The Liquid High Hat - Back from the dead! [PCB's]
Page 10 of 12 [284 Posts]
Goto page: Previous 1, 2, 3, ..., 8, 9, 10, 11, 12 Next
HexInverter
New postPosted: Tue Aug 30, 2011 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
magneticstripper wrote:
put me down for 2 please.
Sure thing!
dnode
New postPosted: Tue Sep 06, 2011 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Hope I'm not to late ... I'd really like two boards as well!
Anyway it works out, thanks and compliments on your efforts!
HexInverter
New postPosted: Tue Sep 06, 2011 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope! Not too late. I ordered some extra this time. Got ya down for two, now!
zoot horn rollo
New postPosted: Tue Sep 06, 2011 8:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
I would like to buy one board as well if it is not too late!
Thanks
HexInverter
New postPosted: Tue Sep 06, 2011 8:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
zoot horn rollo wrote:
Hello,
Thanks
Sure thing! Very Happy
rosch
New postPosted: Sat Sep 17, 2011 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
i figured i might as well ask here (just asked @TSOL too)
can the LHH be run from +/-9V or +/-15V too? seems like this is actually thought for 12V, no?
edit: yup, works. just got the answer from Rich.
JoeMorris
New postPosted: Sun Sep 18, 2011 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Would like two boards por favor. Ta, Joe
HexInverter
New postPosted: Sun Sep 18, 2011 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Gotcha!
Actually, you're on the spreadsheet already! Very Happy You missed the first time around I think, so I carried you over to the one for this round automatically Smile
They should be here soon hopefully! They're definitely on their way here by now...it's just a matter of them being delivered!
Paradigm X
New postPosted: Wed Sep 21, 2011 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
yo hex, can you please send me the schematic, i ant find it anywhere, nearly finished building it now but a couple of head scratchers (see soundoflogic forum)
email to paradigmx <at> paradigmx <dotcom> would be aweome.
Many thanks, Ben
HexInverter
New postPosted: Wed Sep 21, 2011 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Many thanks, Ben
Done! And here's the link just in case something funny happens with the email...
http://hexinverter.net/?projects=liquid-high-hat-v11
rosch
New postPosted: Wed Sep 21, 2011 5:02 am    Post subject: Reply with quote  Mark this post and the followings unread
here's a shot from the manual (proto board), i guess the negative electrolytic cap (C2) should be reversed, no?
 Filesize:  102.96 KB
 Viewed:  207 Time(s)
HexInverter
New postPosted: Wed Sep 21, 2011 5:23 am    Post subject: Reply with quote  Mark this post and the followings unread
You are correct! The board has a mistake on it. Sorry about that!
NOTE: MAKE SURE TO INSTALL C2 OPPOSITELY BIASED TO WHAT THE BOARD LAYOUT/SILK-SCREEN SAYS!
(Edited out the error for clarity to avoid any confusion)
marvkaye
New postPosted: Wed Sep 21, 2011 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
HexInverter wrote:
The negative supply filter capacitor's positive lead should be at -V, and its negative lead at GND.
Huh?? On the negative supply the ground is at a positive potential compared to the negative voltage, so the + lead of the capacitor should connect to ground, the minus lead to the - voltage, shouldn't it? Unless I've been missing something along the way (not impossible, I'll admit Rolling Eyes )
<marv>
rosch
New postPosted: Wed Sep 21, 2011 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
i'm wondering if i'm missing something here.
i think normally it would be like -V _ C-C+ _ GND _ C-C+ _ V+
i haven't analyzed the whole circuit though, might be i miss something essential
HexInverter
New postPosted: Wed Sep 21, 2011 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
YIKES! Sorry guys. Good call!!!
I will make a large warning in the assembly manual to install it in the correct position.
This is why engineers have an entire design team behind them...so when someone makes a silly mistake, the others catch it. Thanks guys Smile
Paradigm X
New postPosted: Wed Sep 21, 2011 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the shems and the update.
Interesting how mattias got his working with it reversed (although if i understand it right its a non critical part of the power supply (?))
The schems are wrong too then if the above is correct. (I think) - only this capacitor tho.
Cheers, ben
HexInverter
New postPosted: Wed Sep 21, 2011 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers, ben
Yes, the way the layout software works is that whatever is in the schematic winds up in the board. I will have to update the schematic eventually!
Well, its just a filter capacitor, but they can blow up when reverse biased sometimes D:
rosch
New postPosted: Wed Sep 21, 2011 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks, hex
should have finished it soon!
mattias
New postPosted: Fri Sep 23, 2011 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ooops, should fix that on mine. Usually I check those caps on the power rails independently of the assembly instructions, but somehow I goofed this time. I guess they survived because they are heavily overrated at 63Volts.
HexInverter
New postPosted: Wed Oct 05, 2011 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is a package waiting for me at the post office Smile I will be picking it up after my exam today...hopefully it's the boards! I can't think of anything else that it would be Wink
Once I am home with the boards and have inspected them, I will edit the thread with payment information and dispatch messages to people who ordered!
decaying.sine
New postPosted: Wed Oct 05, 2011 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hex,
I'd like to buy two if you have any leftovers. I also posted at Muff's using the same username.
Brian / decaying.sine
HexInverter
New postPosted: Fri Oct 07, 2011 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
To the people who have sent payments thus far: your orders will be shipping Tuesday morning! Smile Unfortunately this Monday is a holiday (Thanksgiving) so postal service is not running.
Also, any orders received by Monday afternoon will be going out in this batch. I will post back here once they are shipped!
Theta_Frost
New postPosted: Sat Oct 08, 2011 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Is it alright if I can tack on another board to my order so I can get 2? I'm ready to order now, but I wanted to make sure it would be alright because I originally said one. Thanks!
HexInverter
New postPosted: Sat Oct 08, 2011 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is just fine! Smile I take "pre-orders", but since I do not take any money up front, it is first come first served! If I held onto boards...well, then I'd be still hanging onto some from the first batch that people never actually came back for xD
Theta_Frost
New postPosted: Mon Oct 10, 2011 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ordered! Woohoo! Excited for my first forray into modular, and DIY synth.
