LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Wed Nov 16, 2011 1:13 am Post subject:
you built four of them and want more? so you are happy with them?
your synth looks great BTW - looks vintage...
and yes, i have PCBs available. _________________
Tech Buddy at Random*Source |
LektroiD
Posted: Wed Nov 16, 2011 6:44 pm Post subject:
| fonik wrote: | you built four of them and want more? so you are happy with them?
and yes, i have PCBs available. |
Indeed, they do everything an oscillator should, and track very nicely over a good range of octaves.
I'm in the process of moving, so now is not an ideal time to buy, but I'm definitely in for some more soon! Ideally I'd like another 8, but funds are looking more like I can only stretch to another 4 sets (I may come back for more at a later date).
Also, any plans for Fonik VCAs? |
a.b.o.z.
Joined: Feb 07, 2007 Posts: 351 Location: Zagreb, Croatia
G2 patch files: 4
Posted: Thu Nov 17, 2011 3:43 pm Post subject:
Got mine boards today. Looking funky
Thank you |
aladan
Posted: Wed Dec 07, 2011 3:57 pm Post subject:
Low triangle output level on Fonik X-4046 core PCB? |
Last night I finished building a X-4046 core board (Fonik style) and the saw and triangle waveforms are looking and sounding beauitful. Sawtooth is around 5V p-p, but the triangle is much quieter; less than 2V p-p. Is this normal? Can I simply decrease the value of R4 (currently 1K) to increase the level of the triangle output, or should I be looking at R32 or trying alternatives for IC3 instead (I think I ended up using a uPC324 because I had no TL074s handy?)
Thanks for the boards Fonik - ordering was a breeze, the price was very reasonable and they arrived here in Australia very quickly. Even the PCB layout and the red boards are aesthetically pleasing! I couldn't be happier
On the weekend I'll try out the waveshaper... |
Posted: Thu Dec 08, 2011 12:16 am Post subject:
Re: Low triangle output level on Fonik X-4046 core PCB? |
| aladan wrote: | | Last night I finished building a X-4046 core board (Fonik style) and the saw and triangle waveforms are looking and sounding beauitful. Sawtooth is around 5V p-p, but the triangle is much quieter; less than 2V p-p. Is this normal? |
actually not. what 4046 IC are you using?
| Quote: | | Can I simply decrease the value of R4 (currently 1K) to increase the level of the triangle output, or should I be looking at R32 or trying alternatives for IC3 instead (I think I ended up using a uPC324 because I had no TL074s handy?) |
R4 is nothing but the output impedance resistor according electro notes.
increasing R32 would add gain.
the uPC324 has a wider swong than the TL074, so i don't think this is an issue. _________________
aladan
Posted: Thu Dec 08, 2011 5:55 am Post subject:
| fonik wrote: | | aladan wrote: | | Last night I finished building a X-4046 core board (Fonik style) and the saw and triangle waveforms are looking and sounding beauitful. Sawtooth is around 5V p-p, but the triangle is much quieter; less than 2V p-p. Is this normal? |
the uPC324 has a wider swong than the TL074, so i don't think this is an issue. |
Thanks for your response Fonik,
The 4046 is one of the "good" brands - an NXP HEF4046BP. I have a few spares of those I can try, and some other unrecommended ones (unknown brand 4046B, ST HCF4046BE and TI CD4046BE.) I checked R32, it's definitely 100k. And I did find and use a TL074 so that's not the issue there either.
Tomorrow I'll try a bigger resistor for R32 and let you know how it goes.
Thanks again!
Adrian. |
Posted: Fri Mar 09, 2012 5:09 am Post subject:
i just wanted to let you know that i re-ordered a few more of PCBs for this VCO. due to the low order quantity i had to raise the prices.
the PRICES (revised for low quantity re-order)
7.- EUR/10.-USD for the VCO core PCB (saw/tri)
and
5.- EUR/7.-USD for the waveshaper PCB (tri2sin/pulse/PWM)
+ p/p
Deutschland: 1.- EUR/2 PCBs, 1.50 EUR/3+ PCBs
Europe: 2.- EUR/2 PCBs, 4.- EUR/3+ PCBs
Outside Europe: 4.- USD/2 PCBs, 6.- USD/3+ PCBs _________________
hegeldas
Posted: Mon Apr 16, 2012 10:20 pm Post subject:
| Is it possible to count one of each for me ? how to pay? |
Posted: Mon Apr 16, 2012 11:12 pm Post subject:
you do the right thing, check PM.  _________________
elanhickler
Joined: Jun 24, 2008 Posts: 152 Location: Gilbert, Arizona
G2 patch files: 6
Posted: Tue May 29, 2012 10:12 am Post subject:
| Is this a saw core VCO? |
Posted: Tue May 29, 2012 12:41 pm Post subject:
it is both, a saw and a triangle core VCO!
tomas henry used a very clever method to combine several outputs of a manipulated CD4046 to form both, a saw and a triangle output.just take a look at the schematics:
http://www.birthofasynth.com/Thomas_Henry/Pages/X-4046.html _________________
elanhickler
G2 patch files: 6
Posted: Tue May 29, 2012 12:55 pm Post subject:
Aha, a response! Hey! Another question: Does this VCO have variable sync? According to your panel it doesn't but just wondering if you left it out... since... tri-core oscillators usually have it. (Anyway I'm interested in this VCO for its hardsync everyone is raving about!)
What's the + p/p 1 euros for 2? |
Posted: Tue May 29, 2012 10:33 pm Post subject:
| Argitoth wrote: | | Aha, a response! Hey! Another question: Does this VCO have variable sync? According to your panel it doesn't but just wondering if you left it out... since... tri-core oscillators usually have it. |
don't forget, this is not a VCO with comparator/integrator core. it uses a PLL as core... anyways, this hardsync is worth it.
| Quote: | (Anyway I'm interested in this VCO for its hardsync everyone is raving about!)
all prices are written in the 1st post of this thread, however, the PCBs are currently sold out. nevertheless, i will re-order a new batch soon and announce it herein the sub-forum.
hope this helps. _________________
OSCANO
Posted: Thu May 31, 2012 1:38 am Post subject:
Re: PCBs for Thomas Henry's X-4046 VCO Subject description: re-ordered a few spares... |
| Hi! do you still have the PCBs??? Need 2 of each, thanks. |
Posted: Thu May 31, 2012 2:18 am Post subject:
i will re-order a batch soon, however, i will have to complete the PS3100 resonator PCB sale first.... _________________
aladan
Posted: Tue Jun 05, 2012 9:57 pm Post subject:
| fonik wrote: | | i will re-order a batch soon, however, i will have to complete the PS3100 resonator PCB sale first.... | Count me in for a few more when you do... need more VCOs, loving the X-4046  |
Joined: Jan 07, 2009 Posts: 1226 Location: Scottish Borders
Audio files: 161
Posted: Tue Jun 19, 2012 11:27 am Post subject:
Hi Fonik
2 core's & 2 shapers for me please .
Thanks again
Dave. |
elanhickler
G2 patch files: 6
Posted: Tue Jun 19, 2012 12:41 pm Post subject:
I am confooozd...
So, is the PCB available? Where do I send payment? If paypal, what's the address? When will it be shipped?  |
Audio files: 161
Posted: Tue Jun 19, 2012 2:24 pm Post subject:
| Argitoth wrote: | I am confooozd...
Keep an eye on this thread over the next month or so , Fonik says "after the ps3100 boards are all parceled up & posted off , he will order another batch of the vco pcb's , register your number of boards required so he can get a rough idea how many to order from the factory
Dave. |
baudrate
Posted: Tue Jun 19, 2012 6:41 pm Post subject:
| I can't wait to build a pair of these! |
Mongo1
Posted: Tue Jun 19, 2012 8:20 pm Post subject:
I'd definitely be in for a pair of these... Looks great!
Gary |
Oort Cloud
Posted: Tue Jun 26, 2012 6:34 am Post subject:
| I'm in for 4 core & 4 wave shapers PCBs. |
tokyomatik
Audio files: 6
Posted: Tue Jun 26, 2012 5:12 pm Post subject:
i think i did something wrong with one of my boards.
i desoldered maybe 3 or 4 times the tempco and now the pads are gone, so now on my scope i can see the triangle wave only when i turn the frequency pot at 50% or more, before just flat, the sound is pretty acute on the high high frequencies....i hope i didn't killed all the dogs of the neighborhood with it ...or drive crazy dolphins and bats.... in wich way i could fix this??
just in case, are there some pcbs available?? |
elanhickler
G2 patch files: 6
Posted: Sun Jul 08, 2012 3:09 pm Post subject:
Is it OK to use Mouser # 147-72-104-RC 100n capacitor for VCO and Waveshaper boards?:
C10
C12
C13
C300
C400 |
