My nord lead occasionally turns off and on?
Page 1 of 1 [3 Posts]
Roman
PostPosted: Sun Oct 21, 2007 5:21 pm    Post subject: My nord lead occasionally turns off and on? Reply with quote  Mark this post and the followings unread
Maybe a better description is that it seems to reboot. Sometimes it stays clicking as if it's trying to reboot at which point I turn it off.
This happens a few times a month.
Roman.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Oct 21, 2007 11:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome Roman
It could be there is something wrong with the power supply.
Open the red hood by unscrewing all the screws like those four at the back of the synth (two at each side, but leave those two with the washers which are used as an articulation) and don't forget the one at the bottom side, right underneath the wheel.
Check all cables (some can be disconnected a little) and the fuse.
If you can't find anything, contact Clavia support or a dealer. Maybe the power supply needs to be replaced.
Wout
munkthalund
PostPosted: Thu Apr 07, 2011 5:21 am    Post subject: My Fix Reply with quote  Mark this post and the followings unread
I have two NL3s acting out this way,
a few weeks ago a boffin friend helped me track the cause
I've posted a fix here. Worked like a charm on both my synths.
http://www.gearslutz.com/board/6515383-post19.html
