my first PCB layout (need advice & correction)
Page 1 of 1 [3 Posts]
lintang
PostPosted: Fri May 06, 2011 3:52 am    Post subject: my first PCB layout (need advice & correction) Reply with quote  Mark this post and the followings unread
Hi...
I`m beginners.., now i`m sarting my 1st project to make my little step sequencer...
this is myu PCB layout
for suhu or master please check my lauout, and give me some correction Smile
thanks`
 Filesize:  93.56 KB
 Viewed:  271 Time(s)
andrewF
PostPosted: Fri May 06, 2011 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
welcome to electro-music
Could you post a schematic to check the layout against?
cheers!
bubzy
Audio files: 64
PostPosted: Fri May 06, 2011 8:00 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome Smile
although quite difficult to read as the image quality isn't good, your schematic looks ok at a glance, however, a schematic would be clearer to read and easier to troubleshoot, or perhaps both together. if you are planning to etch this board yourself, you may want to consider the size of the traces you are using, as they seem quite thin and may get etched away by the solution.
Hope this helps a little bit.
-Bubzy
