SpringSim
Page 1 of 1 [8 Posts]
PostPosted: Wed May 23, 2012 12:53 pm    Post subject: SpringSim
Subject description: Accutronics Digi-Log-Reverb Module
i made myself a simple reverb module built around an accutronics digi-log-reverb unit. the schematic is according to the datasheet, however, i changes some values to accomodate my synths audio levels.
Junk Rhythm
PostPosted: Wed May 23, 2012 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice Fonik! If you ever do a small run for the PCB, I'm in for one. SMD is super easy. Very Happy
[twitter] [blog] [flickr] [toppobrillo] [buzz]
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger
mark_olson
PostPosted: Wed May 23, 2012 7:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Really nice! Inspiring too - I have an Acutronics reverb tank that's been gathering dust for years because I don't seem to have the time or motivation to adapt a circuit for it. Seeing this makes me think I might never get around to it, this being such a straightforward alternative.
Mark
diablojoy
PostPosted: Wed May 23, 2012 10:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Orsm as usual matthias
2 for a true stereo version would be nice
sign me up for 4 if you do produce a board Smile
my current spring reverb is a box 2 feet square [the tank itself is huge] but then it is from the early 70's so this would be quite a bit more manageable panel wise Laughing
ask where the hell am I
as good an answer as any
PostPosted: Thu May 24, 2012 11:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
mark_olson
PostPosted: Fri May 25, 2012 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Real cool. Thanks for posting the video.
Mark
diablojoy
New postPosted: Sun Jun 24, 2012 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
just ordered 2 short and 2 long digi-log-reverb units from small bear
decided against getting the mediums as well not enough difference to warrant adding them in
should make for a nice module true stereo with a mix of short and long times available.
thanks matthias will be studying your schematic for the value changes
you used Smile will save me a lot of time
izash
New postPosted: Fri Jul 21, 2017 4:10 pm    Post subject: Reverb Module - Opamps Reply with quote  Mark this post and the followings unread
Hi Fonic,
Thank you for some great designs. I learn a lot!
I'm an electronics newbie, so please explain how the output opamps work in this circuit. Are they used as differential amps? How do they mix the dry and wet signals.
Izhar
