today> Twyndyllyngs Chez Mosc
PCBs for Thomas Henry's X-4046 VCO
Page 8 of 12 [296 Posts]
Goto page: Previous 1, 2, 3, ..., 6, 7, 8, 9, 10, 11, 12 Next
PostPosted: Tue Jul 26, 2011 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
so there must be something wrong (no news, ain't it?). the good news is, that the circuit and the board is proven to be correct, so there will be an error that you can easily correct. you just have to find it Very Happy
i would triple check all wiring 1st.
then "greenline" the schematic, thus measuring and checking all connections and values, and marking them with a green pen on a printout of the schematic.
(any other color would do, i made good experiences with green, though).
tokyomatik
Audio files: 6
PostPosted: Tue Jul 26, 2011 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
hey thanx for the goods news
i think you must be a really funny guy
is a luck that you don't live in berlin
probably i was coming to you everyday in your pl Laughing ace to stress you because something is not working....
tokyomatik
Audio files: 6
PostPosted: Tue Jul 26, 2011 12:22 pm    Post subject:   Reply with quote  Mark this post and the followings unread
ehm
while i was checking with the multimeter the coarse pot
pin 1 and pin2 by mistake i touched the two terminals and i saw some smoke coming from the area of the tl074 on the vco core
Crying or Very sad
so now i don't know if i burned the tl074, or the electrolithic or one of the resistors at the bottom of the ic or the 220r close to the -v....something happened around there......
somebody can lend me a gun that i wanna kill myself?
PostPosted: Tue Jul 26, 2011 9:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
tokyomatik wrote:
ehm
Crying or Very sad
oops.
what i would do:
1st - triple check wiring and "greenline" as mentioned above; without power connected to the board, of course.
2nd - replace the TL074
BTW resistors can take quite a little bit of power. if you burned one, you should see it by the chenged color of the resistor (turned brown).
PostPosted: Wed Jul 27, 2011 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Unless all the magic smoke escaped through a tiny little hole on the underside - I've seen that on low valued resistors (like 10 Ohm or lower) - pretty hard to spot that with the eyes only.
PostPosted: Wed Jul 27, 2011 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
thank's for the hint, jan. fortunately i did not fry too many resistors yet Laughing
sonic
PostPosted: Sat Sep 10, 2011 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Fonik
Do you still have spares? I would love 2 sets if you have them.
Richard
PostPosted: Sat Sep 10, 2011 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
i will have to check the open orders vs. what i have left here on monday. i think i have still enough core PCBs, but i am not sure about the waveshapers... hold on.
sonic
PostPosted: Sat Sep 10, 2011 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Okay. Thanks mate. Fingers crossed. Smile
PostPosted: Mon Sep 12, 2011 12:25 am    Post subject: Reply with quote  Mark this post and the followings unread
all good, sonic. check PM soon.
oozitron
PostPosted: Fri Oct 21, 2011 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Finally getting a chance to build this and I'm hesitating on cap C11
In my notes I have written "MYLAR" next to it, and I've backtracked thru the various threads but can't find out where I got this from.
Does C11 have to be Mylar? Or will a good quality Polyester Film work?
(If anyone has a specific Mouser part they've used that would be ideal)
I want it to really sound good, since I've sold one of my Blacet VCOs to fund a batch of these!
THANKS!
Drew
PostPosted: Fri Oct 21, 2011 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
C11 is just for the AC coupling of the FM input, so not critical at all IMHO. it is not part of the audio path anyways.
a.b.o.z.
G2 patch files: 4
PostPosted: Mon Oct 31, 2011 4:18 am    Post subject: Reply with quote  Mark this post and the followings unread
matthias, are there any boards left?
I would like to have one set if possible.
cheers
Ivan
PostPosted: Mon Oct 31, 2011 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
i have some core PCBs left. i re-ordered a few waveshaper PCBs to have complete sets again. they should arrive early november... i will let you all know here in this thread.
inlifeindeath
PostPosted: Wed Nov 09, 2011 8:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wooo hooo! Just got mine put together and it works great first shot! Used the scope to calibrate it, easy enough. Sounds great and is a blast to play with. The hard sync is indeed awesome, thanks all who were involved!
Video as soon as I can find the camera charger.
PostPosted: Thu Nov 10, 2011 12:49 am    Post subject: Reply with quote  Mark this post and the followings unread
he is doing a video, he is doing a video... banana
PostPosted: Thu Nov 10, 2011 12:50 am    Post subject: Reply with quote  Mark this post and the followings unread
BTW the waveshapers are in, so i now have a few complete sets again...
a.b.o.z.
G2 patch files: 4
PostPosted: Thu Nov 10, 2011 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, loged in finaly.
I would like one set please.
Ivan
SubG (deactivated)
PostPosted: Sat Nov 12, 2011 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
have a question regarding the outputs:
ramp out = 'skew' output
pulse out = output affected by PW and PWM
is this right?
thanks
PostPosted: Sat Nov 12, 2011 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
is this right?
thanks
yes.
J6 is the "rampoid" out, which is influenced by the "skew" control pot (R53). i think this is what you mean?
my explanation: "ramp" is another word for "saw", and the "rampoid" is a mixture of "triangle" and "saw".
J10 is the pulse out, affected by PW and PWB
SubG (deactivated)
PostPosted: Sun Nov 13, 2011 2:02 am    Post subject: Reply with quote  Mark this post and the followings unread
reve
PostPosted: Mon Nov 14, 2011 6:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
So after a lot of dilly-dallying, I finally got around to building my boards and shapers (polyphony will finally be mine!). I'm still waiting for pots, so in the meantime I figured I'd start drilling panels.
Thing is, I want to have the option of using the shapers with external VCOs as well. I figured I'd just run the triangle out from the core to a normalized jack and then run it back to the shaper? Is there anything with... wire length or shielding anything that I need to worry about or would that be cool?
Seems like a stupid question, but... I'd rather ask it before drilling panels just to be sure. Smile
- r. mosquito
SynthDIY Synthpop -> http://www.reverbnation.com/photovoltaik
PostPosted: Tue Nov 15, 2011 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
since you use this normalized jack as an input, there is nothing more to think about. you wanted to use the triangle ouput on the J_WS header on the core board for this, i believe.
The Bad Producer
PostPosted: Tue Nov 15, 2011 5:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias, have you got two sets perchance? Seems I missed this!
PostPosted: Tue Nov 15, 2011 5:49 am    Post subject: Reply with quote  Mark this post and the followings unread
yes.
