Intro & Novation remote zero mkii G2 engine template
Page 1 of 1 [25 Posts]
tIB
PostPosted: Sat Feb 26, 2011 2:24 pm    Post subject: Intro & Novation remote zero mkii G2 engine template
Subject description: G2 engine control
Hello, finally got my hands on a G2 engine today, its been a very long wait but a worthwhile one: cut my teeth on a micromodular before going real modular with a euro and frac setup. So, very happy to be here.
Along with the G2 I also ordered a control surface for it in the form of the novaiton remote zero SL mk2. Does anyone have any G2 related setups or sysex for this machine they would care to share?
So far I thinking a page for each bank with the illuminated dials doing the 8 morphs and the bottom row of buttons triggering each of the variations.
That leaves plenty of buttons, 8 dials and 8 sliders for each bank. If anyone has any ideas on ways to implement these Im all ears, Ill post any templates I make in this thread, if any else has any I could try out the let me know.
Here is the device Im using:
PostPosted: Sat Feb 26, 2011 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome tIB
tIB
PostPosted: Sun Feb 27, 2011 4:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers my man. Smile
Quick novation update:
So far Ive got 4 memory slots on the novation controlling each of the 4 banks, with the illuminated dials controlling the 8 morphs and the bottom row of buttons selecting each variation. Works well.
Not sure what to do about the other buttons, dials and switches: would be nice to configure them to some of the global parameter pages but I havent figured that yet. Might just set them to a bunch of CC's so I can assign them depending on what patch Im making.
Anyway, if anyone needs the template as it is now let me know...
PostPosted: Sun Feb 27, 2011 7:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't remember the CC's,but you can set it up four of the sliders to control slot volume. That way you have a global mix of all slots always at the ready.
tIB
PostPosted: Mon Feb 28, 2011 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
^ good idea cheers. Thinking about it I could go for each of the patch variations on the buttons so I can change any variation no matter which bank Im controlling. Plenty of options!
Kaan
PostPosted: Sat Mar 05, 2011 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just got my SL MK II key couple of days ago. And start to make a template for my G2 Engine.
Volume CC is 7 and Variation is 70. Also found the program change in the quick menu.
I assigned the variation to buttons and rotary Smile
But I couldn't found the dump file of the template?
Also it would be cool if you could share your template for modding.
Kaan
tIB
PostPosted: Sun Mar 06, 2011 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Ill upload my templates later today, they are on a different machine to this one.
Thanks for the volume tip, Ill add that in before uploading...
I didnt know you could program change externally, Ill have to look into that: is it as simple as sending a program change message to the relevant midi channel?
tIB
PostPosted: Sun Mar 06, 2011 2:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Right, here is my V4... I store in the novation as G2 A, B and so on, in slots 1-4 on the novation, selecting through banks by hitting the dial and selecting the relevent bank on the dials. You will need to write them there on yours. Probably doesnt make much sense until youve used the templates.
I set up a blank patch in the nord editor, with the morph groups on cc 21-29, bank A is on channel 10, B 11, C12, and D13. Obviously you can edit these as you wish.
Im probably going to use the other row of dials as assignable CCs, also want to look into pattern changes... if anyone knows how thats setup let me know and Ill add it to this.
Nord - G2 Engine Slot A.syx
 Filename:  Nord - G2 Engine Slot A.syx
 Filesize:  4.02 KB
 Downloaded:  532 Time(s)
Nord - G2 Engine Slot C.syx
 Filename:  Nord - G2 Engine Slot C.syx
 Filesize:  4.02 KB
 Downloaded:  539 Time(s)
Nord - G2 Engine Slot D.syx
 Filename:  Nord - G2 Engine Slot D.syx
 Filesize:  4.02 KB
 Downloaded:  542 Time(s)
Nord - G2 Engine Slot B.syx
 Filename:  Nord - G2 Engine Slot B.syx
 Filesize:  4.02 KB
 Downloaded:  558 Time(s)
Kaan
PostPosted: Tue Mar 08, 2011 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, I didn't know too G2 Engine could receive the program change info externally, but it works! Smile
Thanks for sharing!
Nice to have 4 templates for every slots!
BTW I dumped my template but couldn't found the syx data in my PC. And couldn't send to Novation the templates?
Could you explain how I can do that, please?
Kaan
tIB
PostPosted: Tue Mar 08, 2011 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ive been using this: http://beta.novationmusic.com/releases/sl_mkii/
If you load the template in the editor and hit upload it will send it to the controller.
You figure out how to change the program? standard program change?
Kaan
PostPosted: Tue Mar 08, 2011 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the program! I was making the template on the Novation. With the editor it's became much easier.
About the program change, yep just standard program change. Press the quick menu on the Novation and change with second rotary knob.
BTW I just tweaked a bit the templates for my needs (changed the channels to 1,2,3,4; move the volume faders to the last 4 fader; changed the var. buttons display format to On/Off and opened up the key zones).
Edit: I tweaked a bit more (added program change to upper buttons of the variaton buttons as a temporary idea; actived drum pads, touchpad, modwheel, pitchbend; assigned CC's for the first 4 fader and dials) and replaced the files.
Lastly please excuse my Tarzan English Very Happy
Kaan
Nord G2 A.syx
 Filename:  Nord G2 A.syx
 Filesize:  4.02 KB
 Downloaded:  527 Time(s)
Nord G2 B.syx
 Filename:  Nord G2 B.syx
 Filesize:  4.02 KB
 Downloaded:  493 Time(s)
Nord G2 C.syx
 Filename:  Nord G2 C.syx
 Filesize:  4.02 KB
 Downloaded:  500 Time(s)
Nord G2 D.syx
 Filename:  Nord G2 D.syx
 Filesize:  4.02 KB
 Downloaded:  457 Time(s)
Kaan
PostPosted: Wed May 04, 2011 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here are the last versions of the templates (Added names to some of rotaries like Cutoff, res, LFO etc. changed some of the CC' to avoid conflict between the default CC's and added octave shift and Patch/Perf to the buttons at the bottom of first fader):
BTW does anyone know the ARP On's CC?
Nord G2 A.syx
 Filesize:  4.02 KB
 Downloaded:  282 Time(s)
Nord G2 B.syx
 Filesize:  4.02 KB
 Downloaded:  272 Time(s)
Nord G2 C.syx
 Filesize:  4.02 KB
 Downloaded:  262 Time(s)
Nord G2 D.syx
 Filesize:  4.02 KB
 Downloaded:  254 Time(s)
Kaan
http://soundcloud.com/phosphene-1
tIB
PostPosted: Thu May 19, 2011 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice job kaan, look forward to getting these in. Smile
BobTheDog
PostPosted: Thu May 19, 2011 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I wish they did one of those SLs without the faders and maybe with another row of encoders.
Is the quality good?
Kaan
PostPosted: Thu May 19, 2011 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks tIB.
BobTheDog, I like the faders actually, for the ADSR and volume control especially. And quality is pretty good to me.
BTW these are the last ones I promise Razz
Nord - G2 A.syx
 Filename:  Nord - G2 A.syx
 Filesize:  4.02 KB
 Downloaded:  292 Time(s)
Nord - G2 B.syx
 Filename:  Nord - G2 B.syx
 Filesize:  4.02 KB
 Downloaded:  307 Time(s)
Nord - G2 C.syx
 Filename:  Nord - G2 C.syx
 Filesize:  4.02 KB
 Downloaded:  291 Time(s)
Nord - G2 D.syx
 Filename:  Nord - G2 D.syx
 Filesize:  4.02 KB
 Downloaded:  286 Time(s)
Kaan
tIB
PostPosted: Mon Oct 03, 2011 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
6 out of 10 from me- works well but feels plasticy. I dont mind the faders either, though I would have prefferred more endless rotaries. I think the mk1 had more encoders.
speak_onion
PostPosted: Tue Oct 04, 2011 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I beat the ever loving shit out of my remote zero mk1 and it takes it like a champ. I've wrecked two Trigger Fingers in the time I've had this remote. It's definitely made of plastic, but I'd not worry about it breaking unless you pour water in it or something.
BobTheDog
PostPosted: Tue Oct 04, 2011 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I just wish they did something like this:
BobTheDog
PostPosted: Tue Oct 04, 2011 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice video, I think I would like one of your shows Wink
Jack_Hertz
Audio files: 101
G2 patch files: 7
PostPosted: Tue Oct 04, 2011 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Too bad that thing only has a MIDI interface. It could easily choke on the 64k buffer limit using all those CCs. USB is a saving grace in that regard. I have a BCR-2000 that I love, but you have to remember what you assigned where.
Right now I am using my iPad 2 and a custom MIDI-Touch template to control the G2 Engine. See pic below.
 Filesize:  67.29 KB
 Viewed:  304 Time(s)
Jack Hertz.com | Aural Films
frabo
PostPosted: Sat Oct 08, 2011 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Here are my two templets.
for me it is ok to use only these two.
feel free to use it.
37 - bollini - Nord Modular G2-edit.syx
 Filename:  37 - bollini - Nord Modular G2-edit.syx
 Filesize:  4.02 KB
 Downloaded:  274 Time(s)
38 - bollini - Nord Modular G2-global.syx
 Filename:  38 - bollini - Nord Modular G2-global.syx
 Filesize:  4.02 KB
 Downloaded:  270 Time(s)
Jack_Hertz
Audio files: 101
G2 patch files: 7
PostPosted: Sat Oct 08, 2011 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, but what controller are these for?
frabo
PostPosted: Sat Oct 08, 2011 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
oh, sorry, yesss aa..
Remote SL
Confused
tIB
PostPosted: Wed Jun 01, 2016 3:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Pardon the necro-ing of this one but Ive come full circle- just sat programming a remote sl for control of my recent repurchase!
tIB
PostPosted: Wed Jun 01, 2016 3:36 am    Post subject:   Reply with quote  Mark this post and the followings unread
And imagine how pleasantly surprised I was to find all the patches for the remote zero ii work in the remote SL keyboard!
