 Forum index » DIY Hardware and Software » PAIA Equipment
Paia two-note ribbon controller
Page 1 of 1 [13 Posts]
MirlitronOne
PostPosted: Tue Jan 03, 2012 12:50 pm    Post subject: Paia two-note ribbon controller Reply with quote  Mark this post and the followings unread
I'm sure that this question should have been asked elsewhere, but I've searched and can't find anything relevant. The question is:
"Has anyone ever successfully built John Simonton's two-note ribbon controller circuit, shown at http://www.paia.com/ProdArticles/dual-ribbon-howto.htm?"
The reason I ask, naturally, is that I have spent the last week laying the circuit out on stripboard and everything works except for the follow-and-hold circuitry. The 'hi' note generator derivation circuitry works fine as does the trigger generator. If isolated, the follow-and-hold circuits work fine. If I unplug the 4066 chip, I can set and hold both ribbon voltages using wire bridges; however, when the chip is in place, both high and low outputs drop to zero as soon as the finger is removed and the gate signal switches off. Same when the 'hold' switches are used (I've used ordinary toggles for hold rather than the touch plate approach).
I've tried two 4066 chips and a 4016 - same results every time. Oh, and I'm using a Spectrasymbol linear sensor for the ribbon.
My tests indicate that the control voltages for the 4066 switches are way out - the control inputs are biassed slightly negative of zero to ensure a clean trigger and when the gate operates, the voltage at the control inputs only rises to about 1 V. However, the switches open fine - it's just that they leak as soon as the gate signal disappears.
All suggestions gratefully received! scratch scratch scratch
[Incidentally, did Paia ever sell a kit for this circuit?]
Life is like an analogue sequencer. Twiddle the knobs to avoid boredom.
MirlitronOne
PostPosted: Tue Jan 03, 2012 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Okay, update - slight impedance issue overcome. The voltages controlling the switch control inputs on the 4066 are actually operating between -0.7 V (off state) and +5.8 V (on state), which, although short of VDD, should be okay for switching states.
The only remaining explanation is one of timing - I guess the 'Lo' and 'Hi' voltages are dropping faster on releasing the ribbon than the 4066 can isolate the follow-and-hold circuitry, so next task is to examine the capacitor values more critically.
TheLoneRoger
PostPosted: Thu Feb 23, 2012 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
How are you getting along with this?
It's been on my project to-do list for several years, and now I'm finally about to make a start on it, so any tips or info I can get will be greatly appreciated (don't suppose you drew a stripboard layout...?).
I contacted Paia some time ago, and sadly the project's author John Simonton died of cancer before it got as far as being a commercial project, and they said they thought it unlikely that they ever would be.
Where did you get your ribbon, btw? I have an old piece of anti-static bag i was going to use, but it's looking a bit ragged now...
MirlitronOne
PostPosted: Fri Feb 24, 2012 5:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, you got a reply from Paia - they ignored my enquiry.
I gave up temporarily in frustration and haven't revisited it since. Suffice to say that the published circuit doesn't work. I fixed a few problems, but every time I fixed one another appeared! I now have a unit that triggers and sweeps up perfectly, but any downward glissando just drifts down far too slowly, and I still haven't found the reason. If I get it to work I'll post the stripboard layout, modifications and notes, but not until then - it would just mislead people into wasting time and effort on it. I may just give up and design something from scratch.
The strip I'm using is a 300 mm 'Spectrasymbol' linear position sensor from CPC Farnell. They're expensive - nearly £30 each - but I get a discount through work. There are shorter ones.
TheLoneRoger
PostPosted: Sat Feb 25, 2012 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, thanks for your reply. I'll see how I get on...
We also have a CPC account where I work, but the search engine on their site is useless and is not turning up anything under 'Spectrasymbol','hotpot' 'position sensor' etc. etc. Do you have a part no.?
MirlitronOne
PostPosted: Sun Feb 26, 2012 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree, the CPC / Farnell search engine is hopeless.
This isn't the exact one that I ordered, but it looks like it has replaced the Spectrasymbol part:
http://uk.farnell.com/multicomp/sp-l-0500-st/sensor-linear-membrane-500mm/dp/1734693
It's the same price and is also available in shorter lengths.
corex
PostPosted: Tue Mar 06, 2012 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure how Mouser is from the UK, but it's easy to find Spectra Symbol SoftPot ribbons, in sizes from 25mm to 1000mm:
http://www.mouser.com/Search/Refine.aspx?Keyword=softpot
vladosh
Audio files: 51
PostPosted: Fri Mar 09, 2012 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
greetings
This has also been on my - to do list . Well i guess ,who wouldn't want a TWO note ribon controller ,sounds more than great , i hope you folks can sort it out somehow ,it's just in some old post here on the forum there was someone who made some mods with success ,or he just said he did ,but what should be done i have no idea , anyway good luck with your work
vlad
frijitz
Audio files: 54
PostPosted: Sun Oct 21, 2012 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I looked at this several years ago and never got it to work. I took a deeper look at this just the other day. A quick circuit analysis suggests that the Track/Hold cannot possibly work correctly.
The T/H is operated by the "Trigger proc." section, ie the circuitry around IC3C. IC3C fires the Hold function when pin 10 goes below zero volts. This happens when the (smoothed) input signal goes below 0.24 volts. This is the voltage that is held. Always. Capacitor C2 discharges slowly through R24 when the finger contact is removed, so what you hear is a slow sweep down to the pitch corresponding to 0.24 V.
I wrote PAIA the other day to see if they could explain what's going on, but the guy there has no experience with the circuit and does not have a working version to look at. He didn't seem to understand the analysis I gave above.
I've scratched my head to see if the problem could be explained by some small error on the schematic, but so far I have come up blank.
I gave a fairly simple circuit that works well with the Softpot here:
http://www.electro-music.com/forum/topic-32246.html
The latest version is a bit of an improvement, but not by much.
Ian
MirlitronOne
PostPosted: Sun Oct 21, 2012 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Many would-be Nobel Laureates have spent huge amounts of effort trying to make sense of the last writings of Albert Einstein. Unfortunately, it appears to have been what might be euphemistically referred to as "not his best work". In other words, he was way off the mark.
Sadly, I think that, in a very real sense, this presumably untested circuit was not John Simonton's best work either. I wish Paia would take this misleading document off their website.
Thanks Ian for pointing out your contribution, which presumably is tested. I became so frustrated with the Paia circuit that my most recent thoughts have been to press an Arduino into action to do the difficult stuff in conjunction with a dual serial DAC for output. However, it's a little way down the 'to-do' list.
frijitz
Audio files: 54
PostPosted: Sun Oct 21, 2012 5:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
MirlitronOne wrote:
...Sadly, I think that, in a very real sense, this presumably untested circuit was not John Simonton's best work either.
I guess we will never know the whole story here. Maybe a schematic got switched or something. It's certainly difficult to concentrate on anything -- even your life's work --when you have serious medical issues.
Yep, have it sitting right here in a little white project box. It seems to work well with the softpot. There's a bit of a squish factor that changes the pitch a bit on release, but I've learned to compensate for that by rolling my finger a tad as I raise it.
There have been a couple of changes to the circuit to make it respond a bit faster and to reduce the levels into the CA3280 (5V input max on that one!) I should probably put up a modified schematic. It's a slightly "nicer" circuit, but I don't think it works much better in practice.
Yeah, I've been thinking about getting a touch screen for this and other applications. Lots of possibilities once you go to digital. (You've seen bebot? Linked by Howard in the other thread.)
Ian
StarTrek
PostPosted: Mon Nov 16, 2020 4:13 pm    Post subject: PAia ribbon controller
Subject description: i do think i got it to work
Hi i have been tweaked it for a long time and i got it to work now
(sample/hold) anyway. I made a Pcb in Eagle if someone want to
have the Pcb-layout and componet placement as well.
The outputs generates up to 5.5 volt and the "hold" function is up
to 1 min before is start to drop to much. You can change the cap
470n if longer "hold" is needed i think Smile And there is a lot of jumpers
i dont do doubble sided Pcb:s Confused i made a simple touch pad to try out.
 Filesize:  225.29 KB
 Viewed:  427 Time(s)
 Filesize:  62.8 KB
 Viewed:  320 Time(s)
 Filesize:  74.33 KB
 Viewed:  295 Time(s)
 Filesize:  68.26 KB
 Viewed:  342 Time(s)
 Filesize:  12.41 KB
 Viewed:  305 Time(s)
dk
PostPosted: Tue Jan 19, 2021 4:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome! This circuit seems to be the holy grail of non-working ribbon controllers, so it's great to see someone actually managed to get it going.
What ribbon did you use StarTrek?
