Sine core VCO?
Page 1 of 1 [4 Posts]
formant84
PostPosted: Mon Aug 13, 2012 2:42 am    Post subject: Sine core VCO? Reply with quote  Mark this post and the followings unread
Hi all,
I've built a couple of VCOs recently , namely THs XR-VCO and VCO-1. Whilst i'm very happy with how these have turned out, i can't seem to adjust the sine wave well enough so that it sounds pure at really low frequencies, and one thing i wanna do with my kit is produce some really fat sub bass, so this is a small problem.
So what I was looking in the LM13700 datasheet and there is a schematic there for a sine core VCO, so I thought it'd be cool to build that and then derive all the other waves from the sine, but looking around online I can't seem to find any evidence of anyone doing things this way around. Is there a good reason for this which I haven't spotted? Because it seems to me that a perfect sine is the hardest wave to produce and the easiest one to hear the difference in when it's not quite right, so surely a sine core VCO is a good idea?
I'm guessing i'm totally wrong here because if it was such a good idea then there would probably be lots of them about, but i'm just curious as to why this isan't a more popular approach?
Any answers appreciated,
John
frijitz
Audio files: 54
PostPosted: Mon Aug 13, 2012 11:42 am    Post subject: Re: Sine core VCO? Reply with quote  Mark this post and the followings unread
formant84 wrote:
... Because it seems to me that a perfect sine is the hardest wave to produce and the easiest one to hear the difference in when it's not quite right, so surely a sine core VCO is a good idea?
Detailed discussion and circuitry here:
http://www.electro-music.com/forum/topic-19841.html
Yves sells a nice VCQO board.
As far as your other comments, human hearing falls off at low frequencies, so any harmonics will sound especially loud.
Trouble with a Sin core is there is no easy way to get the other "standard" waveforms. You can do a "Sin-Saw", and it is probably about as useful as a Saw, but not the same thing. Pulse is easy to do, but the PW response is nonlinear.
Ian
formant84
PostPosted: Mon Aug 13, 2012 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah right, i just assumed that since the sine seems to be the most fiddly waveform to produce from a triangle or saw then it'd be easier to start with the sine and go the other way, silly me!
That's a really cool circuit, i think i'll have to build one of those this week to have a play! Looks like it could provide me with a good sine for my sub bass as well as the wave mixing features, and you can never hav too many oscillators!
Thanks again for the advice,
John.
Peake
PostPosted: Tue Aug 14, 2012 11:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could try a Mankato or other wide-range VC filter in self-oscillation..
