 Forum index » Instruments and Equipment » Percussa Audio Cubes
Improvisor: MIDI Sequencer application for AudioCubes
Post new topic   Reply to topic Moderators: bschiett
bschiett
PostPosted: Mon May 28, 2012 3:21 am    Post subject: Improvisor: MIDI Sequencer application for AudioCubes Reply with quote  Mark this post and the followings unread
I would appreciate your feedback on improvisor, the MIDI sequencer we created for the AudioCubes. We created this application to let people compose music in a generative way.
Let me first quickly explain to you how improvisor works. Each sequence has a semitone and velocity patterns, relative to a root note. You can play back semitone patterns using different velocity patterns, or also the other way around. Semitone patterns can follow each other, so they will add to each other's relative semitone steps.
We've a made couple of videos using the AudioCubes and improvisor.
http://youtu.be/-CgG_YazsRY
http://youtu.be/ottBCeA1QDE
percussa mSSP - digital modular in a eurorack module - 8 in/4 out @ 48/96/192khz DC coupled - 25+ DSP modules https://www.kickstarter.com/projects/percussa/percussa-micro-super-signal-processor-eurorack-mod
