Protection cv input on SoundLab Plus?
Page 1 of 1 [3 Posts]
Mesir1
PostPosted: Tue May 10, 2011 12:49 am    Post subject: Protection cv input on SoundLab Plus? Reply with quote  Mark this post and the followings unread
I`ve just finished building the Baby10 sequencer, and it`s time to hook it up with my SLP. Do I need to protect the cv input in any way, or is it safe to use the Baby10 as it is, without damaging the SLP?
jordroid
PostPosted: Tue May 10, 2011 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
You should be fine connecting the baby 10 CV outs directly to the soundlab CV inputs. The soundlab (and most other synth gear) is designed to deal with quite large signals, +5 to -5 volts is a common standard, and you would have to send it a considerably larger signal than that to cause any damage.
It's one of the significant benefits of properly designed modular synth gear, you can plug anything into anything else without fear of damage Smile
jordan
Mesir1
PostPosted: Tue May 10, 2011 11:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, then I`ll give it a try.
