live in a windy place that I could do some interesting things with. Anyone know where I can get some pick up for steel cables? _________________ Jack Hertz.com | Aural Films |
DES
Posted: Sat Jan 01, 2011 2:17 pm Post subject:
I would think - unless the wire was non-magnetic - that you could use guitar pickups. Or in a pinch use the small transistor radio earphones. You would have to work out an efficient way to couple the string to the diaphragm in the earphone though. They work pretty good as pickups. Years ago in high school I took one and screwed it onto the end of my flute (the end where the small cap comes off so you can adjust intonation) Put it on just tight enough for the diaphragm to contact the threaded rod. Worked pretty darned good!
Possibly also use piezo elements from old buzzers and such.... _________________ Dave
www.davesneed.com |
Jack_Hertz
Audio files: 101
G2 patch files: 7
Posted: Mon Jan 03, 2011 1:07 pm Post subject:
Yes, Piezos are the way to go. I talked to a buddy who build custom Pick-ups and he said those with some 2-sided tape should do it. Now to find some cables.  _________________ Jack Hertz.com | Aural Films |
Jack_Hertz
Audio files: 101
G2 patch files: 7
Jack_Hertz
Audio files: 101
G2 patch files: 7
Posted: Tue Jan 04, 2011 10:40 am Post subject:
Time Drone 2011-01-03 |
Here is the recording from last nights show. The first hour features my new release "Streaming Landscape" followed by a live set with special guest John Johnson who was performing on the Korg iMS-20 and other devices. _________________ Jack Hertz.com | Aural Films Last edited by Jack_Hertz on Tue Apr 20, 2021 9:56 am; edited 1 time in total |
nobody
Posted: Tue Jan 04, 2011 3:07 pm Post subject:
| Great set, Jack! |
D.Miñoza
Joined: Jun 15, 2009 Posts: 376 Location: CowTown, USA
Audio files: 31
Posted: Tue Jan 04, 2011 6:18 pm Post subject:
excellent set, jack.
~ _________________ *****************
soundcloud
relaxedmachinery |
shanemorris
Audio files: 92
Posted: Wed Jan 05, 2011 1:01 am Post subject:
Jack I have made Time Drone a sticky topic with the other regularly scheduled programs and added you to the radio schedule. Great to add another high quality show to our list. Thanks  _________________ ElectroCasa |
Audio files: 280
Jack_Hertz
Audio files: 101
G2 patch files: 7
Posted: Wed Jan 05, 2011 2:49 pm Post subject:
Thanks muchly for tuning in. Hope I can keep it up with the down slow every week.  _________________ Jack Hertz.com | Aural Films |
nobody
Posted: Mon Jan 10, 2011 7:04 pm Post subject:
In lieu of uploading, I thought I'd post a link to the flac, since it's around 200 MB.
http://audiodef.com/audio/flac/TimeDrone1.flac
This is my stand-alone drone that Jack incorporated into the show on 10 January. I thought I'd include it for the geek factor. |
Jack_Hertz
Audio files: 101
G2 patch files: 7
Posted: Tue Jan 11, 2011 12:12 pm Post subject:
Here is the recording from last night's Time Drone show. I was joined by "sepcial" [sic] guest Audiodef. _________________ Jack Hertz.com | Aural Films Last edited by Jack_Hertz on Tue Apr 20, 2021 9:56 am; edited 2 times in total |
nobody
Posted: Tue Jan 11, 2011 12:28 pm Post subject:
This was fun. I have a few large, brightly-coloured triangular paper clips that I used to hold down keys on different synths.
I've posted the show to my own site. I just need to add a note explaining I was a guest on the show.
http://audiodef.com/shows.php?show_id=4
Edit: note added. Last edited by nobody on Thu Feb 17, 2011 8:03 pm; edited 2 times in total |
Jack_Hertz
Audio files: 101
G2 patch files: 7
Posted: Tue Jan 11, 2011 1:15 pm Post subject:
| audiodef wrote: | | This was fun. I have a few large, brightly-coloured triangular paper clips that I used to hold down keys on different synths. |
That was fun. Thanks for playing along.
That's a great idea. I use a footswtich plugged into the sustain input on my USB controller to keep stuff on. _________________ Jack Hertz.com | Aural Films |
Joined: Apr 03, 2004 Posts: 24595 Location: The Netherlands, Enschede
Audio files: 309
Posted: Tue Jan 11, 2011 1:36 pm Post subject:
| Jack Hertz wrote: | | My account is out of space |
Is the file really larger than 900 MB?  _________________ Jan
nobody
Posted: Wed Jan 12, 2011 9:07 am Post subject:
| Jack Hertz wrote: |
That's a great idea. I use a footswtich plugged into the sustain input on my USB controller to keep stuff on. |
I prefer foot switches, but I don't have any. Maybe I should move this up in my acquisition list - they aren't expensive. Some of my synths have hold functions, but it's a bit convoluted to quickly assign the function to a knob somewhere. |
