PIC based Pitch to Voltage Convertor
Page 1 of 1 [6 Posts]
ericcoleridge
PostPosted: Sat Jan 29, 2011 7:15 pm    Post subject: PIC based Pitch to Voltage Convertor Reply with quote  Mark this post and the followings unread
I don't have one-- I don't really know anything about PIC programming. I've just been seeing a lot of really great PIC based modules lately-- like the tap tempo LFO, dividers and multipliers, and quantizers.
I figured someone must be designing a PIC based Pitch Detector/Follower. This seems to be something that's just too difficult or problematic to do with analog circuits-- but might be easy to do with a PIC chip.
Isn't there someone here who wants to design a Pitch to Voltage module?
StephenGiles
PostPosted: Sun Jan 30, 2011 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I think you need a decent fundamental extractor at the front end, certainly for guitar otherwise it's a complete waste of time. Howard Davis of Electroharmonix probably designed the best one.
jnuaury
Audio files: 9
PostPosted: Sun Jan 30, 2011 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://registeringdomainnamesismorefunthandoingrealwork.com/blogs/?p=150
i havent looked at the code yet, but all youd have to add is a DAC of some kind and some code to output that voltage... seems like most of the heavy lifting is done though.
az/gde
Flickr
YouTube
StephenGiles
PostPosted: Sun Jan 30, 2011 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
As I said, you must have a decent funamental extractor, and it also helps to compress the input signal.
LFLab
PostPosted: Mon Jan 31, 2011 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Would the hardware need to be that much different from the pitch to midi converter in the october 2009 issue of Everyday Practical Electronics? Basically "just" other code, right?
ericcoleridge
PostPosted: Mon Jan 31, 2011 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is it; I think this is perfect.
