Newbie Q: Sporking and Global Arrays
Page 1 of 1 [5 Posts]
vze26m98
PostPosted: Fri Jun 17, 2011 11:30 am    Post subject: Newbie Q: Sporking and Global Arrays Reply with quote  Mark this post and the followings unread
Hi all-
I thought I knew how to do this earlier in the week, but either I'm wrong or have forgotten the incantation.
In file "one.ck" I have a global array:
Code:
[6, 12, 18, 24, 30, 36, 42, 48, 54, 60, 66, 72, 78, 84, 90, 96] @=> int freqs[];
...along with the code to feed this to a Ugen and on to the dac.
I have another file, "two.ck" that has only a reference to the Array "freqs" with different data from the above.
At the terminal, I want to "chuck -l one.ck" in one window, and want to "chuck + two.ck" in another, expecting the array of frequencies to change value.
I get either a sporked shred that does nothing or syntax errors.
Any idea what I'm doing wrong? Pointers on the best way to accomplish this?
Many thanks, Charles
PostPosted: Fri Jun 17, 2011 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Only thing I know is that, in order to make things visible across chuck source files like this, you need to put them as static members of a class, like:
Code:
class MyGlobalStuff {
      [6, 12, 18, 24, 30, 36, 42, 48, 54, 60, 66, 72, 78, 84, 90, 96] @=>static int freqs[];
Now you can do <<< "freq 1 iz: ", MyGlobalStuff.freqs[1] >>> etc.
/Stefan
vze26m98
PostPosted: Fri Jun 17, 2011 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Stefan-
I was heading in that direction. It seems you can't initalize an array inside a class, so this is the way to do it:
Code:
class Foo {
  static int freqs[];
[100, 150] @=> Foo.freqs;
<<<Foo>>>;
(Wow, strange Forum bug screws up ChucK code. Here's what it should be:
More later when I actually get my problem solved.
Best wishes, Charles
 Filesize:  19.89 KB
 Viewed:  5680 Time(s)
vze26m98
PostPosted: Fri Jun 17, 2011 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
It has to be declared a "public" class to be visible from another shred:
Code:
public class X {
  static int freqs[];
PostPosted: Fri Jun 17, 2011 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah public class and no initializer - check. This is one of those things that are poorly documented indeed.
Regarding weird code in your posts - you usually need to turn off HTML and smilies in the post when you include ChucK code - it's two of the five little checkboxes under the text area where you write your post. You need to keep BBCode on to make the code box work.
/Stefan
